| VivaDan |
 VivaDan L Plate Warrior
| benjami |
 benjami Nearly there...
 Posted: 14:43 - 27 Nov 2007 Post subject: |
I've never changed the variator nut after removing it from my speedfight, which is basically the same deal.
If you want to change it to be on the safe side, either just take your transmission case off and measure it.
Or, alternatively you could ask on www.pug-club.co.uk, you'll probably find that it has already been answered so use the search button.
Good luck! |
| VivaDan |
| benjami |
| ZRX61 |
 ZRX61 Victor Meldrew
| cheekythomas |
 cheekythomas Crazy Courier
 Posted: 23:20 - 28 Nov 2007 Post subject: |
The nut is a M10... and needs a 14mm socket.
Ideally you should replace it everytime you undo it as it gets messy if it comes undone.... but you dont have to as ive known them to be reused and not a problem... make sure you properly tighten it up though, use the locking tool and a torque wrench
The O-ring is only on the older models when the rollers used to be greased... nowadays the rollers are nylon coated so self lubricating, therefore theres no grease in there to need the seal. |
The last post was made 18 years, 311 days ago. Instead of replying here, would creating a new thread be more useful? |
