| Marci |
 Marci Brolly Dolly
 Posted: 10:48 - 06 Dec 2007 Post subject: CB500 rear brake drag |
Wotcha peeps... the CB500 failed it's MOT this time around. Sprocket Carrier bearing, rear brake pads, and front brake sticking.
Replaced carrier bearing. Cleaned rear caliper, put new pads in. Now the disk drags on the inner pad. There's a good 1mm gap on the outer piston-side pad, but the inner pad just grates on the disk. As soon as I pull the clutch in, it locks up the back wheel.
Haven't gotten round to doing front brakes yet - intend to pop the pads out and give the pistons a thorough cleaning, but any suggestions for this back brake problem besides beatin' the crap out of the thing with a lump hammer? ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| spikenipple |
 spikenipple Crazy Courier
| Marci |
 Marci Brolly Dolly
 Posted: 11:21 - 06 Dec 2007 Post subject: |
Yep... all the way back... and haven't pumped the brake to make them touch the disk yet. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| spikenipple |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Marci |
 Marci Brolly Dolly
 Posted: 11:55 - 06 Dec 2007 Post subject: |
Aye - tis one o' those gaz... front and back are both sliding calipers... same problem front and back mefinx...
Wots the best way to attack em? Rear is Brembo single pot, Front is Brembo twin pot.
EDIT: n/mind - just found your previous topic  ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
| Gazdaman |
| Marci |
 Marci Brolly Dolly
 Posted: 10:39 - 07 Dec 2007 Post subject: |
Helped a treat...! Had to whack em apart with a rubber mallett they were that jammed...
They obviously hadn't been touched since the bike was built... got the front apart and had to take a file to it to get it back to as-new... copperslip'd and refitted and all peachy... but by that time I'd gotten sick of sitting on my arse in a puddle in the backyard working by the light from the kitchen window... couldn't be buggered with the back, so I've just dropped it off at the local bike-shop for them to sort, along with the added challenge of stopping the speedo drive spinning backwards when you push the bike backwards, as it snaps the speedo cable every time. ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
The last post was made 18 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
