New Headlight?
zaknafien
PostPosted: 15:21 - 24 Nov 2003    Post subject: New Headlight? Reply with quote
Ok after much riding in the shitty weather down country lanes with no lights i've come to the conclusion that the cats headlight is about as useless as an australian at rugby.
If i got a more powerful bulb would i have to change anything else? or would it be ok just getting a new bulb?
02 Firestorm.
McJamweasel
BCF Junkie
PostPosted: 15:22 - 24 Nov 2003    Post subject: Re: New Headlight? Reply with quote
zaknafien wrote:
...about as useless as an australian at rugby.
Kris
PostPosted: 15:24 - 24 Nov 2003    Post subject: Reply with quote
You mean you want a higher wattage normal bulb, or a Phillips blue type one?
www.prisonplanet.com
zaknafien
PostPosted: 15:25 - 24 Nov 2003    Post subject: Reply with quote
Anything aslong as it's stronger than the current one.
02 Firestorm.
Kris
PostPosted: 15:29 - 24 Nov 2003    Post subject: Reply with quote
Whats the wattage of your current bulbs?
Scotty
Scooter Boi
PostPosted: 15:30 - 24 Nov 2003    Post subject: Reply with quote
Pats shiny phillipd blue lights in trusty shiny headlight.
And it works too you know!
Even with my bodge electrics and through clips Very Happy
Regards
Scott
Kris
PostPosted: 15:31 - 24 Nov 2003    Post subject: Reply with quote
wtf? In English please mate Razz
PostPosted: 15:39 - 24 Nov 2003    Post subject: Re: New Headlight? Reply with quote
What is Rugby?
Depends on the bike and the wiring. You can get higher wattage headlight bulbs but they are not legal on a bike that new (limit is 60w, but that is power consumption, not the amount of light). There are better bulbs available, but there are also plenty which are just there to have a slightly blue tinge and look "good".
If you go for a higher wattage bulb then you stand a chance of melting the wiring. You would be best off wiring the headlight up with a couple of relays. Most bikes pull the entire power through the ignition switch and the wiring on that can burn out (has happened to me on the FZ750).
Also if the larger bulb is hotter you stand a chance of melting the actual headlight (probably not that likely though).
Scotty
Scooter Boi
PostPosted: 15:39 - 24 Nov 2003    Post subject: Reply with quote
You mean you don't understand my scotty talk.
How dare you not know it,
For this you will be dragged into the deepest darkest regions of hell,
and poked for all eternity by little devil men dressed up in kwak green leathers.
Regards
Scott
Kris
PostPosted: 15:41 - 24 Nov 2003    Post subject: Reply with quote
now that's just plain nasty Sad
The last post was made 22 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 66.41 Kb
