Removing stuck bolts...
TiN
Pocket Tin
PostPosted: 21:49 - 02 Jun 2002    Post subject: Removing stuck bolts... Reply with quote
I was trying to remove the end can of my RVF today (just for, er, research purposes, honest!), but there were two b@stard "torx" bolts that seem to be jammed to solid...
...I have tried copious amounts of WD40 but to no avail...is there any other stuff that I can try?
Cheers,
Tin
PostPosted: 22:02 - 02 Jun 2002    Post subject: Reply with quote
I hate torx bolt, but then that is probably because the only 2 vehicles I have needed them for I didnt like
Heat will help, but the WD40 might take some time to have full effect. Let it soak in, maybe spray a bit more on each day, and then have another go. Also, put the torx bits in place and tap them with a hammer, which will help to break the seal
Doddmaster
PostPosted: 22:03 - 02 Jun 2002    Post subject: Reply with quote
I find that gently tapping a stuck bolt for a while with a spanner or something can loosen it up a bit
moggymiaow
PostPosted: 00:23 - 03 Jun 2002    Post subject: Re: Removing stuck bolts... Reply with quote
try an impact driver, back in the days when I had a clapped out Kawasaki KC100 it was invaluable. 12 years ago it cost me 15 quid, no idea what it would cost now.
Kat
Scooby
Scrappy Doo
PostPosted: 01:35 - 03 Jun 2002    Post subject: Reply with quote
Brute Force mate!! Laughing
Nige
PostPosted: 10:28 - 03 Jun 2002    Post subject: Reply with quote
If u still cant shift them,try undoing them while the exhaust is still hot a fter a good run. If u still have no luck, invest in a ratchet type kit, where the torx 'bits' are hexagonal (allenkey) ended, or ever available as ratchet socket ended, then u can get a bit more leverage on the buggers. My zorst had some threadlocker on the bolts, and they took some doing, but i did it. If all else fails, dont bother, and leave it.
Nige
Stew
If it's good enough for top race teams...
PostPosted: 18:03 - 03 Jun 2002    Post subject: Reply with quote
SEN GOKU?
Didnt realise you post on NC30 owners forum too tin.
I was reading your post on there and had a strange feeling of deja-vu.Mr. Green
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
TiN
Pocket Tin
PostPosted: 18:13 - 03 Jun 2002    Post subject: Reply with quote
SEN GOKU?
Yeah, well...I thought that they'd be more knowledgeable than this lot...JUST KIDDING!...nah, I just thought that I'd try to mingle with some more dedicated V4 owners...
...as for the name...well...someone else had taken "tin", and I didn't like the sound of "tin367"...it's just not quite the same...
Anyways, thanks for the responses guys...I've decided to take Keith's advice for the time being, just spraying a bit 'o WD40 on each day...and then I'll try using some heat...but: what should I actually heat up?...the bolts themselves?...
I've got to take the bike back to the dealer soon anyway (to get, amongst other things, Datatag installed...), so they should be able to get the damn things off, right?
Cheers,
Tin
Milo
PostPosted: 18:17 - 03 Jun 2002    Post subject: Reply with quote
one time i was stuck with ideas so i got the drill out. when i was drilling it through it started moving, the heat loosened it up.
Shaft drives rule. Razz
The last post was made 24 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 59.79 Kb
