Cooling System Issue - Urgent
UrbanRacer
PostPosted: 19:13 - 23 Oct 2007    Post subject: Cooling System Issue - Urgent Reply with quote
Hi folks, need a bit of help with my bike and i need it fast as i'm trading it in at the weekend. One of the dealers mechanics will be giving it an apraisal and will spot this.
the bike is a Suzuki GSXR 600 K4
here are a few things that may help with the diagnosis
the bike is not over heating (never goes above 105c)
their is no water that i can see dripping from where it shouldn't
their is no steam coming from it,
the fan kicks in at the right tempreture (102c)
So here is what happens, when the bike is at a standstill say in heavy traffic that i cannot filter through the temp will rise like normal, however when the temp gets to around 90c the water in the expansion bottle starts to rise and by the time it hits 100c the coolant is emtying itself out of the overflow tube on the expansion bottle.
I thought it was the Thermostat so i ordered a brand new one and i fitted it tonight, but the problem is still here.
any ideas folks?
MidnighToker
PostPosted: 19:17 - 23 Oct 2007    Post subject: Reply with quote
this might be a stupid question -and if it is, then feel free to laugh at me and just see this post as a bump, but...
Could you not just be over-filling it?
Timmeh
PostPosted: 19:20 - 23 Oct 2007    Post subject: Reply with quote
that would have been my immediate thought.
Wait until the bike's stone cold and then check the levels in both the main system and the expansion bottle.
lukamon
PostPosted: 19:40 - 23 Oct 2007    Post subject: Reply with quote
cant you just move the hose so it points upwards?
killa wrote: Im an ass man myself
PostPosted: 19:56 - 23 Oct 2007    Post subject: Reply with quote
Most bikes are filled to the top of the radiator, I believe.
Wondering if the radiator cap is working properly? This is the bit that 'releases' the pressure to the expansion bottle usually.
After that, maybe it could do with the coolant renewing?
UrbanRacer
PostPosted: 20:02 - 23 Oct 2007    Post subject: Reply with quote
the coolant levels are fine and i put fresh coolant in tonight, i will order a new rad cap tomorrow Rolling Eyes and pray that its that simple
much obliged for your input Thumbs Up
iooi
PostPosted: 20:28 - 23 Oct 2007    Post subject: Reply with quote
Water pump starting to give out, head gasket on its wayout....
Removing stat would help to stop it soing it, but would cause a longer warm up time.
UrbanRacer
PostPosted: 21:02 - 23 Oct 2007    Post subject: Reply with quote
surely if it was the head gasket their would be signs of it in the coolant? i flushed the system and didn't see any white gunk, also when i washed the driveway clean with water if their had been oil in the coolant i would have seen the rainbow effect?
BanditsHigh
Worse than a woman
PostPosted: 21:07 - 24 Oct 2007    Post subject: Reply with quote
^^^ Correct .. it'd be a nasty mix if either oil or exhaust gases were getting into the water.
Didn't your bike have a lot of problems at a certain dealer not long ago ... have they fitted the hoses from the cooler to the overflow bottle back on the right way?
I only say, because I've just rebuild a Vmax engine for a mate not that long ago, and I (or my mate) connected the two pipes leading to/from the overflow the wrong way round ... this led to the overflow bottle being pressurised when the engine heats up, pushing water out of the bottle and on to the road ... sounds like this may be the problem with yours.
All the best ... Barry
UrbanRacer
PostPosted: 21:19 - 24 Oct 2007    Post subject: Reply with quote
thanks, i have a copy of the workshop manual so i'll have a look and make sure its all connected up properly
PostPosted: 22:48 - 24 Oct 2007    Post subject: Reply with quote
Not always. It can just be a tiny wee 'jet' of gas. That said, a blown head gasket usually does it more the higher the revs get. If it's doing it at tickover, it's probably something to do with the coolant system itself.
UrbanRacer
PostPosted: 13:30 - 27 Oct 2007    Post subject: Reply with quote
I bled the cooling system again but it hasn't made any difference so i've bought a Rad Cap from ebay, hopefully it will arrive monday or tuesday and it will solve the problem.
i'll post the outcome
Gpz 900R
PostPosted: 23:31 - 27 Oct 2007    Post subject: Reply with quote
Without wanting to sound patronising you said you have bled the system, i would double check as a lot of bikes have 2 bleed points for the cooling system, another option would be to fit a manual overide switch for the fan this would mean you can ensure the fan is operating when you see the temp starting to rise.
Paddy Blake
PostPosted: 23:43 - 27 Oct 2007    Post subject: Reply with quote
Have you checked if the front of the rad is blocked so the air can't get in
to cool it down.Or the fins could be bent and doing the same thing.
Paddy.
PostPosted: 08:44 - 28 Oct 2007    Post subject: Reply with quote
Couple of things with Suzukis:
The fan switches are prone to failing, perhaps the fan is coming on too late or not at all. If not at all check the fuse.
It's common to get an air-pocket in the cooling system when filling up, which would cause the water to boil inside and increase the pressure. When you fill the bike set it running thengo round squeezing the hoses to try to "burp" out any trapped air.
UrbanRacer
PostPosted: 10:28 - 28 Oct 2007    Post subject: Reply with quote
their is definetly no air in the syetem, i squeezed the hoses and had the bike over on its side several times
UrbanRacer
PostPosted: 15:27 - 03 Nov 2007    Post subject: Reply with quote
I got a Radiator Cap from ebay for £8 and It solved the problem.
Thanks for your input guys Smile
bugsy46
Village Idiot
PostPosted: 15:37 - 03 Nov 2007    Post subject: Reply with quote
I cant believe G was the only one that solved this!!!!!! Lower pressure lower boiling point!!??? Shocked Shocked What happens when you boil water up mount everest? Shocked
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
LeeR
PostPosted: 17:47 - 03 Nov 2007    Post subject: Reply with quote
It boils at 75deg C fine for coffee but damned useless for tea.
My claim to fame: Austin Vince nicked my pen...
Paddy Blake
PostPosted: 17:58 - 03 Nov 2007    Post subject: Reply with quote
I am sure others would have posted the same but it was all ready
there. Thumbs Up
And I got lost in other parts of the forum. Laughing
Paddy.
PostPosted: 23:28 - 03 Nov 2007    Post subject: Reply with quote
You can put your hand in it but you can't brew a decent cuppa Wink
The last post was made 18 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 112.19 Kb
