Major NSR help needed!
Thom
PostPosted: 17:38 - 30 Nov 2007    Post subject: Major NSR help needed! Reply with quote
Right, I erm... Knocked my bike over yesterday but luckily it took no damage as it fell onto a large heavy duty plant pot! Well a cracked fairing.
Anyway since then i wheeled it along my garden and went to staart the bike, but realising i had the fuel line turned off i knocked it 'on'.
All of a sudden a massive torrent of fuel flows from a pipe located near the centre stand, so i turned it to 'off' again.
What happened?!
i also noticed there is a pipe that seems to come from the coolant chamber.
Where do these two pipes connect to!
I've had a rummage around the bike, had all the fairings off and the fuel tank is currently off. I've noticed that the underside of the carberator has a small attachment to where maybe a pipe should connect?
I don't dare run the bike in fear it happens again so please, fast advice!
Could it be after falling over the fuel float is stuck?
moonym20
PostPosted: 20:44 - 30 Nov 2007    Post subject: Reply with quote
nothing to worry about, it happened with mine when it fell over,
a quick fix was to knock the carb with the handle of a screw driver a few times to move the floats,
it might run rough until you get the carb out and clean the float chamber up and check that the floats weren't damaged when it fell. hope that helps Thumbs Up
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
alains
PostPosted: 01:41 - 01 Dec 2007    Post subject: Reply with quote
i agree , the fuel valve has been stocked but may be it's the moment to clean the carb and air box filter
The last post was made 18 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.84 - MySQL Queries: 13 - Page Size: 36.02 Kb
