Engine Weights
loomesy
PostPosted: 17:30 - 06 Oct 2007    Post subject: Engine Weights Reply with quote
Hello,
Im interested to know how much the following engines weigh. This is for a university project, whereby we will be possibly using one of these engines on an integrated type racing hovercraft, so basically the lighter the better. OK here goes
Aprilia 450 V-Twin
Honda vfr400
Honda cbr400
Kawasaki gpz500
Kawasaki ZXR400
Suzuki DRZ400
Suzuki GS500
Yamaha YZ450
If any of you guys have Haynes manuals, i think engine weights are in there.
Thanks for your help. Also any other engine suggestions welcome, up to 500CC
Loomesy
halo123.
PostPosted: 14:28 - 08 Oct 2007    Post subject: Reply with quote
Hi maybe its here
https://www.motorcyclespecs.co.za/
The Haynes i have doesent list the engine weight just the whole bike (gs500)
Halo123. =Techie/geek and bike rider Wink ,
current bikes owned ,fix me upper gs 500e missing cdi
cbr 250 virgin colours
Robby
Dirty Old Man
PostPosted: 14:41 - 08 Oct 2007    Post subject: Reply with quote
The aprilia 450 and the two singles listed there should be by far the lightest.
Any of the four cylinder engines will be heaviest.
If you want a decent power/weight ratio you should go for a 2 stroke engine. A fair few of the dirtbike 2 stroke singles have magnesium alloy casings, single carbs, and fairly lightweight gearboxes. I assume you want to junk the gearbox anyway, so you may be better off looking at paramotor engines - 2 stroke, decent specific output, very lightweight.
PostPosted: 15:40 - 08 Oct 2007    Post subject: Re: Engine Weights Reply with quote
I'd expect the Yamaha would be the lightest, followed by the Aprilia, then the DRZ. I'd expect the 400 il4s will all be about the same and the 500 twins the same, but not sure which is heavier out of the two.
As it's for something that won't be tilting much a dry sump maybe an advantage, as the oil can slosh about a bit in a wet sump.
The DRZ has a dry sump I believe, not sure about the others (oil nomrally stored in the frame.)
Reliabilty and servicing is also worth considering - the Aprilia engine probably makes about as much power as any of the others, but is quite expensive to keep running.
I'd be tempted to look at a 250-500cc mx or enduro 2 stroke, as these should be not too heavy and have at least simple maintenance.
PostPosted: 15:52 - 08 Oct 2007    Post subject: Reply with quote
Most of the hovercraft kits I've seen use a TZR250 2MA engine, which is a two stroke, makes about 50bhp and weighs bog all.
loomesy
PostPosted: 14:34 - 09 Oct 2007    Post subject: Reply with quote
Cool cheers for the help
Yeh sorry i shouldve mentioned no 2 strokes, which makes it hard to get a comparable amount of performance and weight.
Loomesy
The last post was made 18 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 47.51 Kb
