Windows live messenger
Resurrection
Ballast Boy
PostPosted: 18:17 - 23 Nov 2007    Post subject: Windows live messenger Reply with quote
Ahh somebody help!
Its not been working for weeks but ive not really been here so its not bothered me.
It's saying my firewall may be blocking it but the windows one wasn't even turned on but it was allowing messenger anyway!
I've tried re installing and alsorts but i cant sign in.
Help!
Res
ZX9r
T1z3R
PostPosted: 18:22 - 23 Nov 2007    Post subject: Reply with quote
do you get any error codes if you run the troubleshooting?
duck my sick!
Resurrection
Ballast Boy
PostPosted: 18:26 - 23 Nov 2007    Post subject: Reply with quote
Yeah i get: 80048820
and extended code error: 8004840f
Also when i run trouble shooting its saying IE cannot connect to the net.
I use FF
Res
ZX9r
T1z3R
MSN uses the same settings that are found in the network settings of IE. check in there to see whats up. if you get IE connecting the MSN will too.
duck my sick!
Resurrection
Ballast Boy
PostPosted: 18:49 - 23 Nov 2007    Post subject: Reply with quote
Yeah thanks sorted it.
Goddam proxy!
Res
ZX9r
Jaloopa
PostPosted: 19:18 - 23 Nov 2007    Post subject: Reply with quote
I once had a toolbar installed in IE that tried to connect to the internet every time you used it. Not a major problem in a browser but it also installed itself in Windows Explorer and tried to connect every time I opened, for example, My Computer.
I was on dialup at the time, so when I was offline it was usually because I needed the phone line, or just wasn't using the internet so wanted to be able to receive calls. The only way to stop the connection window coming up every time I opened a folder was to tell Explorer to work offline. All well and good, and since I used firefox at the time it didn't affect anything. Until I wanted to use messenger. If I wanted to sign in I needed to open IE, turn off the "Work offline" option and close it again, which let me use Messenger. Then when I was offline again and opened a folder I had to go through the rigmarole of changing the settings again.
Anyway, sorry to derail, the short form of this post would be "IE sucks. Windows Live Messenger sucks"
mattsprattuk wrote: but at least the lifan could do like 104mph in 3rd gear
The last post was made 18 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.9 - MySQL Queries: 13 - Page Size: 46.78 Kb
