| binge |
 binge Emo Kiddy
| Stevie B |
 Stevie B Crazy Courier
 Posted: 00:42 - 22 Oct 2007 Post subject: |
I had this now and again with my CB-1 when i had it, but can't really remember what the circumstances were when it happened..
It's ace though when it happens isn't it, like you said i always came home grinning from ear to ear thinking "i love that bike!"
In answer to your actual question.. I've no idea
 ____________________ Past: Katana 50, NSR125RR, FZR600r, CB-1 Present: TRX850 |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 00:48 - 22 Oct 2007 Post subject: |
if your bike runs better when cold, and then gets worse as the temp of the outside air or the bike increases then your bike is running rich,
which is kind of odd since you have changed your exhaust, which normally leans it out slightly,
sounds like the bike needs a good tune ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| hmmmnz |
 Posted: 00:51 - 22 Oct 2007 Post subject: |
here is a guide to lean and rich carb conditions
from motorcyclecruiser.com
Typical Lean Conditions:
- Poor acceleration; the engine feels flat.
- The engine won't respond when the throttle is snapped open, but it picks up speed as the throttle is closed. (A too-large main jet also mimics this symptom.)
- The engine runs hot, knocks, pings and overheats.
- The engine surges or hunts when cruising at part-throttle.
- Popping or spitting through the carb occurs when the throttle is opened. Or popping and spitting occurs through the pipe on deceleration with a closed throttle.
- The engine runs better in warm weather, worse in cool.
- Performance gets worse when the air filter is removed.
Typical Rich Conditions:
- Engine acceleration is flat and uneven and loses that "crisp" feel.
- The engine "eight-strokes" as it loads up and skips combustion cycles.
- The engine's idle is rough or lumpy, and the engine won't return to idle without "blipping" the throttle.
- The throttle needs to be open continuously to maintain acceleration.
- Black, sooty plugs, a sooty exhaust pipe and black smoke from the tailpipe that stinks of unburned fuel.
- Poor fuel economy.
- The engine works better when cold. Performance falls off as it warms up or the ambient temperature rises.
- Engine performance improves when the air cleaner is removed. ____________________ the humans are dead
| mr.z |
 mr.z World Chat Champion
 Posted: 01:37 - 22 Oct 2007 Post subject: |
When its cold the air density is greater, so you get more o2 per cm3 of atmosphere, just like in nitrous oxide /// theres a greater density of oxygen, or when your in the himalyas your bike might not even run, down to the lesser o2.
It could be shitty setup but its something that affects allot of bikes (two strokes especially it seems from here, but then maybe its just more noticeable) every winter theres posts up allong the lines of "its funkin freezeing but my bikes going faster" because you get a more efficient burn you get more prod.
Maybe worth haveing it dynoed and set up right if its really that noticable you might be running rich, or at least check your filters e.t.c.
edit: yep your quite right, think its time for sleep! ____________________ >RidingSkills<->Tech Tips<->MyBikes<
| hmmmnz |
| binge |
 binge Emo Kiddy
 Posted: 01:43 - 22 Oct 2007 Post subject: |
From the guide there are symptoms from both.
The main ones I notice are.
Pulling away from traffic lights, its very underpowered until the revs rise above 4k It pulls away as slow as cars. The NC29 on the other had ripped your arms out!
Looking at the temp gauge it does appear to be running hot. Or Hotter than the NC29 did.
I get pops on over run
Runs shit hot in cold weather  |
| binge |
 binge Emo Kiddy
| Marcg868 |
 Marcg868 World Chat Champion
The last post was made 18 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
