Leaking Carb?? Help
flyer
PostPosted: 23:17 - 04 Dec 2007    Post subject: Leaking Carb?? Help Reply with quote
My CCM 350 2 stroke has a leaking carb. Im pretty shite with engines but can do the basics. Ive taken off the bottom which is held on with a pivoting clip, and geuss its leaking because the floats arent working so the needle is perminently down, is this right?? Any suggestions for fixing it??
Any help will be much appreciated. Thanks
st3v3
PostPosted: 23:46 - 04 Dec 2007    Post subject: Reply with quote
Seen carbs use springs for the floats before, just check if this is the used method the spring isn't too long/stretched thus keeping the floats in a position to cut off fuel.
Paddy Blake
PostPosted: 00:06 - 05 Dec 2007    Post subject: Reply with quote
Where is it leaking from.Is it the top edge of the bowel or the bottomIt could be the seal on the bowel.
Paddy.
Joeb46
PostPosted: 10:50 - 05 Dec 2007    Post subject: Reply with quote
check the floats make sure no fuel has drained in to them, this would stop them well floating... Thumbs Up
Current- Drz400sm- For sale
Kawasaki er-5 race bike# 106
Whosthedaddy
PostPosted: 11:05 - 05 Dec 2007    Post subject: Reply with quote
I suppose the simplest check would be to make sure that the screw to drain the bowl is tight and not causing a leak in the first place.
flyer
PostPosted: 09:40 - 06 Dec 2007    Post subject: Reply with quote
ok ta, its a quick release type bowl, with a simple clip holding it on,( all original), its leaking through what looks like a overflow?? But I shall check the floats for fuel in them, fingers X!
alains
PostPosted: 10:29 - 06 Dec 2007    Post subject: Reply with quote
it's mostly a fuel valve sticking in it's sit , sometimes one or two knocking with a mallet will solve the problem
The last post was made 18 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 51.08 Kb
