Polishing frames?
R1stu
Shrek!
PostPosted: 23:09 - 10 Dec 2003    Post subject: Polishing frames? Reply with quote
I have just purchased a swingarm to polish up for the summer. Unlike wheels where you can use paint stripper (nitromorse) which would kill the alluminum, what is the best way to polish a frame / swingarm!?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 23:11 - 10 Dec 2003    Post subject: Reply with quote
My best advice would be not to. Trust me, it's going to take you fucking ages!
Annabella
Like a person, only smaller
PostPosted: 23:13 - 10 Dec 2003    Post subject: Reply with quote
Elbow grease. Very Happy
There really isn't an easy way as far as I know. I used to work for a surface treatment company, and a colleague decided it would be a great idea to polish his frame with the polishing equipment we used in the lab....
...Needless to say we were falling over his blade for the following month while he used the polishing wheel and diamond paste on his frame. Apparently the costs amounted including the polishing papars and the diamond paste totalled over £200 (although it was Moaning Mick who worked that out) Shocked.
However you decide to do it - Good Luck Very Happy
Avast! Pirates ahoy!
I did Cadwell! Very Happy
R1stu
Shrek!
PostPosted: 23:26 - 10 Dec 2003    Post subject: Reply with quote
I know its going to take ages, thats why im starting it now! Shocked What I need to know, is what to use?
eg.
1) Drill
2) Sand paper
3) Some paste
4) get someone else to do it.
PostPosted: 23:28 - 10 Dec 2003    Post subject: Reply with quote
What you are trying to take off is the anodising. This stops the frame from corroding and also makes it marginally stronger. If you want a weaker frame that is prone to corroding then go for it.
As to what to use you are probably best off just using fine wet and dry paper. As the anodising is basically part of the aluminium then the paint stripper will not have any real beneficial effect.
All the
4 Laughing
R1stu
Shrek!
PostPosted: 23:30 - 10 Dec 2003    Post subject: Reply with quote
This is where the keeping of the old swingarm comes in! Every winter I can put the old SA back on and keep the other one all nice and shiny! Razz
My bike is comming on now, starting to look good!
Robby
Dirty Old Man
PostPosted: 23:53 - 10 Dec 2003    Post subject: Reply with quote
Why bother, you'll only crash it or get it nicked again.
R1stu
Shrek!
PostPosted: 00:17 - 11 Dec 2003    Post subject: Reply with quote
Dear oh me robby! you are the most cheerfull one! If I crash it, I have a spare swingarm Razz and its upto me!
Scotty
Scooter Boi
PostPosted: 00:54 - 11 Dec 2003    Post subject: Reply with quote
Stu, go for it i say.
If your not polishing the frame, you'd probably end up polishing other bits Wink
and least the frame will tke longer to polish off Wink
Regards
Scott
PostPosted: 09:58 - 11 Dec 2003    Post subject: Reply with quote
Polished swingarms, Carbon fibre ram air covers, changing swingarms for the summer?
<G/Dusty/MarJay mode> www.tartshandbag.co.uk</G/Dusty/MarJay mode>
Razz
Hex
Party Boy
PostPosted: 10:07 - 11 Dec 2003    Post subject: Reply with quote
If your doing the swing arm my advice would be not to do it all, only do what you will see ie the outsides of it, you'll not really get any benefit from doing the inside.
That will save you a bit of time straight off.
An orbital sander with some rough wet and dry to start with will take the top coating off so you can then start sanding properly.
Work down the different grits each time making sure you have taken out all the deeper scratches caused by the grade you are using as when you move down a grit you will end up having to go back up to remove the deeper scratch.
Don't use a drill and flap wheel if thats what you where planning as you will probably end up with low spots etc as trying to keep a drill at an even pressure across the surface will be ni-on impossible (thus the orbital sander advice).
When your down to a low grit you may want to move to either wire wool or polishing paste stuff (this is where the super hard work starts by hand).
Other tips would be go along the arm not across it, take your time don't rush and good luck.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
chunkielad
PostPosted: 10:12 - 11 Dec 2003    Post subject: Reply with quote
When it is done, which will take eons!!!!! Get it powder coated in clear that way it won't corrode as easily!!!
Mark Harrison R.I.P - 26th March 2003.
Remember you always and will ride in your honour.
Big revvs up for Mark!
Hex
Party Boy
PostPosted: 10:27 - 11 Dec 2003    Post subject: Reply with quote
You may find that a powder coating won't stick, or the surface will have to be etched first so the mirror finish will be spoilt.
Just general cleaning should be enough to be honest and say every couple of months polish with a proper aluminum polish which will remove oxidation and help prevent it.
Scotty
Scooter Boi
PostPosted: 12:09 - 11 Dec 2003    Post subject: Reply with quote
The only bit thats polished on my bike, is the foot rest hangers, which have been worn down by peoples feet.
Looks cool though.
Although it has took about 14 years Wink
Regards
Scott
divuk83
PostPosted: 15:02 - 11 Dec 2003    Post subject: Reply with quote
Just pay some one to polish it mate, if you want a mirror finish then that is the best way. Most chromers/powdercoaters will be able to do it for you in a fraction on the time it will take you.
I have been polishing stuff myself for the last few days. Just used a quids worth of wet and dry paper then gone over it with a cheapo polishing kit that fits to a power drill, it looks OK, took ages though.
Its a piaggio engine cover BTW
https://www.divuk83.com/images/bike/cover3.jpg
This is what a my mate paid a polisher about 20 squid for, its like a mirror!
https://www.divuk83.com/images/bike/cover4.jpg
Hex
Party Boy
PostPosted: 15:23 - 11 Dec 2003    Post subject: Reply with quote
Your mates looks like it has been chromed not polished though. Theres quite a difference.
divuk83
PostPosted: 15:25 - 11 Dec 2003    Post subject: Reply with quote
yeah, its well impressive. but believe it or not, it has only been polished. cost him about 20 squid and was done in a few hours. where as mine took yesterday afternoon and this morning!
Hex
Party Boy
PostPosted: 15:31 - 11 Dec 2003    Post subject: Reply with quote
Fair enuf, you cant beat a nice polisher though to do the job in a fraction of the time. Very Happy
I'm planning on doing my mini moto frame (time allowing) I know I could do it here, but if I took it up to my fathers garage I know i could do it in half the time on the buffing equipment.
Dusty
King of the Rim
PostPosted: 15:51 - 11 Dec 2003    Post subject: Reply with quote
Noooo Gav, Rolling Eyes don't do the mini moto, get it powder coated black, imho it'll look way better.
Gallery
Hex
Party Boy
PostPosted: 16:23 - 11 Dec 2003    Post subject: Reply with quote
But that costs money - also I was thinking shiny metal parts and black body work.
Once I get a black tank I'll paint the fairings etc.
There again it all comes down to the point where I go "Hmm can I be bothered", and even though it means I get to polish stuff the answer may still well be no for the moment.
Dusty
King of the Rim
PostPosted: 16:42 - 11 Dec 2003    Post subject: Reply with quote
hmmm, might look quite cool with black body work, although I reckon the wheels would have to be shinned up too. Confused
Gallery
Hex
Party Boy
PostPosted: 16:50 - 11 Dec 2003    Post subject: Reply with quote
Hmm hadn't considered the wheels, hmm that could look well cool.
Black body work (few decals maybe or a flash of colour) and a polished frame and wheels, could look nice till I wrap it round a trye wall. Laughing
Scotty
Scooter Boi
PostPosted: 17:32 - 11 Dec 2003    Post subject: Reply with quote
I'll wrap it round a tire wall, i do that well Very Happy
And polised frame and black body work... it'll look like a mini aprilla.
Very Happy
Get some mini CBR stickers for it, and call it mini me...
Regards
Scott
R1stu
Shrek!
PostPosted: 22:00 - 11 Dec 2003    Post subject: Reply with quote
Ok well here is a picture of the swingarm as I got it this morning! I will be filling you in on the progress of the polishing as we go like the Go-Kart.
So with my cordless sander and wet and dry paper, plus autosol.
We can see how it goes!!
The last post was made 22 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 132.76 Kb
