Honda Valve Stem oil Seals.
Jamie S
PostPosted: 19:05 - 03 Dec 2007    Post subject: Honda Valve Stem oil Seals. Reply with quote
Whats the best place to get some valve stem oil seals for my TLR200 from ? How much should they be as well?
PostPosted: 21:53 - 03 Dec 2007    Post subject: Reply with quote
Try www.davidsilverspares.co.uk
Probably £4 or so each.
D O G
PostPosted: 21:59 - 03 Dec 2007    Post subject: Reply with quote
Can the 'pup not sort you out?
Ariel Badger
PostPosted: 22:19 - 03 Dec 2007    Post subject: Reply with quote
I told you that white smoke was oil.
Jamie S
PostPosted: 22:26 - 03 Dec 2007    Post subject: Reply with quote
Which would also explain why the oil smells of petrol, it burns lots of oil and I can't get a nice plug colour ?
A compression test won't tell if they have gone , so I'm going to replace them and hope for the best , It had new rings not so long ago.
Jamie S
PostPosted: 22:50 - 04 Dec 2007    Post subject: Reply with quote
I don't know.... Mr pup.....Mr pup, theres a customer......
Laughing Thumbs Up
Ariel Badger
PostPosted: 22:57 - 04 Dec 2007    Post subject: Reply with quote
If petrol has got into your oil it will be thin like wee and get past the rings and burn. You say the oil smells of gas so could the carb have been left on and flooded past the float and drained into the sump past the piston?
Odie
PostPosted: 18:42 - 05 Dec 2007    Post subject: Reply with quote
You will also need a top end set as you will have to take the head off, add another £40 to your bill.
Unless you have a special tool that allows you to lock the cylinder in place (with compressed air), keeping the valve shut and then taking off the valve springs and change the seal.
I have one of these tools, they are a god send, has saved me and my friends loads of money over the years.
.Chris.
PostPosted: 19:18 - 05 Dec 2007    Post subject: Reply with quote
Do you get a puff of blue smoke on the overrun? That is a good indicator that the stem seals have gone.
Chris
1985 Kawasaki Z550F
Jamie S
PostPosted: 19:29 - 05 Dec 2007    Post subject: Reply with quote
I have a head gasket here, cost me £5.
The last post was made 18 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.51 - MySQL Queries: 15 - Page Size: 63.19 Kb
