nsr125r clutch problem
steve-h
PostPosted: 15:53 - 25 Oct 2007    Post subject: nsr125r clutch problem Reply with quote
the clutch on my bike dont seem to be working right
when clutch lever is pulled and first gear is engaged it feels as though the clutch has not disengaged
wot i mean is the bike still feels as though its in gear even with the clutch lever pulled in
ive tried to adjust it at the lever end and also the other end
would it help if the transmission oil is changed or does it not affect the clutch
TUG
PostPosted: 15:56 - 25 Oct 2007    Post subject: Reply with quote
what do you mean? when you let the clutch out in first it doesnt move?
Haz ER-5, innit!
steve-h
PostPosted: 16:14 - 25 Oct 2007    Post subject: Reply with quote
when the engine is off and you put it in first it feels as if the clutch aint doing a thing
when the engine is running pull the clutch in and put it in first it stalls
does that make any sense
TUG
PostPosted: 16:16 - 25 Oct 2007    Post subject: Reply with quote
hmm, has it been stood for a while?
Haz ER-5, innit!
steve-h
PostPosted: 16:18 - 25 Oct 2007    Post subject: Reply with quote
yes a few months why you ask?
TUG
PostPosted: 16:21 - 25 Oct 2007    Post subject: Reply with quote
possible the plates are sticking together,
you sure the cable is tight? and upto specification out the manual?
you not over tightened it have you or left it too slack have you?
Haz ER-5, innit!
steve-h
PostPosted: 16:34 - 25 Oct 2007    Post subject: Reply with quote
adjusted it back to where it was
clutch lever pulls ok
if plates are sticking together how would i cure it
will it have to be stripped apart to free them
TUG
PostPosted: 16:37 - 25 Oct 2007    Post subject: Reply with quote
well i was gunna tell you how but we should run through the basic stuff before we start stripping it down. how long was it stood for? have you got a manual for the bike? there should be about 2-5mm freeplay measured from the ball on the lever. have you got a few pics of the clutch area?
Haz ER-5, innit!
steve-h
PostPosted: 16:40 - 25 Oct 2007    Post subject: Reply with quote
ive owned it since the start of august this year
so im not quite sure just how long its been stood for
TUG
PostPosted: 16:44 - 25 Oct 2007    Post subject: Reply with quote
well i guess if its been stood for a long time and not been used for a long time, then the plates could be stuck together, is the first time you've tried to use it or have you been using it previously?
Haz ER-5, innit!
steve-h
PostPosted: 16:47 - 25 Oct 2007    Post subject: Reply with quote
this is the first time as i was doing other jobs on the bike first
TUG
PostPosted: 16:49 - 25 Oct 2007    Post subject: Reply with quote
well if you wanna have a look at your clutch anyway as it might be worn down i could tell you a quick way and a more in depth way to cure sticky plates if youd like?
Haz ER-5, innit!
steve-h
PostPosted: 17:57 - 25 Oct 2007    Post subject: Reply with quote
yeah any help at all would be great
TUG
PostPosted: 18:02 - 25 Oct 2007    Post subject: Reply with quote
well, if you drain all the transmission fliud out and remove the clutch casing you can undo the clutch basket and take out all the plates and give them a good look at to see if they are worn or warped, or if the pressure plates are warped or under limit, if there ok put em back in with fresh fluid, if nor replace them with some new plates EBC brakes do good replacement sets a a very good price. or if you want the quick route then drain the trans fluid and tie the clutch lever to the bar and leave overnite, then check it the next day with some fresh fluid. any questions? Thumbs Up
Haz ER-5, innit!
alains
PostPosted: 18:46 - 25 Oct 2007    Post subject: Reply with quote
you can try to get it working . warm your bike until the temperature needle comes out the blue zone . apply full front break , apply acceleration 5000 rpm , press down your clutch handle then engage firsyt gear , after 1,2 or 3 times your clutch will get unstock . if not , you may dismount it
TUG
PostPosted: 18:47 - 25 Oct 2007    Post subject: Reply with quote
there you go king of the NSR's info should fix it up unless you need to trip it like i said or have already started stripping it.
Haz ER-5, innit!
steve-h
PostPosted: 19:28 - 25 Oct 2007    Post subject: Reply with quote
in the morning ill try alains way if that dont work ill strip it down
shouldnt take to long
cheers for the help guys
steve-h
PostPosted: 16:59 - 29 Oct 2007    Post subject: Reply with quote
well i tried it alains way over the weekend and it went into first without stalling
let the lever out about half way and you could feel it biting
but still cant get first smoothly
so i think im going to renew the clutch
so if im ging to strip it i may aswell put a new 1 in
exactley what parts should i be changing
is it 5 or 6 friction plates needed and what else
or is there somewhere i could buy a complete clutch kit from?
TUG
PostPosted: 17:05 - 29 Oct 2007    Post subject: Reply with quote
um, well it depends on whats wrong with the clutch as a whole, the pressure plates might need renewing etc, i would take it apart have a see at the pressure plates to see what condition there in.
but apart from that, you can buy good parts from https://www.ebcbrakesdirect.com/bike/default.asp they sell friction plates, and springs, not sure on the pressure plates though, i would take a look at the pressure plates and if seem nice and unwarped and not worn down, i'd give em a good ruffing up with some emeroy cloth. Thumbs Up
Haz ER-5, innit!
TUG
PostPosted: 17:10 - 29 Oct 2007    Post subject: Reply with quote
had a once over and looks like £40 odd to replace the friction plates and springs. Thumbs Up
Haz ER-5, innit!
Timmeh
PostPosted: 19:56 - 29 Oct 2007    Post subject: Reply with quote
sweet.
just make sure you put them back in the right order. Wink
steve-h
PostPosted: 22:47 - 30 Oct 2007    Post subject: Reply with quote
well i stripped the clutch out this evening and noticed that the friction plates looked thin(but i dont know how much material should be on them)
and the steel plates well one looks ok and the other four have what i looks like discolouration they look like heat marks
i take this isnt normal is it
any ideas ???
TUG
PostPosted: 01:45 - 31 Oct 2007    Post subject: Reply with quote
discolouration would suggest slipping, could you see the grooves in the friction material? and where the pressure plates nice and flat?
you take a look at the kit on EBC?
Haz ER-5, innit!
steve-h
PostPosted: 18:57 - 01 Nov 2007    Post subject: Reply with quote
took the clutch to my local bike place today and he reckons the clutch should be fine with some new oil
thought it may have been dragging(whatever that means)
the plates are within the limits of the manual specs
and the pressure plates dont seem to be warped either
so im going to refit the clutch with new oil
whats the best oil to use in the transmission??
and i need a new gasket also is this a main dealer item?
TUG
PostPosted: 21:39 - 01 Nov 2007    Post subject: Reply with quote
instant gasket costs the same but you can use it everywhere like i have, sump starter clutch and my clutch is sealed with instant gasket not dealer gaskets. if you wanna use original then it will have to be a dealer part.
Haz ER-5, innit!
The last post was made 18 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 118.75 Kb
