sppedfight reverses doesnt go forward
genchie1
PostPosted: 17:09 - 07 Oct 2007    Post subject: sppedfight reverses doesnt go forward Reply with quote
hi there heres a gd 1 for you why would a speedfight go backwards instead of forward
i have changed engine but i know it worked before i put it in
i have also change the cdi for the aftermarket 1 because my immobiliser keeped coming on and i didnt have red key Sad
sickpup
Old Timer
PostPosted: 17:14 - 07 Oct 2007    Post subject: Reply with quote
The timing is too advanced. Retard it and it will run in the correct way.
st3v3
PostPosted: 17:17 - 07 Oct 2007    Post subject: Reply with quote
Usin da txt speak dunt 'elp, Please type properly. Thumbs Up
I think you need to switch your throttle cable ends round. Smile
rezzin
PostPosted: 17:36 - 07 Oct 2007    Post subject: Reply with quote
St3v3 to be fair he didnt really use 't3xt' speek. Wink But i see where your coming from bruv Thumbs Up Weird issue to be reversing,im sure someone on here had the same problem a while back,maybe have a look and try and pick up some info from that. Good luck.
genchie1
PostPosted: 18:49 - 07 Oct 2007    Post subject: Reply with quote
hi there sorry about text talk im to used to msn could you tell me what retard it means thanks
bugsy46
Village Idiot
PostPosted: 20:46 - 07 Oct 2007    Post subject: Reply with quote
Maybe his kickstart is sending the engine backwards ie similar to bumping a bike backwards!! Retard means make it spark later
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
sickpup
Old Timer
PostPosted: 21:15 - 07 Oct 2007    Post subject: Reply with quote
Unlikely unless he has fitted the kickstart the wrong way around and broken off all the gear stops.
Damn this is BCF isn't it, did you do the above? Wink
genchie1
PostPosted: 22:21 - 07 Oct 2007    Post subject: Reply with quote
i havent touched the kick start i have mucked about with the engine when i kick it,
it goes the right way round but when it starts it goes the wrong way,
if retard mean make it spark later how do i do that
Cigaro
PostPosted: 12:04 - 08 Oct 2007    Post subject: Reply with quote
Sounds like a result of you changing the CDI.
Isn't the timing fixed on modern CDI's? Did you defnitely get the right one?
genchie1
PostPosted: 13:35 - 08 Oct 2007    Post subject: Reply with quote
yea it is the cdi its not the correct one although it fits its not the right one thanks everyone for your replys Thumbs Up
The last post was made 18 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 62.34 Kb
