Xs250 Cuts Out When Hot And Leaks Petrol Through Air Filter?
Jamie S
PostPosted: 13:52 - 09 Oct 2007    Post subject: Xs250 Cuts Out When Hot And Leaks Petrol Through Air Filter? Reply with quote
Hi , the Xs250 is all back together and running after having new piston rings , any way the bike cuts out when hot ( used to do this before the rings were done) any idea what it could be ?
The bike runs fine for 20 or so miles then cuts out and refuses to start ,if we leave it 30 mins or so it will fire straight back up , any ideas what it could be??
(I'm thinking something electrical braking down when hot ?)
Also fuel is leaking out of the air filters when the bike is stationary (both air filters), so I stripped the carbs down and gave them all a good clean out but it still does it , it never used to do this before the rebuild.
Any help much appreciated.
Jstokes.
Thumbs Up Karma
halo123.
PostPosted: 14:18 - 09 Oct 2007    Post subject: Reply with quote
hi jamie
I would suggest check that you have the correct sparkplugs.
For extended use as my gs did same put in new plugs and problem gone.
Cause its like it over heats plug, not the correct heat range or some thing.
edit
check here
https://www.ngkspark.com.au/part_index.htm?https://www.ngkspark.com.au/PartFinder/spark_plug_vehicle_type.php
YAMAHA 250cc XS250PK/SK/R
Spark Plug Part No. Plug Gap
Recommended Plug D8EA 0.7
Iridium Option DR8EIX 0.7
or
YAMAHA 250cc XS250/C/H/RH/SE/SH
Recommended Plug BP7ES 0.8
Iridium Option BPR7EIX 0.8
Halo123. =Techie/geek and bike rider Wink ,
current bikes owned ,fix me upper gs 500e missing cdi
cbr 250 virgin colours
Nath
PostPosted: 14:54 - 09 Oct 2007    Post subject: Reply with quote
Check your float valves are sealing shut. Take the float bowls off one at a time, and hold the floats up whilst turning on the petrol. When you let the float drop petrol should start coming out, and stop flowing when you lift the float again. If both the floats are working fine you might have to adjust the heights. Could also be a punctured float.
When the bike cuts out, is it at normal running temperiture, or is overheating and running like a bastard and then stalling?
Hard livin', hard luck.
Andyco11
PostPosted: 15:06 - 09 Oct 2007    Post subject: Re: Xs250 Cuts Out When Hot And Leaks Petrol Through Air Fil Reply with quote
Could also be the vacuum advance on the fuel tap mine are always getting holes in them
Thumbs Up Karma
You have connected the vacuum advance and fuel line back up the correct way
XS250 Special - XS250 US Custom - XS250 Special Jap Import with YICS Engine
The Florida Forum
Paddy Blake
PostPosted: 16:41 - 09 Oct 2007    Post subject: Reply with quote
When the bike stops open the petrol cap and if it sucks in air then the
breather in the cap or tank is blocked.
Check if there is a spark as the coil can stop for a while when hot and
work again when it cools down.
Paddy.
Jamie S
PostPosted: 17:27 - 09 Oct 2007    Post subject: Reply with quote
There is a really week spark when it cuts out.
Checked the tank breather and that is ok and does not suck air in when opened.
Never heard of a vacuum advance ? Bear in mind this is a 1980s bike.
When the bike cuts out, is it at normal running temperature, or is overheating and running like a bastard and then stalling?
If going along nice flat road with no junctions it will run fine and not cut out.
But with it only being a little 250 and going 2up it has a tendency to stall at junctions , this is when it won't restart , but it only does this when hot if you know what I mean ?
I will check the spark plug number later but IIRC it is D8EA.
Cheers.
Jamie S
PostPosted: 17:33 - 09 Oct 2007    Post subject: Reply with quote
Paddy Blake wrote:
Check if there is a spark as the coil can stop for a while when hot and work again when it cools down.
Paddy.
Hi paddy does this mean that the coils are nackerd then ?
I'm not going to spend £30 on a new set if it is. Confused
The bike is being sold at the end of the month and is only worth £100 , we are putting the CB750 on the road for the 1st of November you see.
Paddy Blake
PostPosted: 17:42 - 09 Oct 2007    Post subject: Reply with quote
Hi Jamie.
Well if it is the coils then you could match some second hand ones off
many different bikes.
A lot off bikes will take a good few different types of coils.
I have stuck the CG one on a few bikes.
Paddy.
MaybeGuy
PostPosted: 18:04 - 09 Oct 2007    Post subject: Reply with quote
when it stalls, try push starting, see if that works...
Jamie S
PostPosted: 18:06 - 09 Oct 2007    Post subject: Reply with quote
Tried that an it didn't work. Sad
Andyco11
PostPosted: 18:25 - 09 Oct 2007    Post subject: Reply with quote
As far as i am aware All XS machines have a Vacuum activated Fuel tap
[img]https://i91.photobucket.com/albums/k298/andyco11/XSFuelVacumepipe.jpg[/img]
The Florida Forum
Andyco11
PostPosted: 18:29 - 09 Oct 2007    Post subject: Reply with quote
And if you are selling it PM me and maybe we can do a deal
The Florida Forum
Jamie S
Hum, the two inlet rubbers have a pipe linking them but I didn't think it had a vacuum fuel tap , could this cause the problems I'm having ?
Andyco11
PostPosted: 18:33 - 09 Oct 2007    Post subject: Reply with quote
The vacuum hose comes from the right hand (as you are siting on the bike) inlet and pushes on to the back of the fuel tap.
Could be your problem if not connected as it need the vacuum to suck open the membrane in the tap to allow full flow of fuel.
The Florida Forum
Jamie S
PostPosted: 21:21 - 09 Oct 2007    Post subject: Reply with quote
The rubber hose off the rh inlet is connected to the lh inlet.
There is only one pipe that comes from the petrol tap.
sickpup
Old Timer
PostPosted: 11:42 - 10 Oct 2007    Post subject: Reply with quote
If it still has the original points ignition when was the last time the two condensors were changed?
Jamie S
PostPosted: 12:20 - 10 Oct 2007    Post subject: Reply with quote
sickpup wrote:
If it still has the original points ignition when was the last time the two condensers were changed?
If I'm honest mate I haven't a clue about when the point's were last changed but it still runs on points, the bikes done 28k and was stood for around 5 years before I bought it , but for a while the bike ran nice then after a few months developed these problems.
Caft Dunt
PostPosted: 13:23 - 10 Oct 2007    Post subject: Reply with quote
have you checked the points gap? sounds like theyre closing up when warm. where are you btw might be interested wher your selling it
Jamie S
PostPosted: 13:28 - 10 Oct 2007    Post subject: Reply with quote
Hi , Yea set the points gap a few time's , I'm In Flintshire North East Wales , Practically on the English border.
Jamie S
PostPosted: 16:39 - 10 Oct 2007    Post subject: Reply with quote
It seems the bike is sold to Andyco11, cheers for your help guys.
Jamie S
PostPosted: 14:00 - 13 Oct 2007    Post subject: Reply with quote
The bike went today. Smile
Thanks Andyco11, hope she brings you as much fun as we had with her.
Andyco11
PostPosted: 16:02 - 13 Oct 2007    Post subject: Reply with quote
Thanks dude
No-doubt i will be giving it a good kicking later Laughing
The Florida Forum
There is a gap of 5 years, 34 days between these two posts...
oz spudgun
PostPosted: 17:13 - 14 Nov 2012    Post subject: xs250 Carbies leak, Flooding, only runs for a while Reply with quote
I just bought an 1980 xs 250 in OZ and its been giving me a bit, Anyway I noticed that there is meant to be a vacuum pipe connected to the rh carb inlet rubber brass port. As mine didn't have this I have been having all kinds of trouble keeping it running fro more than 5 mins. It floods. I changed the petcock rubbers and all but it still flows a bit when ON position. I am quite excited about this believe me its past 3am. It must be whats wrong because everything else has been checked fifty times. Thanks in advance I'll let you know how I go.
sometimes i fly others i slide
bikenut
PostPosted: 11:38 - 15 Nov 2012    Post subject: Reply with quote
want some spares for this bike, rods with pistons and rings ( little ends worn out as well as crank )), g/box parts, side panels, tank, seat, some electrics and other bits.
alloy wheels and rear disc/swing arm going on the rd250.
north wales.
The last post was made 13 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 129.5 Kb
