| chris_rf600r |
 chris_rf600r Two Stroke Sniffer
| spikenipple |
 spikenipple Crazy Courier
| Phil_P |
 Phil_P Trackday Trickster
| Ichy |
 Ichy World Chat Champion
 Posted: 23:28 - 26 Nov 2007 Post subject: |
No use at all but I was just wondering what the thinners might do to the paint on the callipers and the seals?
The hydraulic system used by the braking system tends to be the best way of releasing a seized piston. I tend to take the pads out and put a piece of wood in one calliper to lock the pistons in place then pump away.
If you do use a g clamp then put a piece of wood against the body to stop any damage.
To be honest I find it quicker to strip and separate the calliper body then use my compressor to blow the pistons out. If anyone tries it then be warned, the pistons will take your head off if your not careful  |
| spikenipple |
| chris_rf600r |
| chris_rf600r |
 Posted: 00:32 - 27 Nov 2007 Post subject: |
Use a couple of G clamps to hold the pistons from popping out and pump them out a bit at a time (eg, pump them out to the G clamps, release the G clamps a bit and repeat). Otherwise likely the most free piston will just pop out first. Once the pistons are out then clean them up thoroughly. Pop the seals out carefully and clean the grooves they sit in. Preferably put new seals in.
Normal problem is that corrosion builds up behind the seals and forces them out to jam the pistons.
| Ichy |
| chris_rf600r |
The last post was made 18 years, 321 days ago. Instead of replying here, would creating a new thread be more useful? |
