Stupid MS Access!!!
Yoko
PostPosted: 10:34 - 23 Nov 2007    Post subject: Stupid MS Access!!! Reply with quote
Right I'm trying to write a query that if a form tickbox is ticked it applies a certain criteria to a field and if its not ticked it returns everything (as if no criteria was specified).
I tried:
Code:
Is NOT Null
Which worked as expected... Doesnt return the empties so...
Code:
Is NOT Null OR Is Null
Again worked as expected... Returns everything...
However...
Code:
IIf ( True, Is Not Null, "Some Criteria" )
Returns Nothing...
Similarly...
Code:
IIf ( True, Is Not Null or Is Null, "Some Criteria" )
Comes back with...
The expression is typed incorrectly or is too complex
Where is the logic in that?!?!
Confused Evil or Very Mad
Sheep Shagger
PostPosted: 11:24 - 23 Nov 2007    Post subject: Reply with quote
Err, that isn't IIF syntax.
Should be iif ( condition, value_if_true, value_if_false ).
Yours seems to be saying if True is True then return "Is Null Or Is Not Null" (god knows what it would try and return).
JonB
Afraid of Mileage
PostPosted: 11:30 - 23 Nov 2007    Post subject: Reply with quote
And why would you be using database software?
Haven't got 2 new CD's recently have you? Razz
Yoko
PostPosted: 11:58 - 23 Nov 2007    Post subject: Reply with quote
Err not really, the condition is a questions which returns true or false, I've simply left out the question and given it the answer.
Eg:
IIf ( True, do a, do b ) will 'do a' likewise
IIf ( False, do a, do b ) will 'do b'
I dont actually use that statement in my query, it was just do demonstrate that 'Is Not Null' doesnt work when imbedded in an IIf statement.
Why can I use it in normal criteria and not in an if statement. Doesnt make sense to me.
What I want is an IIf statement that if a button in my form is ticked no criteria is specified (and therefore everything is returned), if its unticked then a list box becomes enabled and the user specifies a criteria from the list box which is then passed to the criteria in the query.
'Is Null or Is not Null' returns everything, which is what I want it to do if the button is ticked.
Is null = Everything that is empty
Is not null = Everything that is not empty
Is null or is not null = Everything that is empty or is not empty
Saying IIf ( 'button ticked' (aka true Wink) , , 'criteria from list box')
Is the same as saying...
IIf ( 'button ticked', "", 'criteria from list box')
In which case when the button is ticked it will return everything with an empty string in that field. Which is not what I want...
Anyway I've now overcome my problem a different way but still doesnt make sense why you can say "something" in an IIf statement but not 'is null' or 'is not null' or 'is null or is not null'
Shifty
Sheep Shagger
PostPosted: 13:14 - 23 Nov 2007    Post subject: Reply with quote
"Is Null" and "Is Not Null" are SQL, while "IsNull" is VBA. IIF if VBA code so presume you would need the VBA check within there rather than the SQL check.
The last post was made 18 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.34 Sec - Server Load: 5.32 - MySQL Queries: 13 - Page Size: 49.71 Kb
