derbigpr50 eletric start and clutch problem
speeddevil
PostPosted: 17:56 - 03 Nov 2007    Post subject: derbigpr50 eletric start and clutch problem Reply with quote
heya
basicaly i won the 07 plate derbi gpr and the eletric start isnt working and teh clutch seems to be loose as when i try to start the engine the bike jumps even when it is pulled in most the way but it only happens half the times taht i try to start it if you have any diea what may be wrong i would be greatfull thank you Smile
cheekythomas
PostPosted: 20:16 - 03 Nov 2007    Post subject: Reply with quote
Whats the electric start doing?? When you press the button does the engine try to start? Does it turn over.. Does it just click?? Or does it do nothing and the dash go out?
The clutch lever has an adjuster on the cable so you can remove most of the slack cable (leave a couple of mm though)
Try to only start the bike when its in neutral as when in gear, even with the clutch pulled in, it puts a lot of strain on the little starter motor and will wear it out much faster....
If the bike is new the clutch will drag a little as they come with cheap nasty engine oil in as standard which should be changed at the first service 625miles (1000km) and we use a fully synthetic gearsaver oil which improves the gearchange and clutch feel loads!
speeddevil
PostPosted: 12:43 - 06 Nov 2007    Post subject: Reply with quote
the bike sometimes just clicks and doesnt even turn over, othertimes it just starts to turn over but it just wont, i normaly do start it in netural but if i have just tried to bump start it i cba to put it back in gear. ok thanx will fix the clutch tonight Smile
cheekythomas
PostPosted: 10:55 - 07 Nov 2007    Post subject: Reply with quote
Sounds like battery is faulty then... its under the fuel tank.
5mm allen bolt at the front, 2x 6mm allen bolts under seat and it lifts off... there is a wire for the fuel light, the 2 pipes onto the fuel tap and a pipe from the fuel cap drain to be undone and you can remove it... then youll see the battery next to the coolant bottle.
Should be a YTX5LBS.
speeddevil
PostPosted: 18:59 - 07 Nov 2007    Post subject: Reply with quote
cheers i will have a look tonight and if i still carnt fix it i will put a post on this subject
The last post was made 18 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 43.06 Kb
