| moonym20 |
 moonym20 Could Be A Chat Bot
 Posted: 10:49 - 26 Nov 2003 Post subject: NSR died....HELP |
I've had to run the bike without any front fairings for the past week
it rained yesterday and i got caught in it the bike ran fine on the way home but this morning when i was leaving for work I got it fired up touched the revs a minute later and it died.....no electrics.....lights, indicators, dash lights all work but when i hit the starter i get nothing it is deffinatly electrics....
i've checked the fuse next to the battery and thats fine, i've lifted the tank and the engine compartment seems ok with no damp i've checked the wires under the engine that leads to the (alternator??) and they seem ok.......can anybody offer any help....i gotta go to work and can't find the problem
any help would be great  ____________________ A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot  |
| Hex |
 Hex Party Boy
 Posted: 10:58 - 26 Nov 2003 Post subject: |
Desperate man's attempt at a solution, get a tin of WD40 and spray, spray like you've never sprayed before.
Does the bike bump start? It could be something is grounding somewhere but without looking I couldn't really say mate. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| G1_ |
 G1_ World Chat Champion
| Scotty |
 Scotty Scooter Boi
| moonym20 |
 Posted: 11:53 - 26 Nov 2003 Post subject: |
Thanks for the replys
tried bumpstarting it...no use
the battery is fine, as far as i know it aint flat, it was charged last week
it does look like somthing is grounding it
i've left it in a room with a heater to dry out....i'll then cover it in WD40 like Hex suggested and try to get it running again
thanks again ____________________ A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot  |
| Scotty |
 Scotty Scooter Boi
| Milo |
 Milo World Chat Champion
 Posted: 14:11 - 26 Nov 2003 Post subject: |
i had the same problem the other week with my XJ900, it was a loose battery connection. whenever i tried to run a large current (starting it) it jumped and lost the connection. ____________________ Shaft drives rule.  |
| Ste |
 Ste Not Work Safe
 Posted: 14:16 - 26 Nov 2003 Post subject: |
ZX6R isn't that keen on the rain. Whens its really wet, and I'm out for a while, the neutral light comes on Then when I indicate right, it flashes on and off in time with the indicators  |
| Scotty |
 Scotty Scooter Boi
 Posted: 15:04 - 26 Nov 2003 Post subject: |
You and your dodgy ZX6r,
Get a real bike, like a 15 year old 2 stroke 125
pats trusty NSR (as wing mirror falls off) ____________________ Regards
Scott |
| Milo |
 Posted: 16:28 - 26 Nov 2003 Post subject: |
on that note, mine's been misfiring in the wet and seems to not use all cylinders at low revs...though i think that's down to the gaffa tape covering up the spark plug caps... ____________________ Shaft drives rule.  |
| Ste |
 Ste Not Work Safe
| GFK |
 GFK Scooby Slapper
 Posted: 18:56 - 26 Nov 2003 Post subject: |
Don't suppose you accidentally hit the kill switch and didn't notice? Its easily done...
I did that once. Phoned the breakdown people and everything before I noticed.
I rang them back and told 'em "I've managed to get it started so I'm gonna try to ride it home".
| moonym20 |
 Posted: 22:11 - 26 Nov 2003 Post subject: |
It was the rain
after leaving it in a room with a heater for 6 hours I got it working again......no idea where the problem was but its sorted for now.....its now got WD40 on most of the exposed areas and i'll prolly have to fork out for some new fairings tomorrow
whlist i was farting around with that i noticed another problem
my rear brake master cylinder is shagged from the crash.....i guess when the break lever was jolted upwards it pushed the piston too far an shagged the seals....either way i got DOT4 making its way down the thread that links the break to the master cylinder.....would explain why my rear break is not as effective as it used to be
looks like i gota go fork out for another master cylinder now  ____________________ A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot  |
The last post was made 22 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
