Halfords bike builder...
Dischord
PostPosted: 22:38 - 26 Nov 2007    Post subject: Halfords bike builder... Reply with quote
got a 'test' there tomorrow but not sure what it's gonna involve.
I can put on handle bars, wheels, tyres, brakes etc but does anyone know if I'm gonna have to build up the crank and headstock as I'm a bit of a newb with that.
2012 KTM EXC 250
D O G
PostPosted: 23:20 - 26 Nov 2007    Post subject: Reply with quote
I would doubt it TBH - I think your knowledge is quite sufficient - their bikes will almost certainly come in with the bottom bracket installed.
Building headstock is a piece of piss - just make sure;
1 - you get the bearings and carriers in the correct order
2 - you nip it all nicely together with the top bolt (i.e. the vertical one), but not too tight, as it is the headstem which goes on nice and tight and really prevents the forks dropping out. (clearly you will need the stem and any spacers on the fork tube first).
Other than that I think you'll be ok - though I don't know much about MTB stuff, I'm ok with proper bikes Wink
Good luck
Ariel Badger
PostPosted: 23:47 - 26 Nov 2007    Post subject: Reply with quote
If it is the Halfords in Digbeth, Brum hands off the nice Asian chick on checkout. Mr. Green
D O G
PostPosted: 23:58 - 26 Nov 2007    Post subject: Reply with quote
You must be drowning in Stilton and car fresheners in your house Ariel!
Ghost
PostPosted: 00:04 - 27 Nov 2007    Post subject: Reply with quote
The bikes in Halfords come with the cranks, chainrings and bottom bracket already assembled, but pedals are either missing or you get two left hand ones and no right ones. Back wheel is normally already in but the gears will need setting up. Forks will already be in, but you'll need to put the handlebars and steerer in and tighten it up. Front wheel on, adjust front and back brakes and all the other things like saddle, seatpost, reflectors, bells, etc. Takes about half an hour to do one, maybe longer.
Dischord
PostPosted: 00:09 - 27 Nov 2007    Post subject: Reply with quote
Good luck
Cheers for the info! Very Happy
You know what mate, that's spot-on! Can find anything out on BCF! I was hoping it would be simple like that Thumbs Up thanks again!
EDIT - Two small things? by setting up the gears do you mean just putting the chain on and aligning it right between the front and rear sprcokets/chainrings? also what do you mean by steerer? Sorry just don't wanna get down there and be faced with something I can't solve as this job would come in handy over xmas now. Thumbs Up ta!
2012 KTM EXC 250
cagiva gezzer
PostPosted: 00:41 - 27 Nov 2007    Post subject: Reply with quote
There's a difference between a bike builder and someone who PDIs them before they go out the door.
TBH, no one expects a bike from halfrauds to be built well anyway. Thumbs Up
There's nothing you can't pick up on the job, but there's always neat tricks / tips that make the finished bike look / ride soo much better and lasts longer.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 11:05 - 27 Nov 2007    Post subject: Reply with quote
Ask the forums over on ukmb.net - there's a few there that work/have worked as a Halfords bike mech.
UnknownStuntm...
PostPosted: 11:44 - 27 Nov 2007    Post subject: Reply with quote
I was that soldier a few years ago. TBH as long as you can hold the right end of a hammer and know about how not to cross thread pedals when putting them on, you'll be fine.
It's worth bearing in mind that right NOW is the very busiest time of year for the bike boys in Halfords, they'll be getting hundreds of bikes delivered probably twice or three times a week to the shops, and a lot of time will be taken taking the stock in and arranging it so you can get to the bikes when you need them.
Lots of box shifting and probably some late nights.......
Then in January you can look forward to Mr and Mrs Bastard coming in with their son Antichrist who took a tumble while 'only going slowly' on his budget scaffold tube bike, over Ben fucking Nevis and broke every bone in his fatass too-tight-skinned body and how they want a refund and compensation. And the store manager will direct them to you and make a sharp exit.
Yeah good luck with that. Laughing
Visitor Q
$25 whore
PostPosted: 13:03 - 27 Nov 2007    Post subject: Reply with quote
Good job you're coming to mine to get ridiculously pissed after then eh poppet Laughing
Blinding Thumbs Up
Ghost
PostPosted: 23:36 - 27 Nov 2007    Post subject: Reply with quote
Nah, by setting up the gears I mean just adjusting the rear and front mechs so they shift up and down smoothly. At least, that's the idea, it becomes harder than it sounds once you take into account the gear cables made from elastic, plastic levers that bend like beckham, barrel adjusters that snap, limit adjuster screws made of cheese and mech cages of tin that twist under any force at all. Confused The chain will already be on and most of the time most brake and gear cables will already be attached, they'll just need routing and sorting properly.
Most Halfords bikes aren't sold with proper 'Aheadset' fittings i.e a steerer tube that's part of the forks, then a stem that bolts onto the top of the steerer and the handlebars. They're mostly the cheaper variant of steerer, stem and handlebars all being one piece of badly welded together junk. To assemble these you basically slacken off the allen key bolt on top of the steerer, slide the steerer down into the headtube of the frame, adjust it so it's pointing vaguely in the same direction as the front wheel and re-tighten the top allen key bolt. Make sure all your cables are routed the right way and voila, job done.
Hope this helps Cool Confused
D O G
PostPosted: 13:55 - 28 Nov 2007    Post subject: Reply with quote
Ghost, you have reminded me why I never recommend Halfords to anyone for bikes, nor have any work done there.
It is astonishing how crappy they are.
Cillit-BANG
PostPosted: 20:54 - 28 Nov 2007    Post subject: Reply with quote
As mentioned there is quite a large difference between building a bike, and getting one out of a box ready to be put through to a till asap.
Every nut, bearing, spoke, cable and bolt needs checking. Copperslip should be applied to the relevent areas. As a general rule of thumb you would work from front to back.
A proficient mechanic should be aiming for 30mins to 1 1/2hr depending on the complexity of the model. A novice may take twice that.
After your first 20-30 you'll be fine, and will be able to do it with your eyes shut. If your on piece work try to sort them so any similar models are done one after the other.
Looking back, I must have done thousands. Happy days.
Teaman
PostPosted: 21:03 - 28 Nov 2007    Post subject: Reply with quote
oh how right you are Very Happy
spent years being the mechanic for a company in sheffield. and worked for orbit bikes.
build so many wheels it's impossible to remember, from 1 cross to radial to snowflake and never had one break.
bike building is a doddle, setting them up safe for the road is next but as long as you know the basics and have all the correct tools its easy.
The ammount of times I've gone out on boxing day and seeing kids who have had there bike for xmas that there dads put together with the forks facing the wrong way and reflectors dragging in the spokes.
remember with spanner attathed pedal backwards with both cranks to tighted the pedals, (One if left hand thread, THE ONE WITH THE NOTCHES)
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Dischord
PostPosted: 15:53 - 30 Nov 2007    Post subject: Reply with quote
LOL cheers for all the replies! Got the job on wednesday and been working there since, to be fair it's quite an enjoyable job (not career material Razz ) Just searching for the bikes, building them, listening to radio one, chatting and drinking coffee!
As stated it was pretty simple after all (thanks) but the assistant manager is so meticulous about how he likes the brakes and gears set up it becomes tedious working to his standards.
2012 KTM EXC 250
UnknownStuntm...
PostPosted: 16:17 - 30 Nov 2007    Post subject: Reply with quote
Well just for your own peace of mind, listen to the man and pay very good attention to the brakes. Some of those shonky old RSJ tubed "bikes" have the brakes assembled but left loose (indonesian sweatshop muppetery I reckon) before they go in the box.
I remember having to tell everyone about a million times to check the brake pads were tight on the calipers... And like I said, Mr and Mrs Bastard will go to head office where someone from 'customer service' will tell them what a turd you were for not checking them....
But well done fella, good work. Oh, and just to make me smile, why not sneak a pic of the cycle warehouse in it's current state on here so that I may be smug? Laughing
Dischord
PostPosted: 19:18 - 30 Nov 2007    Post subject: Reply with quote
hehe I was thinking of taking a pic earlier but thought it would look dodgey, I'll get one for you on monday though! Very Happy
2012 KTM EXC 250
Teaman
PostPosted: 00:34 - 01 Dec 2007    Post subject: Reply with quote
such is life, the leading edge of the brake to be touching and the back endge slightly less than a mil away from the rim will be perfect to stop brake squeel, the brakes flex on most bikes, this will give best braking performance Very Happy, My standards are high aswell,
setting gears so there as smooth as silk was a pain in the arse at first but once you suss it you wouldn't have anything less mate.
UnknownStuntm...
PostPosted: 09:15 - 01 Dec 2007    Post subject: Reply with quote
Oh yeah one more thing (wait, this is two...) - stretch all the cables out before you adjust the brakes and gears. Give them a fucking MASSIVE pull to make sure. And with the spin on rear sprocket cheap chinese shit bikes, put the fucker in first gear and ride it with the brakes on to tighten the block. You'll be amazed what a difference it makes. Thumbs Up
Cillit-BANG
PostPosted: 18:07 - 01 Dec 2007    Post subject: Reply with quote
Or, whilst you have the wheel out anyway to check the bearings, you can simply drop it onto the suitable tool which is permantly fixed in the engineers vice behind you, along with the cassete lock-ring tool Smile
UnknownStuntm...
PostPosted: 19:20 - 01 Dec 2007    Post subject: Reply with quote
Yeah but even if you've whanged it up as tight as you can on that I GUARANTEE you can stand on the pedals hard enough to make it tighter.
PostPosted: 19:36 - 01 Dec 2007    Post subject: Reply with quote
For the record, don't try doing it with your eyes shut, as a lot of Halfords 'mechanics' do seem to do Razz.
ZRX61
Victor Meldrew
PostPosted: 00:32 - 02 Dec 2007    Post subject: Reply with quote
Not just on bicycles, I've lost count of how many times I've heard of people picking up there new bike only to find the caliper bolts hand tight... There was quite a spate of it with ZX9R a few years back & the dealers tried to blame the factory.. until they pointed out the calipers aren't bolted on at the factory...the assembly chimp at the dealership does that....
The last post was made 18 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 125.22 Kb
