| Keen |
 Keen Guest
| Kickstart |
 Kickstart The Oracle
| Keen |
 Keen Guest
| Guest |
 Guest
| TJ NSR |
 TJ NSR World Chat Champion
There is a gap of 1 year, 232 days between these two posts... |
| ilovens125f's |
 ilovens125f's Renault 5 Driver
| Scotty |
 Scotty Scooter Boi
| Kickstart |
| Hex |
 Hex Party Boy
| Syfoon |
 Syfoon TRUCK!!!
 Posted: 12:04 - 15 Oct 2003 Post subject: |
Ah, burning wasps nests. Great fun!
Lighter fluid works best, but you get stung like a git trying to finish the job.
Found the best way was to firebomb the nest...
... although thats not really a good idea for Keith to use . ____________________ Not here... |
| Scotty |
 Scotty Scooter Boi
| Kickstart@Work |
 Kickstart@Work Scooby Slapper
| Ste |
 Ste Not Work Safe
 Posted: 14:25 - 15 Oct 2003 Post subject: |
Impressive. Will your council not come and kill them for you? They have done all ours (normally 2/3 a year )
Still havn't found that hornets nest which is nearby  |
| Kickstart@Work |
| James |
 James Spanner Monkey
| malc |
 malc Two Stroke Sniffer
 Posted: 15:00 - 03 Dec 2003 Post subject: Tuning NS125 |
Hi,
I have an old K reg ns125 and it already has a high performance exhaust but am interested in the aircleaner change.. Is this the sort of wire grid spong type? Any suggestions where best to get one and how much?
I bought the racing reeds and did very little
The engine is quite flat up to about 4K rpm and then improves to about 6K and then flies.. I would like to normalise this a bit so that it runs better at the lower revs.. any ideas?
If anyone has ns125 spares, particularly a spare complete engine, I owuld be interested as it woudl be better to build and tune the spare than keep stripping the working bike.
Thanks.. I hope to get some advice..  ____________________ _______________________________
Malc
In search of ns125 Bits  |
| Kickstart |
 Posted: 15:08 - 03 Dec 2003 Post subject: |
The actual airbox on the NS is meant to be fairly restrictive.
The only real way to get the low down power back is to get rid of the performance exhaust. Do that and you will get some low down power but loose loads of top end power.
There used to be an aftermarket power valve that you could weld onto the exhaust. Haven't seen them advertised for years. They were just a valve operated by exhaust gas pressure and at low revs they were open and effectively increased the exhaust port volume.
Best solution would be to find an engine and exhaust from an imported full power NS125.
| malc |
 Posted: 15:28 - 03 Dec 2003 Post subject: Import? |
Hi Keith
Thanks for that input... The bike is an Italian Import. 92 model but still with the square steel frame.
What would I look for in a 'full performance' engine?
I am seriously considering the aircleaner change and upping the main jet. Ideally, I would like an old carb to dabble on so as not to destroy the road bike...
Malc ____________________ _______________________________
Malc
| Kickstart |
 Posted: 16:16 - 03 Dec 2003 Post subject: |
If it is an Italian import then it probably already has the full power engine. On the r/h side of the bike (from sitting on it) there is a small cover going from the clutch cover up to the side of the barrel. This opens and closes the ATAC chamber. On UK restricted models this was left off and the ATAC chamber was open (low revs position) all the time.
General trick with the NS was to drill holes in the airbox lid or fit a K&N single filter. Just replacing the filter element will not do much. If you do this it is probably best to up the jetting slightly.
Without saying goodbye to loads of top end power there is not much you can do for the mid range really. However it might be worth trying a normal Honda exhaust rather than an aftermarket one. However avoid the one from the UK spec bikes as they were restricted.
| malc |
 Posted: 16:31 - 03 Dec 2003 Post subject: ATAC |
Hi Keith
Yes, there is a triangular shape cover plate, not opened it so not sure what is in there .. will have a look.. I assume it is safe to open and won't shoot springs and thigs out
Thanks for your advice.
Malc
| Kickstart |
The last post was made 22 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
