New Helmet ... Unsure
alien.46.uk
PostPosted: 23:34 - 30 Nov 2007    Post subject: New Helmet ... Unsure Reply with quote
Hi All ...
For the past 2 years i've had a £30 Nitro Helmet ... which when I was on the 125, was ok, but I have now upgraded due to now being on the 600.
Anyway, I went to the NEC bike show (second time, but this time had to pay to get in, lol) ...
Got to the MandP stand which I'd already seen the KBC Gun DUO there for £119, which is a very good price, but now was £99.99, so over I went too buy one which I did.
But what was odd, was that my Nitro was an XL, where the advised me to get the M ... Now I tried on an XL, an L, and an M ...
*XL was defiantly too big ...
*L felt pretty good, but was told when it wears it will become sloppy ...
*M felt too tight, but was told it would wear and flex a bit to eventually sit well ...
Now the ridge on the forehead felt so tough I was advised to get a spoon and using the outer curved bit, smooth down the (cork?) ridge.
I decided on the M purely based on the salesman's advice and as he was a representative from KBC themselves I decided to trust them.
So did the spoon thing for a bit then, tried just sitting in me room for a bit with it on. About 10 mins in, it was hurting behind my eye sockets, should it be this tight even at the start? I'm sure the nitro wasn't like this but was soo long ago now I cant remember ...
I was told after the M size it changes to a complete bigger shell, when XS, S and M use the same shell, but for L and XL, it uses a complete bigger shell.
How should a well fitting helmet feel roughly when new and when worn in?
How long would wearing in roughly take?
Has anyone else had experience wearing in the KBC V2's?
Any help would be appreciated.
Thanks a lot,
Luke.
2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD
Itchy
PostPosted: 23:47 - 30 Nov 2007    Post subject: Reply with quote
Nitros are always dead big , AFAIK they have a single shell size and pad it heavily , I ripped open a nitro once and it had a helluva lot of padding ,
Nitro I am XXL64 + , Shark I'm smaller, though I can't actually tell anymore cus there are no size markings on my ruined shark.
Stu_666
PostPosted: 23:50 - 30 Nov 2007    Post subject: Reply with quote
Have'nt got experience of those helmets but it does sound like its too tight.
I did a CBT once where they gave me some crappy helmet which was too small as they didn't have any other sizes and after about half an hour I had an aching forehead like you had.
The fit should be comfortable with not too much play or tightness. Should be able to move the helmet slightly from side to side as it needs some give (obviously not too much though).
With the helmet I've got (had Rolling Eyes ), it didn't really change its shape from new (as in expand a bit inside).
Jlo31
PostPosted: 23:55 - 30 Nov 2007    Post subject: Reply with quote
Hi,
I am not keen on the advise of using a spoon to push in the padding. The foam liner is the 'shock abbsorber' to help protect your brain in an impact and this could reduce the effect of the shock absorber.
May be you don't have a KBC head. Bit naughty of the KBC representative as I think he just wanted a sale!
Hope it does bed in for you.
Jlo
Seb
PostPosted: 23:58 - 30 Nov 2007    Post subject: Reply with quote
A new lid should definately feel tight but not so much so that its actually painful to wear.
Best advice I can offer you with regards to a lid is simply try everything on, I went into my local HG aiming to buy a HJC or AGV and came out with a completely different Arai purely because of comfort and fit.
But yeah, whilst I can't help but think that the advice on the spoons is madness (Likely to cause extra wind noise as well as potentially lower the liners ability to absorb and spread an impact), he is right in the regard that the fit of the lid will improve as you wear it in, gloves tend to be prone to this too, often painfully so.
2010 Triumph 1050 Sprint ST
The Tot
PostPosted: 00:11 - 01 Dec 2007    Post subject: Reply with quote
I think Luke VFR has the KBC VR2's. I once had a KBC AR-1 and that had the best padding and plushest liner of any helmet i've tried (it was a beige colour) - better than my arai actually! But i took an S in that! - I think they only make 2 shells and just shove loads of padding into their helmet. Probably only 2 shell sizes and make up by the padding?
Never argue with autism
Itchy
PostPosted: 00:13 - 01 Dec 2007    Post subject: Reply with quote
Hmm , I don't seem to be able to find a size on my ruined shark helmet , anybody know if Shark lids have the size printed on them anywhere? (I'm buying shark again this year and want to do it via mail order but obviously can't find the size Doh!).
TheDonUK
PostPosted: 17:13 - 01 Dec 2007    Post subject: Reply with quote
Sounds like the large would have been a better bet, or a different helmet that fits your head better.
It shouldent give you any pain when breaking in a lid, The cheekpads will give somewhat, as well as any other padding, but from what i understand the forehead part stays largely the same, for obvious reasons. Keep plugging away at it, and hope that it beds in, otherwise you are best getting a new lid, that fits you well. If you ride around with a lid that is too tight it will cause you too loose consentration and that aint good son...
BTW A decent helmet is just as needed on a 125 as a 600...
Finglonga
PostPosted: 20:24 - 01 Dec 2007    Post subject: Reply with quote
How long did you try it on for? You should have it on for a minimum of 10 minutes. Sounds like its too small or even could be the wrong shape for your head. Not all helmets fit the same size head.
If you haven't used it I would take it back (they may not take it back now as they don't know if you may have dropped it) or ring them to see if you can return it by post and try a different make one.
If you are not 100% sure about the fitment of a crash helmet walk away, its allot of money to spend on a plant pot!
Andy Sez....
F.Y.Y.F.F.
alien.46.uk
PostPosted: 21:51 - 01 Dec 2007    Post subject: Reply with quote
Hmm ... ok, thanks for everyone's advice.
I will give it a try out on the bike I think for a 40 mins ride or so, see what it's like. I'll also strap the old helmet to the bike just in case.
I have a feeling based on what you lot said, I may be in another battle with M&P. First battle were over boots which fell apart in 2-3 months wear, lol ...
Only thing is, I guess i'll have to pay full whack to get it changed for a larger size ...
Hmm ... makes me think I should have gone for the AGV Stealth ... Was a Nice matt black with neon blue fog and skulls on with a blue mirror visor ... lush ... Was just more pricy ... It fit very well ... just tight on cheeks which would probably have been more suitable ... I just decided to trust the KBC bloke with M&P.
Anyway, as I said, i'll give it a go on the bike see what it's like ... what sort of timescale would it have on wearing in the forehead area?
Thanks.
alien.46.uk
PostPosted: 21:52 - 01 Dec 2007    Post subject: Reply with quote
True enough ... But I was perfectly happy with my £30 lid ... but lets not get into this sort of argument again on here Laughing ...
I may end up carrying on to be happy with it, if the KBC doesn't get sorted.
J.K.R
PostPosted: 22:12 - 01 Dec 2007    Post subject: Reply with quote
If i was you i'd have taken advantage (ooo-er) of the £1<>$2 rate and got a simpson Wink
Wouldnt have bought the KBC if it needed a gentle 'spooning' Laughing
www.oldskoolsuzuki.info
Finglonga
PostPosted: 22:58 - 01 Dec 2007    Post subject: Reply with quote
If you try it on the bike you can't expect them to take it back as it is 100% second hand. You would stand no chance if they find road grime on it, and they will as you can always tell when a lid has been used.
Wear it around the house for a few hours, its the same thing and if it hurts you have dropped a bollock!
Andy Sez....
F.Y.Y.F.F.
Ichy
PostPosted: 23:37 - 01 Dec 2007    Post subject: Reply with quote
Sorry mate but as far as I'm concerned you've been screwed. Normal M and P tactics. No way will they take it back without some PITA. The spoon stuff simply means that it was the wrong shape for your head.
I should point out I hate the bastards, not biased or anything.
Type_Mo
PostPosted: 00:48 - 02 Dec 2007    Post subject: Reply with quote
no point tho as every simpons ha a different fit.
you can try on 3 of the same simpson lids and they will all fit different Laughing
strag
PostPosted: 01:12 - 02 Dec 2007    Post subject: Reply with quote
Your head is weird...live with it Razz
carbon bling
The last post was made 18 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 94.86 Kb
