New chain & sproket set
Bardeey
PostPosted: 00:08 - 04 Nov 2007    Post subject: New chain & sproket set Reply with quote
Hey all
Today my chain snapped and wrapped around my gearbox however luckily everything is ok and no damage has been done.
Due to this I obviously need a new chain and feel that I need to replace my Sprocket at the same time.
The bike I have is a Suzuki Bandit 400 GSF Gray (Import)
What kit do you suggest I get?
https://www.mandp.co.uk/productInfo.aspx?catRef=548441 ??
Heavy duty, O Ring or X Ring?
I'm not an expert when It comes to choosing!
Thanks for your help
B
(Not being able to go out on my bike is killing me Twisted Evil )
:: P Speedfight 49cc => Gilera DNA 124cc => Suzuki Bandit GSF V 400cc ::
:: CBT=Passed 07/08/05 :: Theory=Passed 31/05/07 :: Practical= Passed 02/08/07::
Ichy
PostPosted: 00:37 - 04 Nov 2007    Post subject: Reply with quote
Any will be fine, its just a matter of how much work you want to put into maintaining it. HD is generally cheapest but requires a fair bit of looking after to get any decent life out of it. O ring is sort of the middle ground, it consists of sealed, lubricated, bearing joints that will ensure good life as long as no grit gets in. X ring is supposed to be better seals compared to o ring.
Richard_Schmid
PostPosted: 09:10 - 04 Nov 2007    Post subject: Reply with quote
How easy are Chains/Sprockets to fit? I`m gonna have to be doing that soon. Rich
Ichy
PostPosted: 10:47 - 04 Nov 2007    Post subject: Reply with quote
The basic principal is pretty simple, break chain, remove front and rear sprocket, fit new sprockets, fit new chain.
One general problem is that the front sprocket can be ridiculously tight. If this is the case then your going to need a minimum of a breaker bar or air gun. At times even this isn't enough and I've had to resort to scaffold tube and heat. Best advice I can give is to not remove the chain until the nut is undone. This means you can use the rear brake to try and lock the sprocket or better still, get a garage to release it, their compressors and air tools tend to be better than most home users, then ride home, carefully, and do the rest of the work yourself.
Next bit is to check what type of chain you have, rivet or split link. Split link, no problem, just follow the instructions and make sure you fit the link the right way round. For a rivet link your going to need to either use a link breaker tool or a grinder to take the chain off. To refit the chain you need a riveting tool or use a split link temporarily and get a workshop to fit the rivet link, should only cost a couple of quid.
Only use thread lock where it says so and try and make sure that you torque fixings up to the correct value.
Richard_Schmid
PostPosted: 12:25 - 04 Nov 2007    Post subject: Reply with quote
Thanks for the Info Wink Thumbs Up
The last post was made 18 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 45.03 Kb
