mastercylinders
Keir
PostPosted: 11:04 - 30 Nov 2007    Post subject: mastercylinders Reply with quote
My srad trackbike has standard brakes albeit with braided lines and HH pads. Id like to upgrade them a little bit. What would be the advantage of a bigger/better master cylinder? How can i tell what one i need? can i use one off a radial braked bike?
thanks
Current : '08 Yamaha FZ1s
gadfium
PostPosted: 15:34 - 30 Nov 2007    Post subject: Reply with quote
Yes, you can use one off another bike (try to match it with a similar braking system, i.e. if you're bike has 4-pot calipers, get one off a bike with 4-pot calipers).
From memory, a bigger M/C diameter will give you increased power, less lever travel and less feel (as it is displacing more fluid per unit of stroke) whilst requiring less finger pressure (i.e. it will require more sensitivity on the riders part), whilst a smaller diameter will give more lever travel, more feel, less initial bite and will require more finger pressure.
I have changed the MC on my SP1 to a radial MC off a Gixxer 1000 K7. That, along with fresh fluid, has made the brakes awesome (and SP1 brakes are pretty damn good as standard). I paid £75 for a virtually new MC off Fleabay.
Don't forget, you may need new hoses (or an adapter), as the fluid outlet is on the bottom of radial cylinders rather than at the end of the cylinder.
Those who risk nothing, do nothing, achieve nothing, become nothing.
Keir
PostPosted: 15:43 - 30 Nov 2007    Post subject: Reply with quote
cheers.
How do you find the size of the m/c to see if its bigger or not?
gadfium
PostPosted: 15:57 - 30 Nov 2007    Post subject: Reply with quote
Keir_K3 wrote:
cheers.
The internal diameter is normally stamped/cast into the body of the cylinder (look underneath the cylinder) . My SP1 has a 19mm or 3/4" cylinder.
These look pretty trick from £135, and have flip-up levers as well (Hafer have had some good feedback on other bike forums). These would be as cheap as getting, say, a Suzook MC and buying a CRG/Pazzo flip up lever....
The last post was made 18 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 41.08 Kb
