High intensity discharge kits
Nb
PostPosted: 12:46 - 17 Oct 2007    Post subject: High intensity discharge kits Reply with quote
Been looking at HIDS for ages now and my new bikes headlights are no where near as good as my my old bikes so i thought about getting a kit from ebay.
The kits come with two of everything so there is enough to do two bikes if you only have it fitted on dipped beam which is the common way to have them fitted.
So does anyone want to go halfs on a kit? Cant see the point of me buying a kit that does two bikes when i only have one. Laughing
This is the cheapest set i've found for H7 BULBS which my bike has.
https://cgi.ebay.co.uk/HID-XENON-CONVERSION-KIT-BULBS-BALLAST-H7-6000K-NEW_W0QQitemZ290170706709QQihZ019QQcategoryZ9895QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The Tot
PostPosted: 12:53 - 17 Oct 2007    Post subject: Reply with quote
Ironically, that's the listing i'm looking at RIGHT now! I'm a bit dubious by the chinese made ballast units and bulbs. My cousin had some installed in his ford ranger, but the ballasts failed on him after 3 months. I'd go for something with a reputable ballast unit and no hassle installation where you don't need to splice your own relays. I was going to fork out 110 quid on the ones at www.hids4u.co.uk - but then i wrote the bike off. Wont be able to afford them once i get them on the road, so going to get OSRAM Nightstars or Philips vision extremes instead. 20 quid as opposed to 80 odd - i only need 1 so i can keep the other as spare.
Never argue with autism
Nb
PostPosted: 12:55 - 17 Oct 2007    Post subject: Reply with quote
I too was thinking about the quality of the kit, that seller does have some neg feedback but it doesnt seem too bad. Thinking
The Tot
PostPosted: 12:59 - 17 Oct 2007    Post subject: Reply with quote
A bunch of guys from MCN ninjas got a bulk order of 20 odd from china and said that it does take some time to fit and wire. If you're good with electronics, then it should be fine. But i'd rather want to be certain than have something arcing 30kV somewhere near an ignitable source!
Nb
PostPosted: 14:21 - 17 Oct 2007    Post subject: Reply with quote
I been looking at the mcnninja site and that ebay kit looks very similar if not the same type. I might just risk the cheap set and keep my fingers crossed! Laughing
EDIT: i've ordered the set, i'll see what happens. Laughing
If its any good, i'll put the other one up for sale on here at what it cost.
map
Mr Calendar
PostPosted: 16:58 - 17 Oct 2007    Post subject: Reply with quote
FYI and FWIW the HID may be illegal to retro fit.
Came across this
From the DfT:
December 2006
Aftermarket HID headlamps
In the Department's view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID "burner" (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern.
The following is the legal rationale:
The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK.
Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
However new vehicles have HID headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal.
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
If you require any further information regarding the regulations covered by this fact sheet, please contact the DfT at the address below:
Transport Technology and Standards 6
Department for Transport
Zone 2/04
Great Minster House
76 Marsham Street Telephone: 020 7944 2078
London Fax: 020 7944 2196
SW1P 4DR Email: [email protected]
Basically what they're saying is that if the reflector unit isn't designed for HID then the pattern produced would be wrong.
HTH Thumbs Up
Nb
PostPosted: 17:07 - 17 Oct 2007    Post subject: Reply with quote
Cheers for the info. Very Happy
I am aware that retro fitting hids can cause some 'leakage' on the beam pattern, but its only a small amount and it will be adjusted slightly down so as not to blind people. Thumbs Up
I know of plenty of people who have hids on their bikes and have had no issues with the plod or having their bike pass its mot, so i dont see any reason to worry.
Nb
PostPosted: 16:21 - 22 Oct 2007    Post subject: Reply with quote
Well they arrived this morning from hong kong and after taking the front end off my bike they are now fitted,and so far they seem to be working perfectly. Going to go out when it gets dark to see what they are like, but even sitting in my shed they look bloody bright. Razz Very Happy
sideways_simon
PostPosted: 16:40 - 22 Oct 2007    Post subject: Reply with quote
can we have pics of them fitted please? were they easy to fit then any problems?
been looking at these myself so it would be good to get some info on what you think of them.
Keir
PostPosted: 16:53 - 22 Oct 2007    Post subject: Reply with quote
i had some in my gix 6. looked cool but the buzzing that they make annoyed me. Fitting was a doddle, hid the ballasts in the nose of the bike.
Wont be fitting them again.
Current : '08 Yamaha FZ1s
Nb
PostPosted: 16:54 - 22 Oct 2007    Post subject: Reply with quote
Cant really take pictures since you cant see any part of the ballast or wiring on my bike, Laughing Apart from taking the nose cone off my bike it was just a matter of finding a big enough space to secure the ballast and then put the wires together and job done. I was surprised how easy it was to be honest, if you can fit a headlight bulb in your bike you can fit hids i'd say.
Mine only buzz when they first start up, other than that they are silent. Thinking[/quote]
Keir
PostPosted: 16:57 - 22 Oct 2007    Post subject: Reply with quote
count yourself lucky then!
LUXY DJ
PostPosted: 17:02 - 22 Oct 2007    Post subject: Reply with quote
nice 1, you should of got a before & after pic of them head on @ same time of day
quick question - can you make H1's fit a H4 fitting? OR is there some sort of converter for this?
i basically got a HELIOS 7000K(good make) HID kit cause it was DIRT CHEAP & im either gonna fit to bike if poss or just sell on @ a nice profit Wink
so, convertable? also how they hold up against wheelies? Mr. Green
GSXR750
Nb
PostPosted: 17:14 - 22 Oct 2007    Post subject: Reply with quote
Here is a picture, its crap but you get the point.
https://img.photobucket.com/albums/v678/blazebrown/22102007133.jpg
As for h1 to h4, hmm thats kinda awkward because a h4 bulb is much bigger than a h1. If you could fabricate some sorta ring to fit round the bulb holding is straight in the h4 holder you'd be fine. A h1 bulb locates with 2 small bumbs on it, the h4 locates using 3 lugs. Its probably doable but you'd have to remove the headlight and do it that way.
Not sure about wheelies, cos i dont do them. Laughing
LUXY DJ
PostPosted: 17:24 - 22 Oct 2007    Post subject: Reply with quote
looking goooooooood Thumbs Up looks FRESH!....so its that just one bulb with 2 filament's?
well only other option iv seen, is the bulbs unplug a bit down the wires so could just buy H4 bulbs & plug them in Very Happy
BUT cant seem to find 7000K replaceables Sad only 6k or 8k but there still good if it means i can have HID Twisted Evil
GSXR750
Nb
PostPosted: 17:31 - 22 Oct 2007    Post subject: Reply with quote
Its just one bulb, i didnt want to do main beam. On my bike main beam is a separate bulb. I still have a h7 kit left over so will probably sell it on. The bulbs on mine came with the 6k (most popular) ones, they seem to be a little blue but not like 10k ones which are almost purple. Laughing
Best thing for you would be to flog the kit you have and buy one on ebay like i did, saves the hassle when you know its going to fit properly. The kit i got cost 46 quid, and i will probably sell one half for 20 +p&p. Laughing
The last post was made 19 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 99.69 Kb
