How do you add fork oil?
lugoismad
PostPosted: 05:50 - 06 Oct 2007    Post subject: How do you add fork oil? Reply with quote
I have leaky fork seals on my 75' Honda CB750
I know the seals need changed, but I want to try to put it off till winter. I don't know much about working on bikes. How do I top the fluid off, and what kind of fluid do I use?
PostPosted: 08:20 - 06 Oct 2007    Post subject: Re: How do you add fork oil? Reply with quote
Seals will just get worse and may spill oil on your brakes / tyres, which is iffy.
You generally loosen the top yolk, then unscrew the fork cap.
You get specific fork oil which comes in different weights. You will have to find the correct weight for your bike.
willi
PostPosted: 09:03 - 06 Oct 2007    Post subject: Reply with quote
there is no way to tell how much oil is in them. the only way is to drain them totally. and put the correct measurment in each one. if you put to much in they will be solid. ie no travel. your best bet is to leave it until you can put new seals in. or if nyou dont mind waisting your money drain both forks and top them up.
wat goes around comes around.
PostPosted: 09:16 - 06 Oct 2007    Post subject: Reply with quote
Providing they are the same each side, you can compare sides using a dipstick. Some bikes specify that fork oil should be filled to a certain distance below the top of the fork, with the fork fully extended I believe.
Though, as you say, too much will mean losing travel.
Ichy
PostPosted: 11:06 - 06 Oct 2007    Post subject: Reply with quote
TBH its only going to take a couple of hours to change the seals, assuming it goes well Laughing . If you don't want to do it by the book then take a look at this.
https://www.bikechatforums.com/viewtopic.php?t=125244&highlight=seals
Halfords sell fork oil in the motorbike section. Nothing special but about average price.
At worst pull up the dust covers and put some kitchen towel in there to try and stop the oil leaking down the fork leg.
JonT
PostPosted: 11:24 - 06 Oct 2007    Post subject: Reply with quote
Four Coils?
I wonder how many people will understand :p
Ichy
PostPosted: 11:53 - 06 Oct 2007    Post subject: Reply with quote
jonnyt wrote:
Four Coils?
https://www.angelfire.com/me/tvcomedy/fourcandles.html
2t-Screamer
PostPosted: 13:10 - 06 Oct 2007    Post subject: Reply with quote
about the only funny thing the two ronnies ever did
visit Collective Knowledge
lugoismad
PostPosted: 18:38 - 06 Oct 2007    Post subject: Reply with quote
I found a friend that is going to help me, and I ordered the parts from mrcycle.com
timjim
PostPosted: 15:38 - 07 Oct 2007    Post subject: fork oil Reply with quote
visit www.virtual-lounge.net
Obviously not a good memory!!!what about the phantom rasberry blower of old London Town...Ronnie Barker was a comic genius.RIP Thumbs Up
Back to the topic,i use a syringe..get them from most chemists...get a few odd looks from oaps!!,then measure the oil level with a cable tie dipped down the tube and compare left to right tube oil levels.
The last post was made 18 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 64.23 Kb
