Went shopping and bought...
P_J
PostPosted: 19:03 - 26 Nov 2003    Post subject: Went shopping and bought... Reply with quote
I originally went in to buy some heated grips after the stupidly cold morning we had the other day.
I saw that Hein Gericke do a 'store card'. Shocked Great I thought new stuff and I don't have to pay for it just yet Smile. Turned out you had to spend over £75. Not as easy as it sounds when you only want 1 thing, and that thing is £49.99.
The heated grips I bought took forever to fit because I was fecking about in the dark last night at about 6pm. It was well worth the hasstle though this morning. Toasty warm hands, and no frost bite Smile Highly recommended
I bought the wrap around the original grip ones. My hands felt a but stiff when I got home tonight though, anyone else have this problem?
I also bought some 35/35w bulbs. They are better on paper than the 25/25w ones I removed but they don't seem that much brighter in reality. It has been mentioned on here before that 45/45w ones are to hot? Is this true because I am tempted to go and buy some brighter ones.
To make up the £75 I found myself ordering a quick release connector thingy watsit for the fuel line. Anyone had any experience with these?
PJ
Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk
Sparks!
Sir Tart-a-lot
PostPosted: 19:06 - 26 Nov 2003    Post subject: Re: Went shopping and bought... Reply with quote
PJ
They are good yes, but are prone to perishing away!! so keep an eye on it .
PostPosted: 19:09 - 26 Nov 2003    Post subject: Re: Went shopping and bought... Reply with quote
I have got fairly small hands and I know that when I have ridden bikes with large grips my hands start to ache quite quickly. This is the reason why I have avoided buying those wrap around heated grips.
I have some normal ones at home to fit. Mind you I have had them since February. They would have been nice on Monday.
How were the ones you bought wired in? I am a bit dubious about powering them off the existing wiring as I would think they draw a fair amount of current. If I wired them directly to the battery I would, no doubt, forget to turn them off one day and then have a very flat battery. I will probably wire them up with a seperate relay.
Sparks!
Sir Tart-a-lot
PostPosted: 19:11 - 26 Nov 2003    Post subject: Reply with quote
Do the oxford hot hands come with a switch?
i'm thinking of getting some Embarassed but also don't want to have them on when i'm not at the bike or something. I think i'll wire them into the ignition somehow
Any ideas?
PostPosted: 19:17 - 26 Nov 2003    Post subject: Reply with quote
I am probably going to run a wire directly from the battery to a relay, and then feed the switch for the heated grips from the relay. I will then try and break into the wiring somewhere to provide a trigger for the relay when the ignition is turned on.
Zimma
Wheelie Junkie
PostPosted: 19:20 - 26 Nov 2003    Post subject: Reply with quote
Keith :- Being logical as usual! Smile
-Zimma
PostPosted: 19:26 - 26 Nov 2003    Post subject: Reply with quote
To be, or not to be. That, is illlogical captain. Wink
Sparks!
Sir Tart-a-lot
PostPosted: 19:49 - 26 Nov 2003    Post subject: Reply with quote
kickstart, why have a relay? just splice the grips directly into the power lead connecting to the ignition Wink
You could in theory splice it into any of the electrics wiring Wink as they should all be the same current ?? As there are no resistors in the wiring circuit from ignition switch through inidicators/lights etc
so, you should be able to connect the heated grips lead into one of the indicators wiring, then wire both of them (use a connector box!) and power them both!??!
Would that work as well as I think it will? Or not?
P_J
PostPosted: 19:51 - 26 Nov 2003    Post subject: Re: Went shopping and bought... Reply with quote
Kickstart wrote:
...How were the ones you bought wired in? I am a bit dubious about powering them off the existing wiring as I would think they draw a fair amount of current. If I wired them directly to the battery I would, no doubt, forget to turn them off one day and then have a very flat battery. I will probably wire them up with a seperate relay.
The Oxford "HotHands" connect with two wires to the battery. The guy in the shop said you could connect to the ignition but I thought it best to leave well alone. long wire connects from battery to the switch. The switch has a green LED (which is actually quite bright) so you would notice that the grips were still turned on at night but maybe not in the day. Two wires to the left, and two wires to the right grips. Not hard to fit at all, I just got myself pissed off while I was doing it. Backwards and forward to the house for stuff i'd forgotten etc, I would recommend doing it in the light though. Smile
https://homepage.ntlworld.com/highlander_pj/images/hot.jpg
Excuse the quality, this pic is only 2 x 1.5 inchs. Had to use Camcorder and Paint shop pro Smile
i'm thinking of getting some but also don't want to have them on when i'm not at the bike or something. I think i'll wire them into the ignition somehow
Any ideas?
They come with a switch, it does have a LED on it so you can tell when they are switched on. The switch is in a small moulding about 1 inch across. It is ment to go round the handlebar. I did not have room so at the moment it is tie wrapped to my yolk (oh yeah, you get 4 white tie wraps - wow) Smile
PJ
Only1PJ.co.uk
PostPosted: 19:55 - 26 Nov 2003    Post subject: Reply with quote
Not sure how much current the grips would pull, but it could easily exceed the rating of the wiring you are tapping into.
My old FZ750 had a 100/80 headlight bulb in for quite a while. The extra power of that (standard was a 60/55, so on high beam an extra 40w, which at 12V is just under 3.5 amps) melted the wiring the the ignition switch. This is not an uncommon problem with the FZ750, and probably shared with any other Yamaha with the same design of ignition switch.
I would not be surprised if the heated grips pull 5~10 amps, especially in the high power warm up mode. Doubt much of the wiring would take that much extra current passing through it.
PostPosted: 19:59 - 26 Nov 2003    Post subject: Reply with quote
Ah, 3 amp fuse. So that means they are pulling about 30w at a guess, more than one of the standard headlight bulbs on the NSR.
The other problem with a switch is kids playing with it. Not unknown for people to come back to their bike and find the suspension played with, and I would expect a switch that illuminates an LED to be even more attractive to kids.
P_J
PostPosted: 20:06 - 26 Nov 2003    Post subject: Reply with quote
Technical data on instruction sheet wrote:
12 Volts input (Max: 14.3 Volts)
Each over-grip: 1.3 amp - 15.6 Watts (Max 18.5 Watts)
I misread that in the shop! Did not realise it was so much!
If something is using a lot of power directly from the battery, could it affect the performance of the bike at all? I was blaming the poor acceleration of my bike on the way home, on that really fine misty rain that gets you soaking. Thought that might have affected something. Could it have been the grips?
PJ
Only1PJ.co.uk
P_J
PostPosted: 20:08 - 26 Nov 2003    Post subject: Reply with quote
What kind of Wattage can a bike battery give out (or have taken from it) before it gets tired?
PJ
Only1PJ.co.uk
Sparks!
Sir Tart-a-lot
PostPosted: 20:16 - 26 Nov 2003    Post subject: Reply with quote
bollocks I'm going to wire the grips to a seperate battery under the seat and re-charge the battery when needed.
Can't be arsed with draining my bikes battery when I forget to turn the switch off (which I will)...
I work for an electrical contractors so can get all the stuff for cheap (cough) free Wink
PostPosted: 20:21 - 26 Nov 2003    Post subject: Reply with quote
Depends on the bike. From memory the NSR alternator produces ~ 120 watts once at reasonable revs (but I may well be wrong there). 50w will go on the headlights (or 70w if you stick 35w bulbs in there), another 5 for the tail light (or 21 for the brake light), say another 10 for clock lights and side lights, plus indicators, power valve, coil and the like. With the 35w bulbs in the front the charging system could well get marginal (add that lot up along with the heated grips and you are running at over 110w probably).
It is possible that you had enough of a drain on the charging system that it was beginnning to struggle to provide sufficient power for the coil to generate a good spark or having problems powering the power valve motor, especially if you were running round town with the revs fairly low.
Think the NSR uses a 5aH battery (ie, basically 60w for an hour).
Sparks!
Sir Tart-a-lot
PostPosted: 20:25 - 26 Nov 2003    Post subject: Reply with quote
fit two batteries Wink
P_J
PostPosted: 20:41 - 26 Nov 2003    Post subject: Reply with quote
I'm struggling to think of a place I could wedge another battery into my NSR Smile
Might be able to fit a nice little 9V one in there somewhere. Smile
PJ
Only1PJ.co.uk
Robby
Dirty Old Man
PostPosted: 20:45 - 26 Nov 2003    Post subject: Reply with quote
Or you could probably get a more powerful (higher AH rating) battery of the same size. Won't stop you overloading the charging system, but will help if you do.
Milo
PostPosted: 20:47 - 26 Nov 2003    Post subject: Reply with quote
not that i've got an alarm...but if you could work out where to put your two wires you could connect it to that.
that charges it's own battery off of the bike's but doesn't let the bike's battery dip below a certain amount - just what's needed for this situation.
Is anyone good enough with electronics that could make a stand-alone circuit like that?
Shaft drives rule. Razz
PostPosted: 20:51 - 26 Nov 2003    Post subject: Reply with quote
Another option, although a bit crude, would be to wire it through a 2nd relay triggered to turn the current off when the brake light is illuminated. This way when you are sitting with the brakes on the heated grips would be turned off. Should minimise the current drain when the engine revs are low and the electrical system barely charging.
Sparks!
Sir Tart-a-lot
PostPosted: 20:52 - 26 Nov 2003    Post subject: Reply with quote
I will have a word with our electronics tech at work to see what he can come up with. I'd did thinking of fitting a second battery in parralel to the main battery to run the heated grips, but just wondered if that's defeating the object? As it will most likely cause the same current drop in the main battery, but still have a second?
Not sure if you can charge 2 batteries from an alternator anyway can you? not effectively??
Other option... fit second battery under seat or subframe somewhere to run heated grips/alarm blah blah, then fit to jack plugs on cables drill holes in plastics in suitable place (connecting to the battery) then you can simply plug an optimate or other charger directly into the jack plugs to charge the battery without having to take the battery out each time....
Phoenix
Twisted Firestarter
PostPosted: 20:58 - 26 Nov 2003    Post subject: Reply with quote
I wouldn't wire em into the ignition as if something goes wrong it could leave you rather stuck. I wired my Daytona grips into the headlights, my lights are 55w and so are the grips on warm up mode, but 15w on 'on' mode which is also quite useless. With the headlights u dont have to remember to turn them off as there is no power going through there when the ignition is off or your headlights are off.
PostPosted: 20:59 - 26 Nov 2003    Post subject: Reply with quote
Think you could fit a bigger battery, except there is barely room for the standard one on the NSR. You could run a 2nd battery in parallel and the charging system would probably manage this. However in both cases you are just delaying the inevitable.
Suspect if you used a 2nd 5aH standard battery it would only manage to power the heated grips for a couple of hours. Also it would likely have a short life if you ran the battery too low.
Sparks!
Sir Tart-a-lot
PostPosted: 21:02 - 26 Nov 2003    Post subject: Reply with quote
Did you just splice them straight in with through connectors Alex?
That's practically what I was planning to do (only more likely by a connection box through the indicator wiring). Do you notice any affect on your battery though?
Although any faults with your battery has to be down to that brilliant reg/rec you've got! Laughing
Milo
PostPosted: 21:32 - 26 Nov 2003    Post subject: Reply with quote
with a second battery wired in to the altenator it would keep charging the extra battery (if it needed it or not) if the primary battery needed it. so if it gets full and the primary is charging then it'll bubble over.
wiring it into the headlights would cause similar problem to the wiring - it could easily melt it.
2nd seperate battery sounds like the best plan but then there's the hassle of charging it. i park on the road so it wouldn't be an option for me, unless you had a bumbag with a few batterys in that you could easily charge
hmm, radio controlled car battery's produce 14Vish from memory and quick charge in 30 mins. a couple of them on you for the way there and for the way home would probably do the job - though i don't know how long they'd last on the higher-power warm up mode.
maybe a few of these gaffa taped together and wired in series (or is it paralell?) to give the same voltage but would make them last longer. sounds easy to me.
just have a optimate type connector on both and it'd be a cinch.
anyone got some to tell us the voltage and amp/hour rating?
The last post was made 22 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 144.69 Kb
