Car sat navs on the bike.
kawakid
PostPosted: 23:15 - 22 Nov 2007    Post subject: Car sat navs on the bike. Reply with quote
Hi,
I've currently got a perfectly adequate "for a car" Tom Tom one, which I have no problems with at all.
Anyway I've found this American site https://www.mountguys.com/category_s/78.htm
And they supply mounts for bikes for my GPS and others.
Anyway has anyone got experience of using one on a bike?
Was it usable? Did you use a headphone? Was it okay just to quickly glance? What happened when it started raining ie how quick to get off and safe.
I know I'll probably have to set the route before I set off as gloves will be problematic/
To be honest at £25 all in (Thanks to the poor American economy), it seems a good price. I'm okay with the electrics and have a switched relay already that could power it.
I've a twin and a 4.
mr.z
PostPosted: 23:26 - 22 Nov 2007    Post subject: Reply with quote
If they are ram mounts your talking about yes i have, there very very good for the price.
To wire it in just run it off the pilot light wire, its switch and more than adequate to power both your gps and the light. Its also up the front, you will obviously still need the 12v adapter.
The mount is all well and good but unless its the rider your going to have problems when it rains, which being the uk, could be at any time whatsoever, lack of clouds or otherwise.. tbh i'd not be happy at all rideing with it uncovered, you could mash up some kind of plastic bag to go on it to protect it, but it'll be a pain in the arse to use, you'll have to refit it every time e.t.c.
I got a garmin gps3deluxe recently for £70 off ebay, mount wasn't much.. just a thought.
McJamweasel
BCF Junkie
PostPosted: 23:31 - 22 Nov 2007    Post subject: Reply with quote
I've got a Garmin i3 with a bike mount, I've used it without sound and a quick glance is usually good enough for me. For weather protection I used a freezer bag type thing, which did me well enough for 1500 miles around Europe.
matthab
PostPosted: 00:20 - 23 Nov 2007    Post subject: Reply with quote
My Ram mount on my Rider V2 was abit of a pain to fit but finally got there. I love the Bluetooth headset and the features it allows me to do like take calls and listen to instructions clearly. I can get my GPS off in seconds and plnnaing routes is easily done with gloves on suprisingly. I dont noramlly use the head set just have a quick glance to check if im on the right road.
Ive just got the mount for the car for it and thats very good aswell.
Try these https://www.ram-mount-uk.com/index.htm
2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen)
PostPosted: 00:50 - 23 Nov 2007    Post subject: Reply with quote
I just use a oxford magnetic tank bag and put it in the map pouch.
lewi46
PostPosted: 01:12 - 23 Nov 2007    Post subject: Reply with quote
this may help you my friend has a nokia N95 the one with sat nav and all he does is put his headphones on and puts it in his pocket he sed it was fine he had no trouble. i no a tom tom may be a bit big to put in your pocket but my main point is that he manged fine with just listening to it.
Bike - Aprilia RS 125 2007 Spains number 1 edition
Aprilia RS 125 V.S. people carrier, Aprilia and me lost big time.
Bike - Kawasaki ZXR 400 L1 (Y)
map
Mr Calendar
PostPosted: 12:35 - 23 Nov 2007    Post subject: Reply with quote
If you want a Sat-Nav for both then I'd suggest looking at the Garmin stuff. They're more ruggedised and designed for use outdoors and on boats. I've got the (very) old Garmin StreetPilot III and it's a brick but suited for use on the bike. I'd also give a big thumbs up for the RAM mount kit. Good stuff that does exactly what it says on the tin.
Also FWIW gpsw.co.uk often have clearance and reconditioned Garmin kit on offer and they can also supply all the RAM mount stuff. I've also found them helpful if you 'phone or email with any questions.
HTH Thumbs Up
deanoet
PostPosted: 16:29 - 23 Nov 2007    Post subject: Reply with quote
You can get handlebar bags as well, spotted them on Hein Gericke as i am looking to do exactly the same as you.
That one hasnt got a clear plastic pouch on it, but one must be around somewhere that does, just a case of hunting one down. Smile
Looking down at the tank seems to be a bit awkward, at least on a CG125, but down at where the handlebars are is a lot easier, as you can still see the road
if you find one, let me know. Thumbs Up
veeeffarr
PostPosted: 16:44 - 23 Nov 2007    Post subject: Reply with quote
Baglux do GPS tankbags.
I've got a RAM mount for my (IPX7 waterproof) Zumo 550 and it's the dog's bollocks.
T
mr.z
PostPosted: 17:01 - 23 Nov 2007    Post subject: Reply with quote
I've had a garmins for a while
etrex
III
III+
i3
and now
Streetpilot III Deluxe
All of which i've used the same ram mount for, (although modified) to fit each one.
If you don't mind the brickisness (and it really is brick sized and with the batterys in weights similar) of the IIID, its fully waterproof (can be submerged) the address entering can be fiddley, and recalcing is a bit on the slow side compared to newer ones, but appart from that its pretty damn good, voice works as well as any out today.
PostPosted: 17:29 - 23 Nov 2007    Post subject: Reply with quote
I've got an 02 XDA orbit, and the audio directions are really just a reminder. On a bike I think I would use a map pocket or tank bag to hold the unit, its phone shaped anyway so it won't move about. I haven't had a chance to try it yet, but plan to soon.
I could understand having trouble with something like a Tom Tom though, with it being shaped like a CRT and all.
stooster
PostPosted: 22:18 - 23 Nov 2007    Post subject: Reply with quote
i use an old HP sat nav which is fine in the car.......i pop it in my top pocket with earplugs and the listen only works just fine....
i once used the sucker bit and stuck it to fairing.....woeked well until i got on motorway fast lane and the mount snapped because of vibration....riding one handed whilst trying to catch a falling sat nav then holding onto it at 90mph aint that much fun Wink
past - er5 - sv650s - drz400s - cbr 600 - gsxr 750 - lambretta gp mugello
present - vespa adidas px - fz6n
Peirre oBollox
PostPosted: 16:50 - 24 Nov 2007    Post subject: Reply with quote
for bike specific satnav mountings try https://www.gadgetguy.net/ good quality kit, that mounts onto the yolks see the photo gallery for mounting ideas.
i`ve got 1 on the way for a zumo (Mk1 bracket and mk2 mounting for zumo), but at around £90 it ain`t cheap but it is quality.
the other issues of using car based satnavs on bikes are the 1`s that have been said previously, and problems with water proofing (inc moisture in tank bags/map pockets) and vibration, that will literally shake stuff like PDA`s to bits
The last post was made 18 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.29 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 81.37 Kb
