| John |
 John World Chat Champion
| John |
 Posted: 22:08 - 27 Nov 2003 Post subject: |
It's still not working.
Help  ____________________ TT600 neeeeeeeeeeeeeeeeeeowwww! |
| Danny |
 Danny Ask Me About Stoppie School
 Posted: 22:11 - 27 Nov 2003 Post subject: |
Sorry to hear that mate. I'm sure Keith will give you some things to try when he's online.  |
| John |
 Posted: 22:14 - 27 Nov 2003 Post subject: |
I think something is just wet somewhere, hope so anway.
Thanks for the sympathy though  ____________________ TT600 neeeeeeeeeeeeeeeeeeowwww! |
| xlfive |
 xlfive Scooby Slapper
| Kickstart |
 Kickstart The Oracle
| John |
| Kickstart |
| John |
| Kickstart |
 Posted: 13:57 - 28 Nov 2003 Post subject: |
Do you mean backfiring through the exhaust or through the carb / airbox?
First would suggest that the engine is possibly flooded. Might be worth taking out the spark plug and taking the exhaust off and then kicking the engine over (ignition off). Empty the exhaust just in case that is full of petrol.
For the second it would suggest that the disk / reed valve are not sealing.
| John |
| Kickstart |
 Posted: 16:37 - 28 Nov 2003 Post subject: |
Kicking back isn't that unusual on any bike. Get it really wrong on a old 4 stroke single and they have been known to break peoples legs! However that is made worse by ignition timing.
Taking the exhaust off should be fairly easy. Probably easier than taking the carb off if a bike is still running with an airbox.
Was the petrol turned on while the bike wasn't in use?
| John |
| Kickstart |
| John |
| Kickstart |
 Posted: 22:09 - 28 Nov 2003 Post subject: |
Well the fuel will flow down through the engine and can go down the exhaust (although not likely without REALLY flooding it), but some will get sent down there when you kick it over if it is a bit flooded.
Not that necessary. I would mainly take the plug out and kick it over (with the ignition off) and see what comes out. Try also leaving it over night with the plug out to let any fuel evaporate (avoid leaving it in the rain like this ).
| tom rg 125 |
 tom rg 125 Borekit Bruiser
| John |
| Kickstart |
| John |
 Posted: 12:01 - 02 Dec 2003 Post subject: |
Put it back together this morning.
After about 10 kicks it started for around 1-2 seconds, and it won't do any more now.
| Kickstart |
 Posted: 12:09 - 02 Dec 2003 Post subject: |
Get a can of cold start or carb cleaner (carb cleaner seems less violent so might be a better idea, although even WD40 will do the job). Turn the ignition on. Make certain the choke is off (if it is flooded the choke will make the problem far worse). Get someone to spray the stuff into the carb as you kick the engine over (using full throttle). Hopefully that will keep it running. Hopefully once running it will clear itself out.
Remember that when doing this the stuff is highy flammable, so be very careful and don't spray if all over the bike around the carb as you don't want it to backfire through the carb and set fire to itself (certainly not if it is inside).
I am not certain that it is flooded but it does see like the best chance. If this fails then it is probably time to start from the basics checking ignition timing, compression, etc.
| John |
| Kickstart |
 Posted: 12:28 - 02 Dec 2003 Post subject: |
Spray in straight into the carb intake from the airbox / air filter.
Although you could turn the fuel off it will take ages to use up that in the fuel pipe and carb. However on a slide carb on full throttle at VERY low revs (ie, when you are kicking it over) then the carb is not going to work very well, and should not draw in much fuel so should land up being a bit lean. This is why I suggest using full throttle (just be ready to close it quickly).
| John |
| John |
The last post was made 22 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
