would these specs power hot grips
lee8040
PostPosted: 15:53 - 12 Dec 2007    Post subject: would these specs power hot grips Reply with quote
Battery capacity 12V7AH
Electrolyte specific gravity 1,260~1,280 20℃
Charging current 7.0A max.
A.C. generator Charging rpm 2,100 rpm (min.)
Capacity 11A min./3,000 rpm
Regulator/Rectifier No contact point type
Charging coil resistance 0.2~0.3
TORQUE VALUES
A.C. generator stator bolt 0.8~1.2kg-m
A.C. generator rotor bolt 5.5~6.5kg-m
would these ratings easily power a set of oxford hot grips on a bike?
PostPosted: 16:07 - 12 Dec 2007    Post subject: Reply with quote
If I remember right from fitting a set to my mates bike, the max amps is somewhere around 3.5 amps. (Please correct me if I've got that wrong.)
So at night with your lights on, grips on full etc. you might struggle, especially when you are stuck in traffic.
The modern Oxfords turn off if the battery voltage drops below a certain point so you mght find yourself turning them on every time you speed back up. (not that easy as you have to hold on a small button until the leds come on)
What bike do you have, someone might have fitted them and can give you more specific information.
Triumph Trophy Launch Edition
lee8040
PostPosted: 16:09 - 12 Dec 2007    Post subject: Reply with quote
i have a kymco zing 125 and thats exactly what it does do, but i have a lil starting problem so i was hoping it may have been that causing them to keep turning off
pa_broon74
PostPosted: 16:31 - 12 Dec 2007    Post subject: Reply with quote
Hey.
Your battery might be on the way out. I recently fitted hotgrips to my 125 and don't have any probs, they're cheapo chinese jobs so don't turn off if the battery gets low.
Mind you, now that I think about it. It has been running a bit wierd lately. I thought it was just the cold... Mmmm... Can't really recall of the top of my head if I have the grips on when it happens...
Mmmm again... Confused
I was thinking about swapping my indicators for LED ones, they pull less current down. If having the grips on proves to be the problem, I might get that done sooner rather than later.
Hope you solve it.
Didn't catch anything.
Finglonga
PostPosted: 17:54 - 12 Dec 2007    Post subject: Re: would these specs power hot grips Reply with quote
lee8040 wrote:
TORQUE VALUES
Torque values need to be much higher or the grips will stay cold. Thumbs Up Wink
Andy Sez....
F.Y.Y.F.F.
PostPosted: 18:46 - 12 Dec 2007    Post subject: Re: would these specs power hot grips Reply with quote
Finglonga wrote:
lee8040 wrote:
TORQUE VALUES
Don't be mean, everyone knows high torques only stop them falling off Thumbs Up Whistle
ZaphodBeeble
PostPosted: 18:56 - 12 Dec 2007    Post subject: Reply with quote
You should be fine with the decent Hot Grips. They definitely turn off as I've fitted these to about 5 bikes recently and the LED flashes when the battery is low at idle. I think they retail at £52 for the decent ones. Thumbs Up
Z
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
The last post was made 18 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 54.3 Kb
