| jimbothe |
 jimbothe World Chat Champion
 Posted: 22:03 - 08 Oct 2007 Post subject: Can anyone explain to me..... |
The difference in ride between the inline four and a twin.
Some of you may already know that im in the market for a new bike and have found a few nice examples but they are all hundreds of miles away. The two main contenders are the Yamaha Thunderace and the Suzuki TL1000R.
From what I can tell the Thunderace is more powerful but is it faster? (I heard the TL has a tremendous amount of torque...)
I currently own two in line four 16v so I know what they ride like but didnt want to commit to a twin until I had some advice. Just my luck no garage has a TL in for me to try  ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| G |
 G The Voice of Reason
 Posted: 22:17 - 08 Oct 2007 Post subject: Re: Can anyone explain to me..... |
One has two cylinders in a v shape, the other has four in a line.
First off, people often say 'torque' when they mean 'range of torque'.
Secondly it's a bit of a myth that a v-twin has a wider range of torque than an inline 4.
Firstly, people often compare smaller capacity four cylinder bikes - for instance 750cc against 1000cc twins, or even 600cc fours against the big twins in some case (they often have similar peak power outputs).
Secondly people feel a large midrange but little top end and presume the bike has a more midrange torque. Often this isn't the case and the four cylinder bike makes a similar midrange, but has a load more go on top of that.
The TL-R will probably handle corners a bit better than the thunderace. The TL had one of the better twin engines of the time, but the R versions got the ones in a lower state of tune.
What current bikes do you own? If you haven't ridden a litre bike, you may find it's a fair bit different even if you get a four.
I should add that v-twins have a 'big bang' firing order, which gives the possibility of very slightly more grip exiting corners. Personally, I think the extra it offers probably isn't usable by anyone but a top superclub racer or better, if that.
Oh and they sound like wet farts . |
| jimbothe |
 Posted: 23:20 - 08 Oct 2007 Post subject: |
Hi G,
I own a Ninja zx10 b3 and a FJ1200, both inline fours. Would the TL feel or be faster than these? (speed isnt a great issue, more torque and acceleration)
Is there any particular riding styles you have to adapt going from a inline fours to v twins?
I know both the TL and Thunderace will benefit from being newer and probably better tuned but will it be an impressive difference over my existing two? ____________________ Check out our tackle shop on Facebook:
| G |
| jimbothe |
 Posted: 23:37 - 08 Oct 2007 Post subject: |
Ok G, thanks for that, it was very helpful.
I just hope I get the chance to try both when a garage near me finally gets one or both in.
Any other ideas for bikes in that range or power with a bit more sparkle? ____________________ Check out our tackle shop on Facebook:
| G |
| Kickstart |
 Kickstart The Oracle
| jimbothe |
 Posted: 23:45 - 08 Oct 2007 Post subject: |
Im a big lad G
the FJ and ZX size is suited to me making the ZX9 and R1 way too small
budget around 2k - 2.5k
Strangely enough the fireblade doesnt look too small as ive sat on one. The R1 is definately out as they are tiny on me ____________________ Check out our tackle shop on Facebook:
| BorderHooner |
 BorderHooner Could Be A Chat Bot
| G |
| killa |
 killa Won't Shut Up
| MarJay |
 MarJay But it's British!
 Posted: 11:46 - 09 Oct 2007 Post subject: |
As a person who prefers twins to fours, I feel compelled to comment here.
Its not just about peak power, or peak torque, but its about how the bike 'feels'.
I prefer twins because for the 70% of my riding which isn't full on mental blasting they are much much better. The midrange on a twin is still a few thousand revs fewer than the midrange on a four (most twins rev 6-10k and most fours rev 12 - 15k).
I personally dislike the power delivery of a four, it feels like its not doing anything, and to me that means that you end up riding faster than you intended. With a twin (particularly a V twin) you get to feel like the engine is actually expending some effort in getting you to a high speed when you thrash it. This means that you are probably travelling at the speed you think you are travelling at, rather than some function of the whine coming out of the exhaust. I suppose it is that you can 'feel' the engine, rather than a four where you have to look at the rev counter or listen to the noise it makes.
I would say the main disadvantage of a TL1000R is that they are very long, and have a very long wheelbase, and so aren't the fastest turning of bikes. Also, they rev to 10,000rpm and do so very smoothly, which means that they are almost like a four in their power delivery.
Personally, If I was looking at a big sportsbike of around 125bhp that weighs around 200kg dry then I'd be looking for a Triumph Daytona 955i.
Has the revs and the smoothness of a lower revving four, with the midrange and the feel of a twin. Makes around 120bhp ish and weighs 199kg dry. It probably won't be as comfy as the ace, but will probably be on a par with the TL. Also They are very well built and rock solid mechanically. A friend of mine still has my old one, and it looks like it just rolled out of the showroom, despite having done 30k miles plus. And they are very cheap at the moment.
a long link
The bike above is newer and lower mileage than the Thunderraces I searched for on AutoTrader. And the closest TLR I could find had done 12000 miles and was £2500.
For some reason, the 'trader seems to insist on calling them all T595 Daytonas, when Triumph actually changed the name as it was confusing. I think the 1997 ones were called T595, and the 1998 on were called 955i, but they are effectively the same bike. Personally I'd go for a '98 onwards as they have a slightly better frame and a slightly better exhaust routing which means the pipes don't deck out under hard cornering. Mine handled really nicely, and although it wasnt super quick on turn in, it had rock solid stability and felt great. I had to sell mine as it was physically a bit too big for me, and I was concerned about my license. But as I said, if I wanted that type of bike again, I wouldn't hesitiate to buy another 955i.
Another option, of course, if you're looking for more comfort is the Sprint RS:
a long link
This one seems a particular bargain, with a bulletproof engine and great comfort. They don't handle quite as well as the 955i, but are probably a good match for the Thunderrace for sports touring ability. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| G |
 Posted: 12:23 - 09 Oct 2007 Post subject: |
I’m feeling the need to get out my infamous R1 vs SP graph .
Often rev-for-rev the twin will have less torque in the midrange than a four. Even less if you compare it on a mph basis with two gears that have the same top speed.
So, presuming you’re comparing a bike of similar cc rather than similar peak power (which we are in this case), this leads me back to a major factor in this ‘feel’ to be the sound – something which as I’ve said before, I think is remarkably like smell in relation to taste. While it may not directly effect what forces are dragging your body along (or your tounge tastes), it does seem to make a fair bit of difference on how your body interprets those forces.
I would suggest that the feeling that the twin is ‘expending some effort’ is more down to a twin having less power, than it being a twin it’s self.
Riding a twin and a four with similar peak power (say ZX6 and firestorm, which I’ve done a few times back-to-back); to most people it feels like you’ve got to work the four a lot more.
A bike with more power overall will mean you have to work the bike less, so on a twin and a four of the same cc, I would expect to have to work the twin more for the same effect. Precisely the reason I bought myself a bike with 37hp, so I could feel like I was making the bike do something .
I’ve found the TL-R to be a bit lumpy low down, as most sports twins seem to be. ‘Commuter twins’ like the SV650 tend to be a fair bit smoother, as do commuter fours and the like .
Most litre sports twins rev to around 10k rpm from what I remember (the 1098 is 10700rpm, for instance, I believe).
Personally I’ve found I have to pay much more attention to ‘feeling’ what a twin engined bike is doing, while the sound of a four along with it’s top end rush means it’s much easier for my body to work out when it’s on song or not without thought. |
| jimbothe |
| G |
| jimbothe |
| MarJay |
| Kickstart |
 Posted: 13:42 - 09 Oct 2007 Post subject: |
| G wrote: | Often rev-for-rev the twin will have less torque in the midrange than a four. Even less if you compare it on a mph basis with two gears that have the same top speed. |
Possiby true.
What I definatly haven't seen is a graph comparing power on various throttle openings between twins and 4s
| G wrote: | A bike with more power overall will mean you have to work the bike less |
If you are at the level where it is producing its peak power then yes.
| G wrote: | Personally I’ve found I have to pay much more attention to ‘feeling’ what a twin engined bike is doing, while the sound of a four along with it’s top end rush means it’s much easier for my body to work out when it’s on song or not without thought. |
But the with the bike which doesn't have the top end rush there is far less need to be that careful with what it is doing to get decent performance. Get it wrong on something where the mid range is only a bit worse than the top end and it makes no difference. Get it wrong with something which has stuff all mid range compared to the top end you were aiming at and you go nowhere.
You are a fairly good club racer. Speed wise that probably puts you well into the top 1% of riders speed wise. Most riders are probably rarely going to the red, let alone spending their entire timing trying to stay within 1~2k of it, and when they try they just land up screwing up their smoothness, loosing far more than they gain.
For most the fact that you are revving the 4 harder, and that for each turn of the crank it is firing twice as many times, the 4 will feel more buzzy and thrashed, while the twin at the same speed will feel more relaxed. Try riding something like a 900SS Ducati (not a powerful bike by any stretch of the imagination, peak power similar to a 600 Bandit), and it is incredibly easy to go at a decent rate of knots. Lob it into top and just use the throttle to control your speed. Most of the performance is a doddle to use. Sure a Bandit might have the same power but to get the same performance means a lot more effort.
Sure you can gear the 4 lower so that it has the same shove in the mid range , but then it just feels even buzzier so people will just sit in a higher gear.
Trouble is you will eventually get to the state of tune of the 60s race bikes (like the 60s Suzuki 125 which needed a 10 speed gearbox to keep on the boil), and then have something that 1~2 people can make work while everyone else goes nowhere (possibly we are already getting there with the current R6).
Reality is that most riders are rubbish and would be quicker on a bike that is ultimatly a slower vehicle, as long as they gained more flexibility.
| G |
| colin1 |
 colin1 Captain Safety
| G |
| colin1 |
| G |
| Kickstart |
| Pete. |
 Pete. Super Spammer
The last post was made 19 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
