Whagwan wi me rear brake an ting?
Cigaro
PostPosted: 15:45 - 16 Nov 2007    Post subject: Whagwan wi me rear brake an ting? Reply with quote
The rear drum brake on my Cub seems to have an intermittent problem - occasionally (well, about once a day on average) when I put the brake on it makes a horrible 'Grinding' noise, like when you try to put a car into reverse when it's moving. If I let off and apply it again, it doesn't make the noise, and it doesn't seem to affect its stopping ability - overall the rear brake seems quite effective.
Pray tell, what could the problem be?
PostPosted: 16:06 - 16 Nov 2007    Post subject: Reply with quote
Well, it might have a stone or something in there.
The shoes sometimes wear unevenly too meaning only the front part of the pad touches down on the drum. This can be cured by putting a slight chamfer on the leading edge of the pad using some sandpaper.
Given how a C90 has a quick-detach rear wheel which takes all of 2 minutes to remove, I'd suggest you whip it off and have a look.
Ariel Badger
PostPosted: 22:10 - 16 Nov 2007    Post subject: Reply with quote
Could be a touch of water in the drum. Wet brakes slip but damp brakes can grab and judder.
The last post was made 18 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 8.93 - MySQL Queries: 13 - Page Size: 40.18 Kb
