| cagivaman |
 cagivaman Derestricted Danger
| prawny1 |
 prawny1 World Chat Champion
| cagivaman |
| Kickstart |
 Kickstart The Oracle
| prawny1 |
| Kickstart |
 Posted: 00:24 - 07 Nov 2007 Post subject: |
The difference between normal unleaded and super unleaded is small, but if you had upped the compression enough to need the super unleaded then the chances are that using normal unleaded would rapidly cause it to burn a hole in the piston.
While it might work, I would seriously doubt it would without a fiddling round to get the compression back down to something sensible. And would certainly be a good idea to measure the compression before you even though about starting the engine.
| prawny1 |
| Kickstart |
 Posted: 01:35 - 07 Nov 2007 Post subject: |
It still makes a substantial difference. Factor in that the Cagiva already runs a high compression ratio and also (in some instances) requires 98 RON fuel as standard, even a small difference could be expensive.
Having killed pistons on an Aprilia 2 stroke using a 0.3mm base gasket on an engine set up for a 0.5mm base gasket (a small change in compression, but enough to burn a hole straight through the piston crown) I am a bit careful about this, and very dubious about saying to anyone to just give it a try.
| prawny1 |
| Kickstart |
| prawny1 |
| Kickstart |
| Kickstart |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| cagivaman |
 Posted: 10:59 - 08 Nov 2007 Post subject: |
ok cheers for the help guys
<SMC> |
The last post was made 18 years, 347 days ago. Instead of replying here, would creating a new thread be more useful? |
