| The Tot |
 The Tot World Chat Champion
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
 Posted: 19:47 - 03 Dec 2007 Post subject: |
Are your drills sharp bud? They can go dull every few mins if it's a hard enough material... Also, spray some oil on there as you're doing it. Helps keep them sharp a bit longer.  |
| Pete. |
 Pete. Super Spammer
 Posted: 19:51 - 03 Dec 2007 Post subject: |
Sharp drill with little back-off, should drill easily on a slow speed. ____________________ a.k.a 'Geri'
| deanoet |
 deanoet World Chat Champion
| The Tot |
| Jamie S |
 Jamie S World Chat Champion
| Jamie S |
 Posted: 20:43 - 03 Dec 2007 Post subject: |
Bering in mind I could get £5 EACH for them on ebay.
Heres a picture of them, lovely arn't they.  |
| The Tot |
| stinkwheel |
 Posted: 21:25 - 03 Dec 2007 Post subject: |
Hardened tool steel is way, way, way harder than titanium.
Of course if you try to drill too fast and overheat the drill, it looses a lot of the hardening.
A normal, sharp but good quality drill should waltz through titanium.
Titanium has a lot of myths about it. It is stronger per unit WEIGHT but not per unit volume than steel. A titanium bar designed to carry the same load as a steel one would be lighter than the steel one but it would also be consdierably bigger. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Jamie S |
| Pete. |
 Pete. Super Spammer
 Posted: 21:46 - 03 Dec 2007 Post subject: |
The Brinell number is the proper measure of hardness, not the density. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 21:48 - 03 Dec 2007 Post subject: |
The density of a material has nothing whatsoever to do with its hardness.
Diamond has a density of up to 3.53g cm-3 and it is pretty much the hardest material known to man (although I think someone came up with a tungsten salt recently that is harder).
With metals especially, the hardness depends a lot on how the metal has been heated and cooled to form crystals. With steel the carbon content is also critical. Tool steel has a high carbon content and is heated hot then rapidly cooled. This makes it VERY hard but brittle.
A titanium exhaust has essentially been repeatedly annealed (by heating and cooling) and so will be about as soft as titanium gets.
The hardness is often measured using the Rockwell C (Rc) scale. Industrial diamond is 70+. Good quality steel drill bits will be in the mid 60's. Hardened Titanium alloy is somewhere in the high 40s. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| The Tot |
 Posted: 22:13 - 03 Dec 2007 Post subject: |
Ironicaly i'm supposed to be doing a degree in materials engineering . It's glad to know about people's actual experiences as opposed to the bollock load of theories i learn! Cheers guys! ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 22:26 - 03 Dec 2007 Post subject: |
if all else fails head up to pentland tech map
the 2 guys in there will go out of there way to help,
ell them logan sent you (the guy with the black kawasaki with the single sided swing arm that they machined)
brilliant guys and probably won't even charge you anything ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| The Tot |
| hmmmnz |
 Posted: 23:00 - 03 Dec 2007 Post subject: |
there is a good bike shop in tranent
Eclipse Motorcycles
5-7 Elphinstone Road
Tranent
East Lothian
EH33 2LG
Tel: 01875 611400
the guys are pritty good in there,
best place to get a mot is
lothian motors they'll pass you bike with a stupidly loud exhaust, they only care about safety not bollocks like noise
yeah still in edinbugger  ____________________ the humans are dead
| ZRX61 |
 ZRX61 Victor Meldrew
| The Tot |
 Posted: 00:21 - 04 Dec 2007 Post subject: |
I am truly buggered for my degree . Yeah, i checked the vickers and brinell hardness on both materials. Cobalt is by far harder than Titanium hence why i decided to go on the drills. Remember doing the microhardness tests on steels and using the diamond and ball indentor .
I'll try the place in tranent because if i'm bikeless, at least i can take the 44 bus back home to musselburgh. I'll book ma MOT once i fit the baffles and number plate light on.
Many thanks for all your help  ____________________ The Tot 2019 Z1000SX - 2007 R1
| hmmmnz |
 Posted: 01:18 - 04 Dec 2007 Post subject: |
i think i have a spare roadlegal bolt on can somewhere about...
if it hasnt been binned, failing that, vmax dude is not far from me and he has a small collection of cans, that you could use for your mot,
but im telling you lothian motors won't fail you on a loud exhaust system,(they are not a dodgy place either.. they will ping you for anything else, but they have ype motorcycle tuners and dyno next door, so hey let loud bike through as a matter of course)
they passed mine, and i had ringing ears by the time i got to work with my old system (just to cockenzie powerstation)
i might even have a numberplate light around as well,
an original and a litle after market led job if you want either of them. ____________________ the humans are dead
| bladerunner |
 bladerunner World Chat Champion
| Jamie S |
| Big Pete |
 Big Pete Spanner Monkey
| Jamie S |
| The Tot |
 Posted: 20:22 - 07 Dec 2007 Post subject: |
Yeh, thank god Stokes packed 2. I'm a very crap materials engineer if i fail to see the correlation between hardness and conversely being brittle. One of the drill bits sheared off because it just grabbed as it punched through and i didn't back off it time! Well, at least the bastard is done. And MOT 2moro, the bike is STILL loud! Nevermind, at least i made to effort. Cheers Jamie for your help  ____________________ The Tot 2019 Z1000SX - 2007 R1
The last post was made 18 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
