Aerox 50 (2006) Brake light HELP please!
pcnut
PostPosted: 18:41 - 18 Dec 2007    Post subject: Aerox 50 (2006) Brake light HELP please! Reply with quote
Has anyone a wiring diagram as i have a problem with the brake light not working, bulb is fine and tail light is ok. I am guessing that it is using an earth switch via the break levers to activate the bulb.
Thanks PCNUT
Crying or Very sad
divuk83
PostPosted: 20:02 - 18 Dec 2007    Post subject: Reply with quote
Brake light switch will have gone. Costs a couple of pounds from almost any garage and can be fitted in minutes.
Dave
J.K.R
PostPosted: 20:56 - 18 Dec 2007    Post subject: Reply with quote
As divuk says, Will be the little switch, Very bad for going if not lubed often Thumbs Up
www.oldskoolsuzuki.info
kat250
PostPosted: 22:05 - 18 Dec 2007    Post subject: Reply with quote
Notorious for going on the aerox's if its 2006 it will still be under warranty go to a yamaha dealer and get it replaced under warranty.
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
pcnut
PostPosted: 23:28 - 18 Dec 2007    Post subject: Reply with quote
where is the switch located and Many thanks for all the replys.
J.K.R
PostPosted: 18:39 - 19 Dec 2007    Post subject: Reply with quote
Look on the master cylinder, Where the lever attaches there will be a small round looking switch with 2 wires coming out, It unscrews.
As far as i remember you have to take the front handlebar cover off to get at them on aerox's Thumbs Up
pcnut
PostPosted: 21:23 - 19 Dec 2007    Post subject: Reply with quote
Thanks J.K.R
pcnut
PostPosted: 20:11 - 20 Feb 2008    Post subject: Reply with quote
JKR: sorry for slow response, and short update to findings.
No master cylinder, but i found the problem with a DVM and it turned out to be the break lever's housing a switch that was no longer working this was controling the power to the break light and was about £6 per switch.
The last post was made 18 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 52.68 Kb
