Scared of High Mileage
Chriss
PostPosted: 12:24 - 06 Oct 2007    Post subject: Scared of High Mileage Reply with quote
Recently looking for winter hacks, and after the GPZ500 I had started to eat it's own weight in oil each week, probably thanks to the piston rings, I've been scared of bikes with high mileage! The GPZ500 only had about 46,000 miles on, which I don't really consider to be alot for a bike, but obviously is.
Is this normal? What sort of mileage do bikes normally get up to before dying? Is there a big difference between engines, ie inline four, twins etc?
Many thanks in advance
Chriss
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
feef
Energiser Bunny
PostPosted: 12:33 - 06 Oct 2007    Post subject: Reply with quote
in my garage I have the following:
'99 Thunderace with 56000 miles
'98 Firestorm with 62000miles
2003 FJR with 64000 miles
my old GPZ which died cos I embedded it in the front of an Astra, had 76000 miles
as long as they are well maintained, a highmileage bike will work fine. In fact, probably better than a VERY low mileage bike which has been used so little the oil isn't covering much of the internals, and the seals are all dry, and cracked.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
PostPosted: 12:34 - 06 Oct 2007    Post subject: Reply with quote
More down to how well it is treated. Charlottes last GPZ500 got nicked at about that mileage bit still burnt virtually no oil.
To an extent buy based on the owner rather than the bike.
panrider_uk
PostPosted: 12:38 - 06 Oct 2007    Post subject: Reply with quote
Engine size will also have a bearing.
Over 100,000 miles on a Pan (1100cc V4) isn't uncommon as its a very unstressed bike.
Buzzy sportsbikes will have a shorter engine life due to their high-revving nature.
Mark
PostPosted: 12:51 - 06 Oct 2007    Post subject: Reply with quote
Not so sure on that. Suspect that any difference there is more down to how often they are thrashed. Smaller sports bike is more likely to be thrashed, and probably far more likely to do short journies (it is warming up where most of the wear will happen).
BorderHooner
PostPosted: 12:53 - 06 Oct 2007    Post subject: Reply with quote
My firestorm had about 5K miles on it when I bought it - I sold it close to 9K and in those 4000 miles or so it needed a litre of oil every 500 miles.
There is no sure formulae to work out oil consumption. Some drink some don't.
Benelli. Happy as a pig in cacky.
jimbothe
PostPosted: 13:54 - 06 Oct 2007    Post subject: Reply with quote
My FJ12 (hack) is now sitting on 92k, uses a little oil but still nothing that I would be concerned over just yet and thats mainly only the valve stem seals from cold.
Ex FJ owners club bike so kept in extremely good order and changed every 3000 miles.
But as said before r.e. the Pan European, it's a bike designed to do plenty of miles.
I spoke to a chap a little while ago and told him mine was on very high miles and he said it was nothing for one and his had done 125,000 Shocked He reckons with regular servicing including the interims and just basic routine maintanence you can push a FJ in excess of 160,000
I sold my 500s quite a few years ago now with 38,000 on the clock and the guy three streets up from me is still riding it daily but only a local commute. Last time I looked it was on 54,000. Thumbs Up
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
brier88
PostPosted: 15:31 - 06 Oct 2007    Post subject: Reply with quote
I read an article about this exact topic in Ride and was explaining that a litre of oil in 1000 miles is manufacturer standard (a standard set in 1977 i hasten to add) but obviously due to technology these days shouldnt it be much less?
I quote from Ride "when the engine comes out of the factory the cylinder bores are not perfectly smoothe, so the piston rings can't achieve a perfect seal and the engine burns oil....To get a good ring seal use a poor quality oil and high throttle openings to create the necessary wear."
Obviously the manufacturers don't reccommend this and only applies to new bikes. All yamaha bikes for example fill thier bikes with cheap mineral oil to aid the wearing in process.
hope this helps with anyone getting a new bike.
Brier Thumbs Up
nynfortoo
PostPosted: 15:53 - 06 Oct 2007    Post subject: Reply with quote
It won't do. People read these 'alternative, risky methods of hard run-ins', but don't feel like 'risking' it because their manuals tell them otherwise. So you see people saying "So now I've gotta stay below 3,500 revs for the first 100 miles" nonsense, then actually doing more harm to their engine than they could have.
A litre of oil every 1000 miles is disgusting and unnecessary.
SuziCat
PostPosted: 16:06 - 06 Oct 2007    Post subject: Reply with quote
I believe some bike engines can do high miles - no worries. Take for example the Yamaha Diversion 900. These engines are superb and can easily do over 100K. (I researched all this out before buying mine in 2003).
Even back in the 70's/80's the Suzuki GS bikes could also do similar high miles. Regular maintenance is the key I think.
If you want a decent winter bike, and no chain oiling to worry about the Diversion should be on your list. They really are good bikes (although a bit heavy)
Regular Rides:- BMW R1200R, Triumph Street Triple
Summer Toys:- Yam Virago 1100, Suzuki GS750 (1979)
PostPosted: 17:12 - 06 Oct 2007    Post subject: Reply with quote
It seems related to particular models of bikes too, like Daytona 675' have got a reputation lately for being an oil drinker. Early R1's like a sup too.
PostPosted: 19:28 - 06 Oct 2007    Post subject: Reply with quote
Litre of oil every 1000 miles is a hell of a lot, but regarded as the limit for acceptable.
Seems to vary greatly. For example the early FZ750 used virtually no oil but later ones (and the FZR1000 did). They changed to slipper pistons for the later ones.
The old 8 valve GS engines were very long lasting. From memory they used roller bearings on the crank, hence didn't care nearly so much about oil quality or pressure.
Suzuki screwed up a few years ago on the Bandit 1200 and released a batch with the oil holes in the pistons drilled in the wrong place. Very excessive oil consumption.
panrider_uk
PostPosted: 21:21 - 06 Oct 2007    Post subject: Reply with quote
Surely a bike that drinks oil is unacceptable and has a problem?
I thought only a 2-stroke should use oil and 4-strokes should lose very little unless there's a problem?
Mark
instigator
PostPosted: 21:47 - 06 Oct 2007    Post subject: Re: Scared of High Mileage Reply with quote
Chriss
I just bought a CB500 with 43k on the clocks. Just spotted a 95 Gpz500s in the local shop with 46k on it for £650 ono. Would have had that instead if I saw it sooner. Mad
Chriss
PostPosted: 22:08 - 06 Oct 2007    Post subject: Reply with quote
See, the owner of the GPZ before me was a BCFer, who definately knows quite a bit about bikes, and before him was a bloke who had it serviced by Kawasaki up until about 30k miles!
Is the best way to look at it that it's a bit of hit and miss? You can try look out for the best things, but there's no sure way? I'd certainly expect my SV to last to 100k miles or so...
PostPosted: 22:12 - 06 Oct 2007    Post subject: Reply with quote
The 1 litre every 1000 miles off is the limit of what is acceptable. Plenty of cars burn a load (VWs are infamous for doing so for the first 10000 miles or so)
Any 4 stroke will burn oil, just hopefully only a tiny amount that will not be noticed.
But did he jump on the bike in the morning and whack the choke on full then leave it idling for a while? With a typical Kawasaki that would put the revs through the roof while dumping a load of fuel down the bores and washing the oil off.
If they still have the TL gearbox then expect a few gearbox rebuilds in that time.
instigator
PostPosted: 22:13 - 06 Oct 2007    Post subject: Reply with quote
To me a service history means sweet fuck all apart from bikes like a ducati where the servicing is vital and tell tale. I would give it a test ride and see how it performs. What year of gpz is it out of interest? I don't consider the engine on the gpz to be a strong as the CB500 to be honest, comparing the number of problems I've heard. Still a reliable bike though. Mind and check the bits that will be checked in the MOT. My MOT is up in a months time and I have the sneaking suspicion that the headbearings are fooked. Either that or the wheel bearings. And I can't be bothered to do either jobs. Evil or Very Mad
Chriss
PostPosted: 22:28 - 06 Oct 2007    Post subject: Reply with quote
It was an 1994 model, but the newer shape. Test rode it first, from jumping from a k3 GS500 to the GPZ, the GPZ felt much stronger. I think this is all part of what's spooked me, everything felt so good, the only down side to the GPZ was the rear end was spongy as hell. But it also looked like the original shock..
Timmeh
PostPosted: 23:19 - 06 Oct 2007    Post subject: Reply with quote
My CBR's done 58,000 miles and only burns a teeny bit, like half a litre every 3,000 miles, which ain't bad.
Having said that, I'm religious about letting it idle for a few minutes before pulling away, and even then I don't go above 7,000 rpm until the temperature gauge's out of the blue.
sickpup
Old Timer
PostPosted: 00:25 - 07 Oct 2007    Post subject: Reply with quote
The ER-5 I use for work ended up needing a new head, barrels and pistons at 49k and I know that was well serviced as I had done most of it for the previous 20k.
Not got a lot of respect for these GPZ engines, they often seem to need a lot of work and rattle like a bag of nails.
bish777
PostPosted: 02:44 - 07 Oct 2007    Post subject: Reply with quote
Ive generally found that the larger the motor the longer it last simply because you spend less time revving the balls off of em.
My FJ1200 racked up 30k, going from 50 to 80 thousandish without any issues. That motor barely left tickover in anything than motorway use.
GSXR1100J
tatters
Exxon Valdez
PostPosted: 04:26 - 07 Oct 2007    Post subject: Reply with quote
My old GT550 had done around 150,000 at a guess and my current VFR750F has 70,000 on the clocks and still runs great plus burns no oil, although l,ve had to replace the rear shock/ exhaust system and fork bushes Thumbs Up
PostPosted: 17:50 - 07 Oct 2007    Post subject: Reply with quote
I don't go over 3k on my Hornet until it's out of the blue, same motor. Thumbs Up
kitty kat
PostPosted: 18:05 - 07 Oct 2007    Post subject: Reply with quote
I ride a MK1 Fazer 600 38000 on clock, 25 000 done in 12 months and the only time it has had oil put in it is during an oil change
panrider_uk
PostPosted: 18:32 - 07 Oct 2007    Post subject: Reply with quote
Up to the individual of course, but any vehicle of mine that consumed oil would be repaired or got rid of.
Mark
The last post was made 18 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 136.54 Kb
