Just a qick question
FROGGYRIBBIT
PostPosted: 18:02 - 24 Nov 2007    Post subject: Just a qick question Reply with quote
Does anyone elses drum brakes squeek and become shaper when there bike is left out in the rain if not whats causing it ???
If it aint broken dont fix it
Jamie S
PostPosted: 18:08 - 24 Nov 2007    Post subject: Reply with quote
Well the water is causing the squeak. Oh ,and my drum brakes get worse in the wet.
Shay HTFC
PostPosted: 18:15 - 24 Nov 2007    Post subject: Reply with quote
Yeah.. mine do the same. Embarrassing when you're in traffic at the beginning of the journey and you're squeaking away loads.
Goes away after a few mins though in my case.
FROGGYRIBBIT
PostPosted: 18:48 - 24 Nov 2007    Post subject: Reply with quote
can i spray somthing like wd40 in there to clean them or will it be too slippy
Jamie S
PostPosted: 18:51 - 24 Nov 2007    Post subject: Reply with quote
Whoa don't be stupid mate ! Christ.
spikenipple
PostPosted: 18:52 - 24 Nov 2007    Post subject: Reply with quote
It's not the best of ideas to spray a lubricant into a friction-dependant mechanism to be honest.
Try undoing the brake adjuster 180 degrees and see if that helps.
Edit: You couldn't try being a little more helpful Jamie?
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
Damon
PostPosted: 18:53 - 24 Nov 2007    Post subject: Reply with quote
not unless you dont mind not stopping... ever....
Shay HTFC
PostPosted: 18:57 - 24 Nov 2007    Post subject: Reply with quote
Wait.. whats happening here? Is it a constant squeaking even when they are not applied, or is it just when you apply them?
I usually have to pump my brakes a bit on my quiet street till the squeaking stops.
FROGGYRIBBIT
PostPosted: 19:16 - 24 Nov 2007    Post subject: Reply with quote
Ni its just there squeeking when i brake and they seem really sharp at the begining of the ride then after a while there really shit to stop ???
Phil_P
PostPosted: 21:06 - 24 Nov 2007    Post subject: Reply with quote
When it's wet, if a bit of water is getting in then you are probably getting a film of rust on the brake lining which makes for a really effective braking surface against the brake shoes. After a couple of applications of the brake, the rust is worn off and the lining is smoothed out so braking is back to normal.
Guzzi cast iron disks are just the same.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
Ichy
PostPosted: 23:58 - 24 Nov 2007    Post subject: Reply with quote
Not the best idea!!! Rolling Eyes Its fucking stupid and dangerous. I think Jamie was trying to be helpful, in his own way, by ensuring the bloke still had the ability to stop.
hmmmnz
PostPosted: 08:53 - 25 Nov 2007    Post subject: Reply with quote
pop your wheel off and slide out the drum and look at the pad, it could be that they are worn and its the indicator(the little peice of metal that tells you to change the pads) that is squeeking.
if they are fine, clean out all the dust and crap with brake cleaner, available from halfrauds for a few quid
the humans are dead
I kick arse for the lord
FROGGYRIBBIT
PostPosted: 19:35 - 25 Nov 2007    Post subject: Reply with quote
yer sound and jamie no worries i didnt take offence i know you was only helping and yes i wipped them off and there was rust but the pads are fine
PostPosted: 23:25 - 25 Nov 2007    Post subject: Reply with quote
Make sure you don't breathe the dust, damp it down so you don't as it can do very nasty things to your lungs.
The last post was made 18 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 79.82 Kb
