weird brake light problem
bonehead
PostPosted: 18:13 - 06 Dec 2007    Post subject: weird brake light problem Reply with quote
Put a new bulb in the rear of the bandit, but it doesnt get brighter when i brake? I thought the switch was trashed, but it does come on when the lights are off and I apply the brake Confused
geordiecbrblo...
PostPosted: 18:15 - 06 Dec 2007    Post subject: Reply with quote
At the risk of asking the obvious Wink you did put a dual filament bulb in there i.e. usually 21W / 5W ?
bonehead
PostPosted: 18:21 - 06 Dec 2007    Post subject: Reply with quote
You are probally right, I never checked, I just asked the bloke in the local parts place for a bandit rear light bulb and gave him the old on, never thought to check. Embarassed
Finglonga
PostPosted: 19:36 - 06 Dec 2007    Post subject: Reply with quote
Or you have the right bulb but its in upside down. It shouldn't fit that way but its possible to get it wrong.
Andy Sez....
F.Y.Y.F.F.
Phil_P
PostPosted: 21:30 - 06 Dec 2007    Post subject: Reply with quote
Could be that old standby, a dodgy earth.
It is not enough to win, others must fail.
Moto Guzzi 1100 Sport Injection '96
Old Time Biker
PostPosted: 22:02 - 09 Dec 2007    Post subject: Reply with quote
when I put some new LED rear lights on a 98 bandit the bulbs went in upside down. Side lights were brake lights and vice-versa,proper pain in the arse,ended up going back to standard bulbs-didnt fancy re-wiring bulb holders.
IT WENT WHOOOOSH.........AND WAS GONE!!
PostPosted: 22:29 - 09 Dec 2007    Post subject: Reply with quote
To check if the bulb is in upside-down first pull the front brake to put the "brake" light on. Now, still holding the brake, turn on the lights - if it gets brighter the bulb is in wrong.
TBH the problem sounds like a bad earth, or as said above a single-filament bulb.
The last post was made 18 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 51.92 Kb
