| malc |
 malc Two Stroke Sniffer
 Posted: 13:18 - 17 Dec 2003 Post subject: Upgrade NS125 disks to NSR |
Has anyone upgraded the NS125 rear or front brakes to those of an NSR125?
The back one needs to be fitted on a new swinging arm but I am told that the measurements of the NSR and NS swing arms are the same in terms of width and where the rear suspension fits so the swap should be possible. I will have to fabricate a master cyclinder bracket... Has anyone got a picture of how the NSR master cylinder and brake pedal are fitted? Help"!
Not yet checked the measurement on the fron, may need NSR forks?
Can anyone advise?
Thanks and have agreat Xmas..
Malc ____________________ _______________________________
Malc
In search of ns125 Bits  |
| McJamweasel |
 McJamweasel BCF Junkie
| malc |
 Posted: 14:01 - 17 Dec 2003 Post subject: Trade in? |
Yep, probably but it is an engineering challenge
Looks like the front disk caliper and fork bottom is the same as I have a caliper off an NSR and the one off the NS... The NSR disk is larger a sfar as I can see in the pictures so not sure how that will fit into the old caliper..
Any pictures of the front or rear caiper and foot controls would be useful.. can you help?
Malc
| Ste |
 Ste Not Work Safe
| Danny |
 Danny Ask Me About Stoppie School
 Posted: 14:50 - 17 Dec 2003 Post subject: |
I've found the NSR brakes 'interesting'.  |
| Major_Grooves |
 Major_Grooves The Doctor
| NSR125-Kid-UK |
 NSR125-Kid-UK Attention Whore
 Posted: 16:01 - 17 Dec 2003 Post subject: |
OT?? Where did THAT come from mate?  ____________________ https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman |
| Robby |
 Robby Dirty Old Man
| malc |
 Posted: 16:04 - 17 Dec 2003 Post subject: Brake Options |
Hi,
thanks for comments... I find the rear NS brakes pretty cr*p. Front aren't too bad but thought that the larger disk may improve them a little more. Just don't understand the relationship of a larger disk on the same calipers... I need to fins a local NSR and do some measuring!!!
I'll post on this trhread as I make progress. So far I have the NSR calipers for front and back along with the master cylinders. The front is identical to the NS, but the NS drum is obviously not suitable for the NSR disk
Maybe I can find an NSR front wheel with disk or cpuld someone with an NSR measure the disk diameter for me???
More as I progress.#
Cheers ____________________ _______________________________
Malc
| Kickstart@Work |
 Kickstart@Work Scooby Slapper
| MarJay |
 MarJay But it's British!
 Posted: 17:14 - 17 Dec 2003 Post subject: |
I got EBC Greenstuff pads, braided hoses, new fork seals and a bit of effort to fit the lot and my NS125R brakes were transformed. I could lock the front wheel at will and even do some piddly little stoppies. Don't mess around with fitting brakes from other bikes, it might just make things worse!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| malc |
 Posted: 17:43 - 17 Dec 2003 Post subject: Thanks guys |
Thanks for all the input and advice... I will only upgrade to rear disk if I pick up a cheap swinging arm. The breaker yeard emasured them and a swap should be easy enough.
The NSR calipers are identical to the NS ones so they must be positioned higher on the forks, so will probably just use the newer calipers and keep the front brakes as they are. Replace the pads and maybe hoses as you have suggested.. goo point... as I do have a spare set of NS forks and yokes so not really keen to buy another set!!
My issue with the rear brake is probably down to my other bike/s have/had rear disks so I find the NS a bit weak when a bit of rear braking is needed. Mind you as the weight is so low, the front should suffive unless its icey or going round a corner
Great forum, sensible advice...
Malc
| Scotty |
 Scotty Scooter Boi
| malc |
 Posted: 20:16 - 17 Dec 2003 Post subject: measurements |
Hi Scotty
Yes please, some measurements of the NSR bits would be very helpful.
On the front brakes, I would like to know the diameter of the front disk and the height of the lugs holding the ca;iper. Based on the NSR caliper I have, I know that the physical caliper is the same, so I am guessing that the height of the lugs is greater to allow for what I think is a bigger disk.
If we could start with that, I will photograph the section and overlay some measurements on if I need more detail... Then I'll ponder the rear section.
Thanks for the offer of help..
Malc
| Scotty |
 Scotty Scooter Boi
| Syfoon |
 Syfoon TRUCK!!!
 Posted: 21:51 - 17 Dec 2003 Post subject: Re: Brake Options |
| malc |
 Posted: 22:14 - 17 Dec 2003 Post subject: Brake measurements |
Thanks Scotty... much appreciated....
Hi Syfoon, That was my feeling about the NS rear end... brakes? Mind you may be my 14 stone that makes 'em work too hard..
I'll keep my progress on this list...
cheers
Malc
| Scotty |
 Scotty Scooter Boi
| P_J |
 P_J Nearly there...
 Posted: 22:34 - 17 Dec 2003 Post subject: |
Sorry about not replying to that email, Malc. Just checked excite today. Looks like you are getting the info you need though.
I do have a digital camera but it is not that great. Maybe you get hold of one and post before during and after pictures of the project in hand.
PJ ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
| G |
 G The Voice of Reason
 Posted: 22:46 - 17 Dec 2003 Post subject: Re: Brake Options |
Right, if you're doing this for the challenge, fair enough, though I can think of a lot more interesting things to do (not that I /do/ do them, so shan't criticise )
If your rear brake won't lock the back wheel then give it a service, it should be able to easily enough. Being able to do more than lock the rear wheel is a little useless and possibly counter productive. You're going to need a new wheel to accommodate the disk, which will through the relative sizes between the wheels out, so you'd also need a new front. Also there may be problems with chain alignment etc. Neverminding all the probs you'd have with a new swing arm.
The NS125 was the first bike I ever stoppied (though only to a stop, not rolling ), so the brakes can be good. A decent clean and thorough service should sort them out.
A new wheel would probably mean a new rear, as well as various other bits and hassle. It'd probably be easier just to stick NSR forks in while you're at it.
If you really do want better stopping power, a much neater solution would be to make or get made up a bracket to use some better brakes; a bloke on the rd forum is offering a pair of brackets to allow me to use my spare Tokico 6 pots on my rd for £90 (also takes Tokico 4 pots).
While it may not be as interesting a solution, it'd leave you time to work on something more genuinely useful: have a search on here for the link to the home made NOS kits . |
| McJamweasel |
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| stevo as b4 |
| G |
| malc |
 Posted: 08:14 - 18 Dec 2003 Post subject: Comments etc |
Hi all,
Once again some very sensible comments....
It seems like the front disk will work well with the right pads and a clean caliper. So, plan is to fit the relatively new NSR caliper which is identical to my old NS caliper, just in better condition..
On the rear, I will have another go at improving the drum performance by doing a service.. does anyone know where i can get the shoes or get them rebonded at a reasonable price?
As a project of interest, I will try and get a cheap swinging arm, disk and rear wheel and see if I can upgrade the rear to a disk brake. I know this is not an economical or maybe good use of time in terms of performance but then I enjoy the challenge. I have access to a lathe and milling machine, welder and some other tools so should be able to make up any little things I need..
Is the rear wheel on the NSR the same size (18 inch) as the NS? What size tyre does it have? The NS has a 3.50 by 18..
Thanks again for all your help.
About to search for those Nissin pads..
Malc
The last post was made 22 years, 311 days ago. Instead of replying here, would creating a new thread be more useful? |
