NEED HELP FAST !!!!!!!!!!!!!!!!!
b1g5m0k3
PostPosted: 18:25 - 08 Nov 2007    Post subject: NEED HELP FAST !!!!!!!!!!!!!!!!! Reply with quote
im going out 2nite and its just been pouring hard with rain and now the bike wont start!!!!!!! what is wrong with it!?
anyone know??
Davo
Davo To The Rescue!
PostPosted: 18:26 - 08 Nov 2007    Post subject: Reply with quote
Try putting in a bit more detail, what exactly happens, does it light up when you turn the key etc..?
It's quite possible water has got somewhere where it shouldn't, but without a bit more detail it's hard to tell.
ken
PostPosted: 18:30 - 08 Nov 2007    Post subject: Reply with quote
Possible water has ingresses into the plug area take ht leads off get hair dryer and dry them... and the plug area...
like said more details but if its after a water fall It limits it Oh and take petrol cap of and fill her up Rolling Eyes
latest bike 03 R1 in zee red and black
AC
PostPosted: 18:33 - 08 Nov 2007    Post subject: Reply with quote
Cut-out switch knocked to off position?
Water in the cut-out switch/electrics causing a blown fuse?
b1g5m0k3
PostPosted: 18:34 - 08 Nov 2007    Post subject: Reply with quote
the lights and indicators work and stuff and the dash lights up for a split second like its trying to start but it just wont
Maybe your power band has gone?
Seriously though something a little more specific would be good. Do your lights, horn etc. still work if you turn the ignition on? Have you checked all your fuses?
b1g5m0k3
PostPosted: 18:35 - 08 Nov 2007    Post subject: Reply with quote
yes all the lights work it just wont start Sad
Lights up for a split second?
Does the starter spin up and it not catch or can't it turn it over/ spin slower than normal?
True Blue
PostPosted: 18:36 - 08 Nov 2007    Post subject: Reply with quote
Does it turn over and not fire, turn over and die, not turn over at all....???
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
b1g5m0k3
no spins same speed as usual
kiers
PostPosted: 18:39 - 08 Nov 2007    Post subject: Reply with quote
dead battery? :S
'but this wasn't any ordinary clio197.this was the SUPER DUPER version.
ooh i can't wait for the next instalment of superluke and his tales of skullduggery.' - lurker 27 sep 2008
b1g5m0k3
PostPosted: 18:40 - 08 Nov 2007    Post subject: Reply with quote
i press the electric start and it makes the noise like its trying to start but it dosent....
b1g5m0k3
PostPosted: 18:41 - 08 Nov 2007    Post subject: Reply with quote
no it dosent have a flat battery
Benrly
PostPosted: 18:49 - 08 Nov 2007    Post subject: Reply with quote
Turn the key, twist throttle 3-4 times, turn it off.
Turn the key, see if it will start up. Give it some throttle while holding the starter button.
If not, try the good ol' kickstart, or have you not got one?
b1g5m0k3
PostPosted: 18:51 - 08 Nov 2007    Post subject: Reply with quote
done all that
PostPosted: 18:53 - 08 Nov 2007    Post subject: Reply with quote
checked for a spark?
b1g5m0k3
PostPosted: 18:55 - 08 Nov 2007    Post subject: Reply with quote
ok guys the rains stopped and it works now.. fucking heap of shite... cant wait to get my 125!!!!!
THANKS FOR ALL UR HELPS
prowler
PostPosted: 19:07 - 08 Nov 2007    Post subject: Reply with quote
lol
Fahim
PostPosted: 19:09 - 08 Nov 2007    Post subject: Reply with quote
should of slipped it into 2/3 gear and got a few mates to start pushing! would of done the trick...still at least it works now, your saved!
Current Bike: CBR125 ---> Written off Theory Test Passed: ---> 8/04/08 ---> A2 Test Booked:8/05/08 - Failed to turn up (had an accident and broke my leg in 3 places!)
Benrly
PostPosted: 19:14 - 08 Nov 2007    Post subject: Reply with quote
Pretty sure we can safely say, using his grasp of the English language and his forum avatar, that he is a pedboi.
ram_doom
PostPosted: 19:19 - 08 Nov 2007    Post subject: Reply with quote
Spray everyhing with a mist of wd40, and make sure your battery terminals are screwed on tight. Mine always vibrate loose (should get some loctite on there really).
TL1000s, KDX200
b1g5m0k3
PostPosted: 19:24 - 08 Nov 2007    Post subject: Reply with quote
not for long Razz
Jamie S
PostPosted: 19:29 - 08 Nov 2007    Post subject: Reply with quote
Scooters hate getting wet , what will of happened, is, water will have made it's way down the back of the clocks , I suggest sealing its up properly with silicone.
PostPosted: 20:17 - 08 Nov 2007    Post subject: Reply with quote
How the hell did you guess that from those symptoms?
The last post was made 18 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 15 - Page Size: 116.06 Kb
