Help! Yamaha Aerox YQ50 Exhaust Advice Needed!
bigdoc1991
PostPosted: 23:12 - 06 Oct 2007    Post subject: Help! Yamaha Aerox YQ50 Exhaust Advice Needed! Reply with quote
Hi. I've just bought a Leo Vince ZX Hand-Made Exhaust for my ped and it fits but on the standard pipe there is two holes: 1 is the main pipe the 2nd is another smaller pipe which leads back into the crank case.On the Leo Vince exhaust there is no second hole for it? Do i just leave it off or cover it up? Help please!
Thanks
Andy Very Happy
Welshd1k
PostPosted: 23:14 - 06 Oct 2007    Post subject: Reply with quote
second oen have a rubber hose? comes off the bottom bend? is fo thet is no longer needed (thats some form of restrictor cut it and weld it on a stock pipe for more power.)
bigdoc1991
PostPosted: 23:26 - 06 Oct 2007    Post subject: Reply with quote
Yes is it a second rubber hose. I've explained to my dad (whos a mechanic) that if that is removed then the restriction on the exhaust is removed but he isnt convinced. He thinks it will spew up exhaust fumes and oil Confused
Welshd1k
PostPosted: 23:28 - 06 Oct 2007    Post subject: Reply with quote
nope thats the restrictor look on most web pages for derestriction it shows that pipe on the stock pipes being clamped and welded shut
PostPosted: 01:06 - 07 Oct 2007    Post subject: Reply with quote
Im not convinced.
If the second pipe is metal then it probably will be the restrictor pipe,but this metal pipe would not attach to the crank case,it would be a closed end.
If the pipe is rubber i would have thought it was a crank case breather pipe.That would go from the crank case to the exhaust (although i thought they went to the air intake side not exhaust?)
anyway in answer to your question:
If its a rubber pipe the i think most people replace it with a small k&n style filter...
Oh and it wouldnt spew up exhaust fumes,just oil vapour Thumbs Up
HTH
dave
DRZ-400sm
rezzin
PostPosted: 11:59 - 07 Oct 2007    Post subject: Reply with quote
Im pretty sure its something to do with the catalytic converter malarkey? Most people just cut it off and crimp the end over,or patch over it with weld or whatever. Taking it off wont harm anything. Thumbs Up
Caft Dunt
PostPosted: 15:44 - 07 Oct 2007    Post subject: Reply with quote
will probably be either for EGR or secondary air injection. seal it and forget about it i reckon
The last post was made 18 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 49.77 Kb
