Need help on a GSX-R400RFK (GK73A) CDI
charisp
PostPosted: 22:24 - 06 Oct 2007    Post subject: Need help on a GSX-R400RFK (GK73A) CDI Reply with quote
Hi to all,
i own a gsx-r400rfk (GK73A). The bike has been idle for a year or so and recently i remembered the good old days we had together(missed her a lot to be honest) so i decided to get it started again.
I cleaned the carbs, bought new battery and sparks but the bike refused to start(this was one of the reasons the bike was idle for so long).
I noticed that the sparks where not firing... I had a gut feeling that there might be something wrong with the CDI so I openned the box and found that the board was damaged(no idea what might have caused it).
Here is a pic of the board
https://img216.imageshack.us/img216/7081/picture067tr2.jpg
As you see there are two components missing(circled in red).
I would be very grateful if somebody could send me a picture of the CDI(part no 32900-32C10) where these components and their ratings are clearly shown.
A circuit diagram would do the job as well.
Also if somebody has the workshop manual for this bike let me know.(I have a japanese version-not very helpful i must say)
Any tip will be much appreciated
Ichy
PostPosted: 22:37 - 06 Oct 2007    Post subject: Reply with quote
I'm struggling to understand how they are missing? The bike was running before. You opened the CDI. The CDI is designed to be waterproof. So how did the bits disappear? If the solder failed they should still of been in the box. Is it just a guess that they are missing? Some boards are designed with solder points that have no components.
There's is no way that you will get your hands on a wiring diagram for the CDI. They are supplied as black boxes to the assembly plant.
Timmeh
PostPosted: 22:45 - 06 Oct 2007    Post subject: Reply with quote
Like Itchy says, CDIs are utterly non-servicable. They either work or they don't.
You can check its function by measuring the resistance across some of the terminals; although being an imporft they're no haynes manua, and finding the figures that ain't in japanese might be difficult.
If there's no spark, it could be any number of things. I'd start first with the HT leads and trace your way back through the wiring.
It could just be a dud coil.
PostPosted: 22:49 - 06 Oct 2007    Post subject: Reply with quote
Think this might be needed:-
https://www.bigccracing.com/shop/product.asp?idproduct=214
charisp
PostPosted: 22:52 - 06 Oct 2007    Post subject: Reply with quote
The black box was not sealed as it might have been opened by the previous owner. As you see in the picture there was a fire which melt the componets(completely). There were some residues of them which i removed along with excess solder to check the board. Of course there might be other damaged components as well but i have to complete the puzzle in order to do this.
I must add here that i have some knowledge of electronics.
Timmeh
PostPosted: 22:56 - 06 Oct 2007    Post subject: Reply with quote
Well then you'll prolly realise that thermal stress would have burnt out the microprocessor.
Do what keith say, or buy another one.
Damage of this type is sometimes caused when the HT goes open-circuit; the voltage generated in the secondary coil of the choke doesn't go anywhere and it overheats and melts.
It's also worth while pointed out that the link to your pic is borken. Wink
charisp
PostPosted: 23:03 - 06 Oct 2007    Post subject: Reply with quote
Indeed there might be a chance that the microprocessor is dead. If not i think its worth the trouble fixing it rather than spending some £150 on a CDI.
Timmeh
PostPosted: 23:06 - 06 Oct 2007    Post subject: Reply with quote
well the chip concerend will be a pre-programmed PIC with the timing curve for that particular engine.
You will not be able to find one anywhere, except inside another unit.
It's a bummer, I know. Sad
charisp
PostPosted: 08:32 - 07 Oct 2007    Post subject: Reply with quote
Thanks for the tips guys, but before i buy the cdi (or sell the bike for spares) i will wait till something pops up.
You never know.Someone might have been there, probably has a picture like mine and willing to share Neutral
Ichy
PostPosted: 11:55 - 07 Oct 2007    Post subject: Reply with quote
In which case you already know that the board is marked up with the type of component that should be fitted at each solder point?
The one at the top is a diode, probably of the same type as the damaged one that is left. Can't see what's wrote in the middle. Those resistors look a bit rough as well.
Have you tried the owners club?
Andyco11
PostPosted: 13:53 - 07 Oct 2007    Post subject: Reply with quote
Well if you decide to sell it let me know how much and we might be able to do a deal
XS250 Special - XS250 US Custom - XS250 Special Jap Import with YICS Engine
The Florida Forum
Caft Dunt
PostPosted: 15:31 - 07 Oct 2007    Post subject: Reply with quote
check part no on d2, probably same as d1, replace them both. can you identify the colour codes for r9? replace it. check coil drive transistors ig 1 and 2 for short circuit using a dvm on diode test part no 2sd1976. chances are the processor is ok it should be well isolated from the drive stages. follow the traces leading to all those components and look for open circuit resistors and short circuit semiconductors. before testing check the bikes wiring for what caused the failure in the first place.
failing that i`ll swap you the bike for an O2 XDA and some merc alloys? Wink
charisp
PostPosted: 07:02 - 08 Oct 2007    Post subject: Reply with quote
Thanks for the tip Gaf Dunt.
I also suspected that the second diode could be the same as the first one. There where,though, traces of a component positioned in the middle of the diodes which melted and destroyed the board(No idea what might that be).
The problem might have been caused by the coils. I checked them and found that the primary coil connected to the cdi was ok whereas the secondary coil was damaged. This must have overheated the cdi as electricity from the primary coil has nowhere to go Crying or Very sad
If anyone is interested for the cdi contact me on email
The last post was made 18 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 84.06 Kb
