derestricting an import nsr
beano
PostPosted: 17:15 - 04 Jun 2002    Post subject: derestricting an import nsr Reply with quote
Hi i just bought an import nsr and after i run the bike in i want to derestrict it but i heard that the imports are dif and to derestrict them u have to change the cdi is this all thats restricted or are the carb and pipe restricted also i no u all must get loads of questions about this but well i dont know much about bikes and im stressing a bit ty. But cant wait till i get on my brand spanking new nsr Very Happy
ride fast eek zbend scrape crash!!
Stevo
Guest
PostPosted: 19:28 - 04 Jun 2002    Post subject: Reply with quote
Its possible, but i wouldent take it as fact that your cdi must be changed without first getting it confirmed by someone who knows about NSR's from whatever country that your bike was originally for, as its an expensive part to replace, especially if it turns out that it is not the restriction, to your bike. I would firstly check for the usual restriction methods first, before looking for anything more sinister, or complex.
Other ways that a bike may be restricted are simple things like limiting the travel of the throttle slide, or fitting a smaller intake tube to the airbox. and rejetting. Its possible to restrict a bike electronically, but less likely as its a more costly option. Disconnected, or sleeping powervalves can also be a way of restricting the power. The latest yamaha DT/TDR models have the YPVS that was ommited on early models, but they have the cables set up, and a plastic spacer that limits the movement of the YPVS valve, but electronically there is no restriction. Of course its possible that a motor could be restricted all over the place, and made near impossible to fully de restrict, but that very unlikely, these days, as the 125 market is much smaller than before. The old Kawasaki AR125 is a gd example, where they did 2 distinct versions, the Unrestricted A model, and the 12hp B version. The B model had lots of changes, and the carb size was different, as was the disc valve, and the cylinder porting, and compression ratio, as well as an exhaust restrictor, as they catered for both full license holders as well as learners, by having the 2 models. I think that some Euro countries allow 125's to be ridden by 16 yr olds, but with an 80kmh limit, so many bikes have gearing changes as well. Check all the obvious things first, and then if needed, get some advice from someone in the know, but dont listen to silly muppets that just go round saying cut the so and so wire, and whey hey you have a 110mph bike, unless they can explain what is what, as there are plenty of bullshitters out there with nothing else better to do.
beano
PostPosted: 20:19 - 04 Jun 2002    Post subject: Reply with quote
Thx i have to run the bike in first so for at least 1000 miles i wont be direstricting it any way but it wont take me long to clock up 1k miles but ill prob take the bike to 1.5 2k before i realy use the bike properly.z
cheers
uglykidjoe
PostPosted: 12:12 - 05 Jun 2002    Post subject: Reply with quote
i just bought an import nsr (black) ive done about 200km. i needed to replac one of the indicators cos it wasnt workin and with it being an import they cost me like 25 quid each! have you been on your bike yet beano? is it 2001 or 2 model?
get in ma belly.
uglykidjoe
PostPosted: 12:14 - 05 Jun 2002    Post subject: Reply with quote
oh, and when you bought it did the shop fit a new speedo in mph than km or did they stick some snide stickers around the clock. is it legal to ride like this or is it expensive to get a new speedo fitted?
get in ma belly.
Robby
Dirty Old Man
PostPosted: 15:18 - 05 Jun 2002    Post subject: Reply with quote
those sticker overlays make it legal, and it will still pass an MOT. getting a new speedo will be 60-100 quid, and not worth it.
TJ NSR
PostPosted: 20:16 - 05 Jun 2002    Post subject: Reply with quote
u can always pick up a speedo from a breakers!!!
much cheaper
The last post was made 24 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 49.89 Kb
