| Dalemac |
 Dalemac World Chat Champion
| big.bee.time |
 big.bee.time Nova Slayer
| Dalemac |
| stinkwheel |
 Posted: 16:34 - 22 Nov 2007 Post subject: |
Hmm. Odd. Check the wire leading into the main fuse on the side of the solenid for corrosion.
WD40 and wiggle the ignition switch back and forth a bit. Same with the kill switch.
Could be the idiot switches playing up such as the sidestand switch, is the neutral light coming on?
Or obviously your alarm could be an issue. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dalemac |
 Posted: 16:48 - 22 Nov 2007 Post subject: |
yeah the neutral light is coming on.
Funnily enough, i got rid of the old sola alarm a month ago, and replaced it with an alarm from the net.
Its been working ok, getting a bit hard to start it, but now it wont start at all.
fuse looks fine to me.
Have tried the wd40 trick on the ignition and have flicked the kill switch back and fourth after spraying wd40.
i cant do anything elts tonight, its threatening to rain and i only have my driveway to work....not got a garrage
what in the alarm could be causing an issue? the alarm is functioning exactly has it has since i changed the alarms.
YBR125 -> GPZ500S -> SL1000 |
| stinkwheel |
 Posted: 16:56 - 22 Nov 2007 Post subject: |
Depends on how it is connected in and if it incorporates an immobaliser.
The safety interlock switch system could definately cause this sort of problem (eg sidestand switch). If you were to temporarily connect the black on green wire coming out of the IC igniter box to earth, it would bypass the entire ignition "idiot switch" cutout system.
If you were just suspicious of the sidestand switch, follow the wire up from the switch until you find the connector block, pull it apart then bridge the two wires on the bike side (a bent paperclip works fine as a temporary measure to see if this is the problem).
Failing all that, try giving the fuse-box several sharp thumps with the heel of your hand as you try to start it. There are a few microrelays in there that can stick. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dalemac |
| Dalemac |
| stinkwheel |
 Posted: 14:52 - 27 Nov 2007 Post subject: |
Remember. After the CDI box, all the ignition componants are seperate for each cylinder. It is highly unlikely that eg. both coils would have gone similtaneously.
If neither plug is sparking, the problem is almost certainly either the CDI system, the inputs to the CDI (pulse coils and power supply) or the safety cutout system.
Of these the safety cutout system is most likely to malfunction and is easiest to check.
If it was my bike. The first thing I'd do after charging the battery and checking to see if it works is to temporarily bypass the sidestand switch by jamming a bent paper clip into the connector block for it. If that did the trick. I'd permanantly bypass it by soldering the two wires together.
I'll go further. With my bikes, I have pre-empively bypassed the sidestand switches before they have a chance to leave me stranded in the middle of nowhere. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dalemac |
| stinkwheel |
 Posted: 00:55 - 28 Nov 2007 Post subject: |
I absolutely garauntee that sticking clutch plates won't prevent the bike starting if you're in neutral. Not even if someone sneaked into your lockup overnight, stripped the clutch and superglued them together.
So, what else has been fiddled with in the circumstance you just described? 2 things as far as I can see.
1) The bike is no longer in neutral.
2) The clutch is pulled in (and so is the clutch switch).
Next time it won't start. Humor me by just pulling in the clutch and seeing if it'll start then. If it does, switch off and try again without the clutch pulled in just to prove the point. If it'll only start with the clutch pulled in, this will isolate the fault to a very specific part of the wiring. The part between the fuse-box and the neutral switch in particular. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dalemac |
| stinkwheel |
 Posted: 02:13 - 11 Jan 2008 Post subject: |
I'll tell you one thing. There are two sets of coils on a GPZ500s. What's the chance that both of them failed at the same time?
In short, it isn't your coils unless there is a fault affecting one cylinder only. If there is, swap the coils over and see if the problem changes sides.
Saved you some money right there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dalemac |
The last post was made 18 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
