NSR POWERVALVE
Haze
PostPosted: 12:15 - 27 Nov 2007    Post subject: NSR POWERVALVE Reply with quote
Hello - Im replacing the barrel on my 1992 NSR125 and ill be buggered if a can get the power valve off! Is it worth my while removing it or is it jut less hassle to replace it with a new part?[/code]
With Thanks Leon
T1z3R
PostPosted: 12:21 - 27 Nov 2007    Post subject: Reply with quote
it might be a bit pricey to replace it.
theres an oil seal around the end of the shaft. you need to get that out then you can pull the shaft out.
id replace the oil seal though as itll likely end up buggered from trying to remove it.
duck my sick!
Haze
PostPosted: 12:55 - 27 Nov 2007    Post subject: Reply with quote
Great thanks for the advice, iv been pulling my hair out!
With Thanks Leon
alains
PostPosted: 13:42 - 27 Nov 2007    Post subject: Reply with quote
i agree , each flap cost £20 ex VAT , the oil seal cost peanuts . all you have to do is a perfect clean of the flaps to avoid stocked valves . the seal needed is 91201 PA9 004
here is a list of spares with refs & price (note cyl-piston is now £105)
The last post was made 18 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 38.96 Kb
