| Jamie S |
 Jamie S World Chat Champion
| sanchezz_182 |
 sanchezz_182 Crazy Courier
| T-b0Ne321 |
 T-b0Ne321 Spanner Monkey
 Posted: 17:34 - 30 Nov 2007 Post subject: |
Is that not also called arc eye?
If it is then, Usually will just heal in 24 hours and will just hurt like a bitch everytime you blink. So good luck with not blinking! ____________________ Current bike: 08 ER6-N |
| Jamie S |
| D O G |
 D O G World Chat Champion
| Ste |
 Ste Not Work Safe
| scorps |
 scorps World Chat Champion
 Posted: 17:37 - 30 Nov 2007 Post subject: eh? |
i think someones winding you up jamie
youd know about it before you went to sleep  ____________________ Do not presume that I am male. |
| Jamie S |
| Ichy |
 Ichy World Chat Champion
| T-b0Ne321 |
| Jamie S |
| T-b0Ne321 |
| Hetzer |
 Hetzer Super Spammer
 Posted: 17:50 - 30 Nov 2007 Post subject: |
What? I've looked at welding arcs before and had no problems. Do you have to be really close or something? ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| Jamie S |
| JonB |
 JonB Afraid of Mileage
| Jamie S |
This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
| owdamer |
 owdamer World Chat Champion
 Posted: 18:04 - 30 Nov 2007 Post subject: |
I used to work a brake press machine at a sheet metal firm and I started having problems with my left eye because of the welding flash. I went for an eye test as i was a bit worried about it. My eye test didn't show up any problems and my eyesight improved when I left the sheet metal job.
If you got it bad you would probably know by now. heres a bit of info.
| Quote: | Eye injuries - flash burns
A flash burn is a painful inflammation of the cornea, which is the clear tissue that covers the front of the eye. A flash burn occurs when you are exposed to bright ultraviolet (UV) light. It can happen in all types of UV light but is a common problem among welders. That’s why it is sometimes called welder’s flash or arc eye.
Flash burns are like sunburn in the eye and can affect both your eyes. Your cornea can repair itself in one to two days and usually heals without leaving a scar. However, if the flash burn is not treated, an infection may start. This can be serious and may lead to some loss of vision.
Symptoms
The symptoms of flash burn include:
Pain that may be mild to very severe
Bloodshot eyes
Light sensitivity
Watery eyes
Blurred vision
The feeling of having something in your eye.
A range of sources
You can receive a flash burn after being exposed to UV light. Sources include:
Welding torch
Direct sunlight
Reflection of the sun off water or snow
Sunlamp in a tanning salon
Some types of lamps, such as halogen or photographer’s flood lamp
Lightning
Solar eclipse.
Diagnosis methods
Diagnosis requires an eye examination, which may include:
Anaesthetic drops - the doctor may use eye drops to numb your eyes. These drops work long enough to examine your eyes and should not be used more than once.
Inspection - the eyes are checked for damage.
Dye - the doctor may put orange dye in your eyes. This shows up any damage when a special blue light is used. The dye is washed out with your tears.
Treatment options
Treatment for flash burns could include:
Atropine drops - sometimes used to relax the eye muscles, which in turn eases pain and allow your eyes to rest and heal. Your pupils (the black part of the eye) will look bigger than normal. This effect lasts several hours.
Dressing - your eyes may be covered with a padded dressing to rest them and allow them to heal.
Antibiotics - you may be advised to use antibiotic drops or ointment at home to stop infection. Follow your doctor’s advice as to how often to use the prescribed eye drops or ointment.
Review - you will be reviewed in 24 to 48 hours to make sure that your eyes are healing. Some problems, such as infection, don’t show up right away. If there are any serious problems, you will be sent to an ophthalmologist (specialist eye doctor).
Eye drops and ointments
General suggestions on how to use eye drops and ointments include:
Wash your hands before touching your eyes.
Rest your finger on your cheek and pull down the lower eyelid.
Tilt your head back and drop the liquid in behind your lower eyelid.
For ointment, smear a small amount along the inside of the lower eyelid. Make sure that the nozzle doesn’t touch the eye.
You need to continue with the treatment until your eyes have healed.
Keep all drops and ointment in the fridge and out of reach of children.
Taking care of yourself at home
Suggestions include:
Take painkillers such as paracetamol or codeine. Check the packet for the right dose. The pain is likely to last about a day.
Don’t wear contact lenses until your eyes have healed.
Wear sunglasses if your eyes are sensitive to light.
Use artificial tears or lubricants to help any discomfort in your eyes. You can buy these products over the counter at most chemists.
It is important to return for a check-up when the doctor advises.
Seek urgent medical help
You should see your doctor or go to the nearest hospital emergency department if you have symptoms including:
Blurred vision
Vision changes
Seeing spots or flashes of light
Pain on moving your eyes
Worsening pain
If you are concerned about your eyes for any reason.
Prevention suggestions
Prevention is best. Suggestions include:
Protect the cornea from UV light by wearing coated safety goggles.
Always wear a welder’s mask when welding. Make sure the goggles are made to Australian standards and cover the eyes completely.
Sunglasses should protect against both UVA and UVB radiation. Check the label when buying sunglasses.
Where to get help
Your doctor
Emergency department of your nearest hospital
Ophthalmologist
Chemist
Things to remember
A flash burn occurs when you are exposed to bright UV light.
With the right care, your cornea can heal itself without leaving a scar.
| JonB |
| veeeffarr |
 veeeffarr Super Spammer
| JonB |
 Posted: 18:46 - 30 Nov 2007 Post subject: |
LOL. He downrates me all the time.
Gotta love it.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| SoND |
 SoND World Chat Champion
 Posted: 19:09 - 30 Nov 2007 Post subject: |
You'll be fine.
If you've looked at the arc for too long your eyes might feel dry and sore later that night, stick some eye drops in if that happens. |
| Ichy |
| Dragonfly |
 Dragonfly Super Spammer
 Posted: 00:10 - 01 Dec 2007 Post subject: |
Can it cause long term damage if exposed a lot to it? sick of seeing the OH look fanny eyed and complaining from not wearing his mask Maybe some info will help him wear it. Owdamers info was good there also.  ____________________ All the breast.
Muzza on Binge:
He's too busy beating the everloving shit out of Lizzie to notice this thread has taken a turn down Drama Avenue and stopped off at the popcorn shop. |
| Paddy Blake |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 18 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
