Spare a moment, think of teh batterys!
mr.z
PostPosted: 18:34 - 22 Nov 2007    Post subject: Spare a moment, think of teh batterys! Reply with quote
Winter is officially here for anyone who didn't notice. Fridays forecast for here says -2ºc
Batterys (conventional ones anyway) don't work as well in colder temps, and bikes can be harder to start as it is! so its especially important to keep yours in tip top condition if you don't want to be running up and down the road trying to bump it.
Its not something you'll tend to think about till it goes wrong, but all you need to do is spend 30minutes topping it up/checking every so often, mine has been playing up a bit an I've only just got around to topping it up myself.
Get yourself to a supermarket and find some "de-ionised water" possibly near ironing related things. You could use tap water but DON'T USE TAP WATER if you know anyone who's had a face full of acid they will tell you its not very nice.
Simply take the tops off (one at a time to save dirt getting in), being careful not to let any crap into the electrolite below, get it to the max mark on the side and close it up. You can shine a torch down the hole and jiggle the bike if its akward to see down. In this case its easier to do it in the dark. A syringe is helpfull here, ebay you can buy them (also handy for petrol, oil, fork oil e.t.c.)
Next thing is to give it a charge, trickle chargers can be got off ebay for £5 and can also be used for gel batterys.
Anyone with a sealed battery can be smug right now (and the three or so of you without a battery can be smugger still) but there pricey, so a trickle charger is worth a thought, being so cheap, and gel batterys being so pricey.
Anyone with anything to add feel free.
PostPosted: 18:50 - 22 Nov 2007    Post subject: Reply with quote
Aye. Don't fiddle about trying to do this on the bike with a torch. Take the bloody thing off and do it somewhere you can see what you're doing properly.
Give the outside a wipe with a damp cloth before checking the cells. Top up with de-ionised water. Make sure the terminals are free of corrosion.
Charge it if you wish.
Then put it back on the bike, tighten the connectors down properly and cover the terminals with a blob of copper grease or vaseline to keep corrosion out.
Paddy Blake
PostPosted: 18:56 - 22 Nov 2007    Post subject: Reply with quote
I bought one of these.
https://www.maplin.co.uk/Module.aspx?ModuleNo=49038&TabID=1&source=1&doy=22m11
Works for me. Thumbs Up
Paddy.
mr.z
PostPosted: 19:02 - 22 Nov 2007    Post subject: Reply with quote
In retrospect i should have taken this one off, the last one was very easy to see through (even without a torch), this ones bloody difficult to see through.
As stinkwheel says you don't have to charge it when you top up, it'll sort itself all being well, if its really struggling you can turn off the lights for a few miles and see how it is then.
sickpup
Old Timer
PostPosted: 19:40 - 22 Nov 2007    Post subject: Battery prices to rise. Reply with quote
I had a warning last month from my battery supplier to expect the prices of batteries to more than double over this winter.
The wholesale price of lead per ton has jumped from $1500 in October 06 to $3800 this October and it's still increasing.
PostPosted: 19:48 - 22 Nov 2007    Post subject: Re: Battery prices to rise. Reply with quote
*Gets ladder out and heads for nearest church roof*
Fisty
PostPosted: 20:01 - 22 Nov 2007    Post subject: Reply with quote
The theft of lead from churches round here is mental. the have even been taking brass from peoples letterboxes and door numbers!
Fatter and faster than Fret
sickpup
Old Timer
PostPosted: 20:09 - 22 Nov 2007    Post subject: Re: Battery prices to rise. Reply with quote
What I thought as well, buy in price is at £1000 a ton at the scrap merchants.
virus
PostPosted: 20:09 - 22 Nov 2007    Post subject: Reply with quote
checked the CGs battery a few weeks back to find it had cracked across the bottom and only 2 cells had any fluid in, brand new battery in and a 12/12 getting charged to put in my ammo crate on the back wired in parallel to the standard to keep some oomph going through.
John
p.s. would a 6 volt light work on a 12 volt system properly? i need a small cheap bright spotlight to rig in and ive got an old 6v push bike jobby in the shed.
own: 81 xs1100g...
LeeWat
PostPosted: 20:23 - 22 Nov 2007    Post subject: Reply with quote
I think a 6v bulb would just burn out if you put it on a 12v circuit.
Simson S51 Enduro, Kawasaki AR80, Yamaha RD125LC, Yamaha XV535, Yamaha XJ600N, Suzuki GS1100G, Kawasaki KLR250, Yamaha BT1100 Bulldog (4/4/08 Deceased). Suzuki XF650 Breakwind.
Finglonga
PostPosted: 20:26 - 22 Nov 2007    Post subject: Reply with quote
John
Not with the cracked knackred battery I hope. It will bugger up the new battery straight away and the old one could explode. Plus battery + Metal Ammo crate is not the brightest idea, especially if the battery falls over or you are involved in an accident.
Best thing to do is get a decent Gel or glass mat battery then you don't have to piss about with water.
No think about it, it will blow as soon as turned on.
Andy Sez....
F.Y.Y.F.F.
Itchy
PostPosted: 20:28 - 22 Nov 2007    Post subject: Re: Battery prices to rise. Reply with quote
I was just thinking this since my NTV battery died a few days ago, and thus it using me CBR battery,
Do you supply batteries?.
sickpup
Old Timer
PostPosted: 20:31 - 22 Nov 2007    Post subject: Re: Battery prices to rise. Reply with quote
Yes. Problem is the postage on them is £10. Plus side is they are completely sealed and last well, just ask Phantomtek.
PostPosted: 20:47 - 22 Nov 2007    Post subject: Reply with quote
And to think I was getting grief for the pile of duff motorcycle batteries in my back yard. By that reckoning there must be about £50 of lead there now.
sickpup
Old Timer
PostPosted: 20:54 - 22 Nov 2007    Post subject: Reply with quote
Probably less. Due to regs with clear ups on batteries they only go for £200 a ton but when you consider the weight of your average car batteries that doesn't take all that many.
Itchy
PostPosted: 20:55 - 22 Nov 2007    Post subject: Reply with quote
how exactly do you sell this scrap metal? ,
road signs around bolton went missing recently before being replaced by plastic ones,
you just go to a scrap yard and hand it over? (I'd have made a killing on copper a year back I have an enourmous number of copper coins),
I also amassed about 500 kilos of scrap aluminium but alas not sure where to sell it anymore since a local junk yard folded.
sickpup
Old Timer
PostPosted: 21:08 - 22 Nov 2007    Post subject: Reply with quote
Find a new scrap merchant. 500 kilos of Ali is worth about £300.
mr.z
PostPosted: 21:28 - 22 Nov 2007    Post subject: Reply with quote
if the battery's were melted down (ala world fastest indian) there'd be no problem?
How much are glass mat batterys at the moment? three figures?
Not surprised the costs of lead and copper e.t.c. same with steel, allot is down to the huge demand from china and others (but mostly china) its not likely to get any better any time soon either Sad
Dalemac
PostPosted: 11:49 - 23 Nov 2007    Post subject: Reply with quote
Do gel batteries charge the same as conventional battery's?
i.e plug it into an optimate?
would something like this work?
https://www.maplin.co.uk/Module.aspx?ModuleNo=37762&criteria=12v%20charger&doy=23m11
YBR125 -> GPZ500S -> SL1000
virus
PostPosted: 12:38 - 23 Nov 2007    Post subject: Reply with quote
Finglonga wrote:
John
got a brand new 2.5 amp standard battery in the cg now, and a 12 amp battery secured in my crate, dont see why i shouldnt use a normal battery incase i have an accident, by that logic i should walk everywere as ive got less risk of crashing Karma
ill rig up an old 12v 10w bulb into the little spot then
John
own: 81 xs1100g...
Finglonga
PostPosted: 14:11 - 23 Nov 2007    Post subject: Reply with quote
John
So if you have an accident your battery shorts out in the metal box and your bike goes up in flames, or Acid everywhere. Got nothing to do with not crashing its about common sense with the dangers of high amp batteries in metal boxes.
What are you going to light up with a 10w bulb? You may as well take a candle out with you it would be brighter. Wink
If you had uprated your bikes battery you would have more power, be safer and not lugging around more weight. Bit overkill on a small bike IMO.
Andy Sez....
F.Y.Y.F.F.
mr.z
PostPosted: 14:15 - 23 Nov 2007    Post subject: Reply with quote
As nath about his battery Laughing
You'll want a 30watt really to be doing much at all, i'd reccomend some driveing (not fog) lamps, just one is enough in fact.
The cg does have a pish poor headlight, a new shell and H4 bulbs should fix it if its causing bother.
Dalemac
PostPosted: 15:35 - 23 Nov 2007    Post subject: Reply with quote
so can gel batteries be charged by normal 12v trickle chargers?
ive got a solar powered 12 trickle charger at home and my gel battery needs charging!
Finglonga
PostPosted: 16:46 - 23 Nov 2007    Post subject: Reply with quote
Yes but only to keep it fully charged. if its down it will need a proper charger to get it up to power than keep the solar one on to keep it there. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
veeeffarr
PostPosted: 17:06 - 23 Nov 2007    Post subject: Reply with quote
"The green reaper" are selling Optimate III SP's for about £25 IIRC.
The last post was made 18 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 5.11 - MySQL Queries: 13 - Page Size: 137.31 Kb
