scooter wont start please help
elliott1983
PostPosted: 22:51 - 31 Oct 2007    Post subject: scooter wont start please help Reply with quote
hi there i have a gilera skp 50cc 1998 plate and it wont start Sad fuel is getting through to piston but none on spark plug so i have tried tipping a bit in spark plug hole to get it fire and it tries but doesnt succeed i have noticed that it is seeping fuel from the exhaust manifold is this the problem for firing up too much air maybe or is it something else also it has had the piston stripped and checked and this isnt the problem according to my dealer please help
b1g5m0k3
PostPosted: 00:11 - 01 Nov 2007    Post subject: Reply with quote
was the bike standing around for a few weeks without being started??
elliott1983
PostPosted: 08:44 - 01 Nov 2007    Post subject: gilera Reply with quote
yes been stood for two years
b1g5m0k3
PostPosted: 00:42 - 02 Nov 2007    Post subject: Reply with quote
ok heres your problem, your battery is as flat as arsehole and your petrol is fucking RANK after having been in the tank for 2 years.. so listen.
drain your fuel and put some new in, and charge ur battery, if it still dont work get a new spark plug and drain your carb
b1g5m0k3
PostPosted: 00:43 - 02 Nov 2007    Post subject: Reply with quote
ps. if its a 2 stroke change the oil aswel Very Happy
Cigaro
PostPosted: 13:26 - 02 Nov 2007    Post subject: Reply with quote
The most important thing is to replace the spark plug and give it fresh fuel.
It will run. I have a moped sitting in my back yard that hadn't started in 5 years. Took two hours of kicking it over before it started to even try and run.
elliott1983
PostPosted: 18:24 - 02 Nov 2007    Post subject: gilera skp Reply with quote
i have drained fuel changed oil and new spark plug still wont kick checked crankseals and piston rings also checked petals are intact so why wont it fire the battery is dead but i connect my jumppack on to turn it over ,
konsoli
PostPosted: 20:23 - 02 Nov 2007    Post subject: Reply with quote
btw, next time you leave your bike standing, drain all the fluids.
Tango675
PostPosted: 20:22 - 04 Nov 2007    Post subject: Reply with quote
Have you checked you have compression?
Have you got a birds nest in your air box?
Have you got a good spark (checked the gap) on your spark plug?
After that, a pagen ritual, followed by a sacrifice (your least favorite teddy)
Somebody give that windup merchant a torque wrench..
The last post was made 18 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 57.02 Kb
