camshaft caps
halo123.
PostPosted: 08:32 - 31 Oct 2007    Post subject: camshaft caps Reply with quote
is it possible to get these separate from the cylinder head ,
or second hand or are they matched to the head and have to be to gether,
the thread on the ones on the gs are in not good shape and i have had one helicoiled already and i see another is going on its way, causing the bike to leak oil from the camshaft cover
Halo123. =Techie/geek and bike rider Wink ,
current bikes owned ,fix me upper gs 500e missing cdi
cbr 250 virgin colours
hmmmnz
PostPosted: 08:49 - 31 Oct 2007    Post subject: Reply with quote
https://images.powersportsnetwork.com/fiche/images/Suzuki/1989/Motorcycles/2103_1.gif
4.1 = 09106-07001
4.2 = 09106-07009
order online from
https://www.robinsonsfoundry.co.uk/
it says on the fiche that you need 4 of each??
you can order individually
the humans are dead
I kick arse for the lord
halo123.
PostPosted: 09:53 - 31 Oct 2007    Post subject: Reply with quote
not the bolts but the cam caps , as i want to replace them and not tap them/heliciol them all , was told that i would need a new cylinder head, as it is a set,
holds the camshafts in place and the those bolts screw in to the top of them and hold the camshaft cover down and seal the head /tappet cover , the part that is between 4 and 5 in this fiche note it does not have a part no and they are letterd a , b , c and d
https://www.ronayers.com/fiche/300_0027/cylinder_head/cylinder_head.cfm?man=su&groupid=3120&parent=3070
cheekythomas
PostPosted: 09:54 - 31 Oct 2007    Post subject: Reply with quote
Thats the rocker cover... he wants the camshaft caps. Wink
The camshaft caps form the top half of the circle that the camshaft sits in, and has treaded parts that the rocker cover bolts down onto.
sickpup
Old Timer
PostPosted: 13:06 - 31 Oct 2007    Post subject: Reply with quote
No they are unique to each cylinder head as they are line bored with the head as one piece.
PostPosted: 13:13 - 31 Oct 2007    Post subject: Reply with quote
As above, although they are also unique to their position on that particular head.
halo123.
PostPosted: 13:25 - 31 Oct 2007    Post subject: Reply with quote
so the options available to me to repair this are
1 get a new cylinder head
or have the remainder tapped/ helicioled
Thanks
Angus
PostPosted: 13:29 - 31 Oct 2007    Post subject: Reply with quote
Yes. If those caps are damaged beyond repair (or you do not wish to repair them) then the head is scrap.
You can helicoil them (the rocker cover bolts should not need to be that tight), or I have heard that you might be able to get over size rocker cover bolts and just tap the threads out to a larger size.
halo123.
PostPosted: 14:49 - 31 Oct 2007    Post subject: Reply with quote
Kickstart Posted: 14:29 - 31 Oct 2007 Post subject:
Grr the dealer here said no i could use a second hand one , and the tried to sell me a new head but i will probably helicoil the others then as i can see that it is just gonna go from one cap to then next getting progressivly worse
thanks
Angus
PostPosted: 15:11 - 31 Oct 2007    Post subject: Reply with quote
Normally the torque required on those cover bolts is pathetically small. Hence there should not be much stress on those threads.
Kris
PostPosted: 15:45 - 31 Oct 2007    Post subject: Reply with quote
I once got some repairs done to a set of camshaft caps after discovering some monkey decided not only to fudge the threads but also fudge hele-coiling them. Brick Wall Brick Wall Brick Wall
I also enquired, like yourself, about replacing them; only to be told they were unique to that particular camshaft. Mad Worse still, one had split due to severe abuse.
I found a place not too far from me that builds trikes and 'one-offs' and the guy welded one up for me as well as fixing the rest with a combination of metal inserts and hele-coils. This time done properly, mind. Very Happy
To get four done cost £80 and took him a week because he was already flat out on other stuff.
So it can be done. Thumbs Up
www.prisonplanet.com
halo123.
PostPosted: 08:14 - 01 Nov 2007    Post subject: Reply with quote
thanks kris.
i will be phoning the guy that did the first one for me some time .
And end up taking them in , maybe he can give me a special price as i brought all of them to him as he charged me R150. (sa) for the one .
The last post was made 19 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 75.99 Kb
