A question about a Honda NSR 125 plz have a look
ShepShep
PostPosted: 19:26 - 29 Oct 2007    Post subject: A question about a Honda NSR 125 plz have a look Reply with quote
Hi, Iv just bought myself a NSR 125 it has done 18000 miles and i wondered if any one knows when do NSR's need a rebuild as i know that RS 125's need a rebuild every 3000 miles??
Thx in advance
Tony
NSR Mick
PostPosted: 19:46 - 29 Oct 2007    Post subject: Reply with quote
Unless you have documentary proof it's had at least a top end rebuild it'll be due one shortly, if not overdue.
Alains will know better. Thumbs Up
ShepShep
PostPosted: 22:21 - 29 Oct 2007    Post subject: Reply with quote
Thanks allot 4 that, ill research how much an average engine rebuild costs for that bad boi, cnt be that much i guess
Tony
st3v3
PostPosted: 23:34 - 29 Oct 2007    Post subject: Reply with quote
I did my NS125R top end for about £50 myself, was really easy and running in was ok, get round your local bike shop and check the prices on following parts:
Piston
Rings
Little end bearing
Gaskets.
Then report back but as Mick said, alains is the best man to ask.
alains
PostPosted: 09:16 - 30 Oct 2007    Post subject: Reply with quote
this schedule of rebuild has been given by my friend mechanic specialized on NSR125R since 1989 :
- 7500 miles de-coke +rings+clips change
- 15000 de-coke +piston-rings+pin+bearing+clips change
- 22500 top-end change and eventually crank bearings
seals & gasket needed : base cyl seal , oil seal (valves shaft), cyl head gasket
it's necessary to dismount valves system in order to clean them , otherwise you have risk of valves malfunction
ShepShep
PostPosted: 09:47 - 30 Oct 2007    Post subject: Reply with quote
What you guys post realy helps Smile i dnt rly have much experience in mechanical engeneering when it cmes to bikes as im only 17 Smile but weve got a honda dealer near me, im sure theyl try to rip me off but with this info i knoe what needs to be done Smile thx allot
Tony
nickcheshire1...
PostPosted: 19:56 - 21 Feb 2008    Post subject: honda nsr 125 foxeye 2002 Reply with quote
hi
i have a nsr and its done about 15,000 miles i personally think its lacking speed but i cant get a bigger bike yet , is there any modifications i can do to the bike to make it fast i have a budget so i do not want to spend too much and i do not want to "de-restrict" it is there anything else i can do to up the perfomance of my bike
thanks
nick Smile
The last post was made 18 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 52.93 Kb
